查看: 1810|回复: 0
[招聘] NO.84-Senior Physical Design Engineer(Nanjing)
发表于 2012-12-21 17:58:57 | 显示全部楼层 |阅读模式
Key Responsibilities
Depending on experience, key responsibilities will involve some of the following:
•IC implementation from netlist to gdsii, with synthesis, floorplanning, place and route, timing closure, and physical verification.
•As a key member of physical design team, your will work on one of most advanced and the most complex chip designed.
•Leading a team of physical design engineers and resolving the technical related issues.
•Crosstalk analysis, power analysis, and static timing analysis.
•Write scripts in Tcl to improve productivity.
Experience: 5+ years in physical implementation engineering
Essential skills
MS in EE required.&#8226roven track records of working independently on place-and-route project running and DRC/LVS/ERC/Antenna debugging skills
•Experience with Magma or Synopsys place-and-route tool set and physical design project implementation.
•Good programming skill. Capable of writing Tcl or Perl.
•Familiar with synthesis, static timing analysis.
•Self-motivated team worker, good verbal and written communication skills in English.
•Technical and team leadership proffered. Previous management experience highly desired.
•Experience with synthesis, DFT, and verification is preferred.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
GMT+8, 2025-12-22 20:14 , Processed in 1.815862 second(s), 7 queries , Gzip On, Redis On.
