楼主: eda_dude
[原创] Cadence MMSIM12.1 cracked
发表于 2013-1-16 18:32:05 | 显示全部楼层
i think maybe rhel5.5 im retry
 楼主| 发表于 2013-1-18 15:53:07 | 显示全部楼层
Start with Hotfix and then at the end of installation it will ask for Base
 楼主| 发表于 2013-1-18 15:54:24 | 显示全部楼层
Use license file for previous releases, it should work fine with it
发表于 2013-1-20 01:13:53 | 显示全部楼层
thank you so much for the reply.
I tried on rhel 4 and rhel5.7 both are giving same screen. i tried root as well as local user.
./SETUP.SH
it asks for path to install, i put:
/home/user/cadence/installs/MMSIM121
it asks for iscape, i installed it:
/home/user/iscape
it launches IScape,....
i go to 'Local directory/ media install', it asks for path:
/home/user/files/mmsim12/MMSIM12.10.317_lnx86.Hotfix/CDROM1
i click 'continue'
it shows MMSIM Hotfix, i select and click 'next'
it says: 'check the products that you want to install'
and i click 'Start'.
it shows license agreement, i click 'Accept'.
Immediately after start, it gives this error:
发表于 2013-1-21 01:21:06 | 显示全部楼层
sorry my fault. i did not extract all files
thank you once again !!
发表于 2013-1-25 03:38:07 | 显示全部楼层
So many parts, I don't have enough credits to download them
发表于 2013-1-27 13:15:16 | 显示全部楼层
多谢多谢!
发表于 2013-1-30 12:19:42 | 显示全部楼层
Dear  "eda_dude"
Could you share the crack patch  or license?
发表于 2013-3-2 23:24:00 | 显示全部楼层
用IC615的license也行。
发表于 2013-4-7 15:58:10 | 显示全部楼层
I may plan to download, Thanks a lot guys!
GMT+8, 2025-9-17 03:48 , Processed in 0.022291 second(s), 6 queries , Gzip On, Redis On.
