Included are:
- Script to create list of design files which are used by Verdi
list_verdi_source_files.tar.gz
- This script will show the path of `include file using npi commands.
npi_inc_file.tgz
- Dump the design hierarchy tree in plain text format, which canbe post-processed
dmp_hier_tree.tar.gz
dmp_hier_tree_C.tar.gz
- Dump the design hierarchy tree in CSV (Comma Separated Values) format
dmp_hier_csv.tar.gz
dmp_hier_csv_C.tar.gz
- Module/Instance information
Dump the module name of instances
extract_file_info.tar.gz
extract_file_info_C.tar.gz
Print all the module names of the design in plain text format
list_all_modules.tar.gz
list_all_modules_C.tar.gz
Dump the file name and line number for each module in the design withtext format file
dmp_hier_file.tar.gz
dmp_hier_file_C.tar.gz
Dump port and parameter information for each module instance/primitive
npi_for_mixed.tar.gz
npi_for_mixed_C.tar.gz
Find the source file and its line number from the specified instance name
find_source.tar.gz
find_source_C.tar.gz
Find the instance and gate name from the specified regexp
find_instance_name.tar.gz
find_instance_name_C.tar.gz
Trace Driver/Load/Connectivity
npi_sig_2_primitive_inst_conn.htm
npi_sig_2_primitive_inst_conn_dump.htm
get_connect.tar.gz
trace_drv_load_C.tar.gz
Print the information of the constant found from every assignment (includingcontinuous assign and assignment)
get_const_value.tar.gz
get_const_value_C.tar.gz
Report the verilog netlist overview like port count, hierarchical scope count,primitive cell count (not including UDP) for the given scope
get_netlist_overview.tar.gz
get_netlist_overview_C.tar.gz
Print the full name for all registers within the given design
list_all_register.tar.gz
list_all_register_C.tar.gz
Print every net/var (defined as wire, reg and logic) name in dump_all_net.log
dump_all_net.tar.gz
dump_all_net_C.tar.gz
Print all port high connections of the specified instance or all connectedinstances of the specified net.
dump_instance_net.tcl
dump_instance_net_C.tar.gz
Dump the target instance’s port connection status and detect the open pin ifthe port is floating.
dmp_port_conn.tar.gz
Check the connectivity between 2 given signals. This Tcl script uses the NPI L1command and return the answer YES/NO after checking the connectivityrelationship between 2 signals.
npi_L1_check_conn_npi_example.tar.gz
Detect all snake paths for the given target net. This script is written usingthe OLD model, set the environment variable NOVAS_OLD_NPI before executing yourscript if your Verdi version is 2012.01 or later
verdi_api_netlist_api_snakepath.tar.gz
If a user has e systems that are checking the metastability, they need to checkthat both q and d pins are in the VHDL or Verilog path. If d and q are from amixed language then they have to find an equivalent net but in the otherlanguage
Check_Metastable.tar.gz
Design Manipulation VIA Design Manipulation Appsinclude a set of C-APIs/Tcl to let users manipulate their designs and thecorresponding files (SDC/CPF/UPF).
- Chip Integration
- Instance Grouping/Ungrouping
- Drop inactive lines from the entire design according to the macro definition. (Requires a version newer than 2012.01)
- Drop_inactive_line.tar.gz
- nECO does not support creating an empty module with ports. This Perl script creates a module and invokes the nECO command to create a port for it.
- Create_Module.tgz
FSDB investigation
- Use the $fsdbAutoswitchDumpfile dumping command for regression. This script enables running both multiple simulations in parallel (regression) and fsdbAutoSwitchDumpfile. Since multiple simulations need to run in parallel, they cannot have the same base FSDB name; therefore, a unique base file name is generated for each test as all tests dump their files to a single common “dumpdir” directory. Because the base name is different for each test, no naming conflicts exist, so the FSDB files, the log files, and the Virtual File (.vf) files are all there and complete when the regression is done.
- This Tcl/TK script will automatically populate a Watch Window with all signals in the current scope and will update when the scope changes.
- This Tcl/TK script adds a command called ‘Duty Cycle’ to the bottom of the Waveform menu in nWave. After selecting a set of one-bit signals in nWave, placing the cursor and the marker, and then selecting ‘Duty Cycle’, a window will open.
- This set of Tcl scripts takes a normal digital bus and then creates a new Fixed Point Fractional Representation bus. The user can specify signed or unsigned and the size of the integer part (IWL).
- This script creates an alias table in nWave Signal File format from alias extraction output.
- AppliAlias.tar.gz
- This script dumps the total time of each value between the cursor time and marker time.
- ReportDistribution.tar.gz
- This script dumps all signal names and the times where the pulse is smaller than the specified time.
- ReportSmallPulse.tar.gz
- This Tcl script provides the statistics of signal value in specific time period.
- 20111117_nWave_report_toggle_in_range.tar.gz
Debug Automatiion
- Automatically trace all Xs in the FSDB file and print out a text report in batch mode. This script includes 3 parts:
- Step 1. List all Xs from the specified FSDB file.
- Step 2. Trace X for each signal from the result of Step 1.
- Step 3. Generate the report of tracing results of Step 2.
- tracex_10_reset_TCL.tgz
- tracex_10_reset_C.tgz
- This Tcl package will automatically allow the user to load a portion of the design dependent upon the signal selected in the nWave window.
- tcl_createvtop_loaddesign.tar.gz
- This Tcl script allows the user to save any signals selected in nWave to a VCD file. This includes, events, logical operations etc. The default VCD file name is nWave_number.vcd, where number is determined by the Tcl clock function, so no 2 files will have the same name. See below to change the file name.
- save_nWave_signals.tcl_v1.0.tgz
- Display all input port signal waveforms for the selected npiModule cell on nWave Script.
- add_input_signal.tar.gz
- add_input_signal_C.tar.gz
- Tcl script to check the violation of simulator report with the Verdi system.
- violation.tar.gz
Tool interoperating
Simulators - This shell script converts Synopsys DVE signal session *.tcl file to nWave’s signal *.rc file.
- This script translates the do file to nWave’s rc file. The do file contains Cadence Signalscan Waves commands that can be loaded and executed by Signalscan Waves. This translator only extracts the information where the rc file has a corresponding command and translates it to rc file’s syntax.
- This is supposed to help user share information with group using signalscan. It will convert all the signals/groups and zero delay information. The compressed file has the source code and the Linux/Solaris executables.
- This Perl script will convert MTI .do file to ”.rc” file for nWave/Verdi.
- mtido-rc.pl.tgz
- This script converts Cadence cds.lib to Novas novas.rc automatically for library mapping. It supports the nested structure. (Limitation: This utility only works for specifying “ABSOLUTE PATH” , not “RELATIVE PATH” for conversion.)
- nc2novasrc.tar.gz
- This is a new Perl script called virsim2nWave that converts Synopsys virsim *.cfg file to signal.rc for nWave/Verdi.
- virsim2nWave.zip
- The users of Cadence NCsim would be able to compile and run Verdi with minimum set up. After pointing to this Perl script, the user can just use the same script or the same Makefile that is used for running the NC simulator.
- Print the target module information into a wrapper map file.
- create_wrapper_lib.tar.gz
- create_wrapper_lib_C.tar.gz
Formal Tools - Please check following link for the example to Display CLP (Cadence/Encounter Conformal Low Power) report with Power Aware Verdi. (Please import the design and CPF file first before running the Tcl script)
Annotate User-definded Data - Verdi allows you to annotate your own data to the Verdi system so that you can browse the data easily. For example, you can annotate power consumption data from a third party tool and browse the information conveniently in the familiar Verdi environment. Currently, the feature is considered beta.
- User_Defined_Annotation.pdf
36.84 KB, 下载次数: 46
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.5 KB, 下载次数: 31
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.07 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
AppliAlias.tar.gz
1.51 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
Auto_Watchsignals.tar.gz
4.51 MB, 下载次数: 30
, 下载积分:
资产 -3 信元, 下载支出 3 信元
1
Bus2FPFN.tar.gz
9.77 KB, 下载次数: 25
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
2.98 KB, 下载次数: 30
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
CLP2Verdi.tar.gz
319.71 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
Create_Module.tar.gz
1.45 KB, 下载次数: 27
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
2.39 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.69 KB, 下载次数: 23
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dmp_hier_csv.tar.gz
1.68 KB, 下载次数: 32
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.15 KB, 下载次数: 25
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.83 KB, 下载次数: 32
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.48 KB, 下载次数: 29
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.32 KB, 下载次数: 34
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.54 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.41 KB, 下载次数: 26
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
do2rc.tar.gz
13.77 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
57.45 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dump_all_net.tar.gz
6.34 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.79 KB, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dump_instance_net.rar
2.07 KB, 下载次数: 26
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
13.9 KB, 下载次数: 23
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
duty_cycle_v2.tar.gz
2.47 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dve2rc_3.tar.gz
16.76 KB, 下载次数: 23
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.28 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.66 KB, 下载次数: 19
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.63 KB, 下载次数: 32
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.21 KB, 下载次数: 21
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
find_source.tar.gz
523 Bytes, 下载次数: 26
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
10.23 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
get_connect.tar.gz
9.22 KB, 下载次数: 38
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
18.46 KB, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
32 KB, 下载次数: 29
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.63 KB, 下载次数: 26
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
12.09 KB, 下载次数: 25
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.57 KB, 下载次数: 25
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.43 KB, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
13.49 KB, 下载次数: 28
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
mtido-rc.pl.tar.gz
1.29 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
nc2novasrc.tar.gz
6.11 KB, 下载次数: 21
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
Ncscript.tar.gz
101 KB, 下载次数: 25
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
6.86 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
17.64 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
npi_inc_file.tar.gz
3.67 KB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.02 KB, 下载次数: 24
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
npi_sig_2_primitive_inst_conn.rar
5.56 KB, 下载次数: 16
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
npi_sig_2_primitive_inst_conn_dump.rar
5.15 KB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
rc2do_a.tar.gz
21.77 KB, 下载次数: 17
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
57.45 KB, 下载次数: 21
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dump_all_net.tar.gz
6.34 KB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.79 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.83 KB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.29 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
run_nc_autosdf.pl.tar.gz
802 Bytes, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
save_nWave_signals.tcl_v1.0.tar.gz
4.06 KB, 下载次数: 19
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
11.86 KB, 下载次数: 16
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
18.76 KB, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
tracex_10_reset_C.tar.gz
1.43 MB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
tracex_10_reset_TCL.tar.gz
316.47 KB, 下载次数: 19
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
User_Defined_Annotation.rar
155.35 KB, 下载次数: 20
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
52.3 KB, 下载次数: 22
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
violation.tar.gz
20.48 KB, 下载次数: 17
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
virsim2nWave.zip
2.79 KB, 下载次数: 18
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
36.84 KB, 下载次数: 15
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.5 KB, 下载次数: 17
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.07 KB, 下载次数: 12
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
AppliAlias.tar.gz
1.51 KB, 下载次数: 15
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.51 MB, 下载次数: 15
, 下载积分:
资产 -3 信元, 下载支出 3 信元
1
Bus2FPFN.tar.gz
9.77 KB, 下载次数: 16
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
2.98 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
CLP2Verdi.tar.gz
319.71 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.45 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
2.39 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.69 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dmp_hier_csv.tar.gz
1.68 KB, 下载次数: 9
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.15 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.83 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.48 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.32 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.54 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.41 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
do2rc.tar.gz
13.77 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
57.45 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dump_all_net.tar.gz
6.34 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.79 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
13.9 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
2.47 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
dve2rc_3.tar.gz
16.76 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.28 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.66 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.63 KB, 下载次数: 16
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.21 KB, 下载次数: 9
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
find_source.tar.gz
523 Bytes, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
10.23 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
get_connect.tar.gz
9.22 KB, 下载次数: 9
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
18.46 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
32 KB, 下载次数: 4
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
3.63 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
12.09 KB, 下载次数: 9
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.57 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
15.43 KB, 下载次数: 10
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
13.49 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
mtido-rc.pl.tar.gz
1.29 KB, 下载次数: 10
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
nc2novasrc.tar.gz
6.11 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
Ncscript.tar.gz
101 KB, 下载次数: 14
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
6.86 KB, 下载次数: 6
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
17.64 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
npi_inc_file.tar.gz
3.67 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
14.02 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
rc2do_a.tar.gz
21.77 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.83 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.29 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
802 Bytes, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
4.06 KB, 下载次数: 5
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
11.86 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
18.76 KB, 下载次数: 7
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
1.43 MB, 下载次数: 9
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
316.47 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
52.3 KB, 下载次数: 11
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
violation.tar.gz
20.48 KB, 下载次数: 8
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
virsim2nWave.zip
2.79 KB, 下载次数: 15
, 下载积分:
资产 -2 信元, 下载支出 2 信元
1
