楼主: layes
Level Shifters for High-Speed 1-V to 3.3-V Interfaces
发表于 2010-7-16 20:40:39 | 显示全部楼层
good ..thx
发表于 2010-7-16 21:30:06 | 显示全部楼层
thanks
发表于 2010-8-4 11:17:16 | 显示全部楼层
正需要呢,谢谢
发表于 2010-8-4 16:41:56 | 显示全部楼层
很好的資料,感謝大大無私的分享
很好的資料,感謝大大無私的分享
发表于 2010-8-10 16:52:19 | 显示全部楼层
thanks for sharing
发表于 2010-8-10 22:43:03 | 显示全部楼层
thanks
发表于 2010-8-11 04:25:40 | 显示全部楼层
thanks
发表于 2010-8-11 07:05:48 | 显示全部楼层
thanks for sharing
发表于 2010-8-11 13:45:14 | 显示全部楼层
谢谢!!!
发表于 2010-10-2 20:48:48 | 显示全部楼层
Level shifters for 1.0-V to 3.3-V high-speed interfaces are
proposed. Level-up shifter uses zero-Vt 3.3-V NMOSs as
voltage clamps to protect 1.0-V NMOS switches from high
voltage stress across the gate oxide. Level-down shifter uses
3.3-V NMOSs as both pull-up and pull-down devices with
supply voltage of 1.0-V and gate voltage swing from 0-V to
3.3-V. The zero-Vt NMOS is a standard MOSFET device in a
0.13-μm CMOS process without adding extra mask or process
step to realize it. Level-up transition from 0.9-V to 3.6-V takes
only 1 ns in time, and the level-down transition has no
minimum core voltage limitation. These circuits do not
consume static DC power, therefore they are very suitable for
low-power and high-speed interfaces in the deep sub-quartermicron
CMOS technologies.
GMT+8, 2025-12-30 14:14 , Processed in 0.017514 second(s), 3 queries , Gzip On, Redis On.
