我是根据论坛大大的帖子安装的,完全一步一步仔细研究了
http://bbs.eetop.cn/viewthread.php?tid=311773&highlight=Calibre
小弟可以启动caliber但是license方面出了问题
首先我运行lmim1的时候没有问题
但是运行lmlim2的时候问题如下
[tea@localhost ~]$ lmlim2
lmstat - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
Flexible License Manager status on Sat 12/1/2012 19:46
License server status: 1818@localhost.localdomain
License file(s) on localhost.localdomain: /home/tea/calibre/lic/license.dat:
localhost.localdomain: license server UP (MASTER) v11.6
Vendor daemon status (on localhost.localdomain):
mgcld: UP v11.6
[tea@localhost ~]$ 19:46:28 (lmgrd) -------------------------------------------- ---
19:46:28 (lmgrd) Please Note:
19:46:28 (lmgrd)
19:46:28 (lmgrd) This log is intended for debug purposes only.
19:46:28 (lmgrd) In order to capture accurate license
19:46:28 (lmgrd) usage data into an organized repository,
19:46:28 (lmgrd) please enable report logging. Use Acresso Software Inc.'s
19:46:28 (lmgrd) software license administration solution,
19:46:28 (lmgrd) FLEXnet Manager, to readily gain visibility
19:46:28 (lmgrd) into license usage data and to create
19:46:28 (lmgrd) insightful reports on critical information like
19:46:28 (lmgrd) license availability and usage. FLEXnet Manager
19:46:28 (lmgrd) can be fully automated to run these reports on
19:46:28 (lmgrd) schedule and can be used to track license
19:46:28 (lmgrd) servers and usage across a heterogeneous
19:46:28 (lmgrd) network of servers including Windows NT, Linux
19:46:28 (lmgrd) and UNIX. Contact Acresso Software Inc. at
19:46:28 (lmgrd) www.acresso.com for more details on how to
19:46:28 (lmgrd) obtain an evaluation copy of FLEXnet Manager
19:46:28 (lmgrd) for your enterprise.
19:46:28 (lmgrd)
19:46:28 (lmgrd) -----------------------------------------------
19:46:28 (lmgrd)
19:46:28 (lmgrd)
19:46:28 (lmgrd) The TCP port number in the license, 1818, is already in use.
19:46:28 (lmgrd) Possible causes:
19:46:28 (lmgrd) 1) The license server manager (lmgrd) is already running for this license.
19:46:28 (lmgrd) 2) The OS has not "cleared" this port since lmgrd died.
19:46:28 (lmgrd) 3) Another process is using this port number (unlikely).
19:46:28 (lmgrd) Solutions:
19:46:28 (lmgrd) 1) Make sure lmgrd and all vendor daemons for this
19:46:28 (lmgrd) license are not running.
19:46:28 (lmgrd) 2) You may have to wait for the OS to clear this port.
19:46:28 (lmgrd) Retrying for about 5 more minutes
[tea@localhost ~]$ 19:46:46 (lmgrd) Still trying...
[tea@localhost ~]$ 19:47:04 (lmgrd) Still trying...
19:47:22 (lmgrd) Still trying...
19:47:40 (lmgrd) Still trying...
19:47:58 (lmgrd) Still trying...
19:48:16 (lmgrd) Still trying...
19:48:34 (lmgrd) Still trying...
19:48:52 (lmgrd) Still trying...
19:49:10 (lmgrd) Still trying...
19:49:28 (lmgrd) Still trying...
19:49:46 (lmgrd) Still trying...
19:50:01 (lmgrd) Failed to open the TCP port number in the license. |
