查看: 6819|回复: 7
小弟在cadence中运行smic13mmrf仿真时候报错,希望大家帮助
发表于 2012-11-30 19:43:10 | 显示全部楼层 |阅读模式
Fatal error found by spectre during AHDL read-in.
    FATAL (VACOMP-2096): File '/home/tea/cadence/IC6151/smic13mmrf_1225/models/spectre/res_rf.def' does not appear to be a valid Verilog-A file. In previous releases, '.def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this file is a SpectreHDL file, you need to replace it with an equivalent Verilog-A file.
谢谢各位帮忙啦
发表于 2013-8-8 11:51:42 | 显示全部楼层
同求!!
发表于 2013-8-9 09:53:18 | 显示全部楼层
回复 1# duofahappy
   同求
发表于 2016-3-23 15:52:33 | 显示全部楼层
回复 1# duofahappy
   I have the same problem. Did you solve the problem.
Thanks.
发表于 2022-11-13 12:41:40 | 显示全部楼层
同问
发表于 2022-11-17 11:30:14 | 显示全部楼层
谢谢分享。
发表于 2023-5-10 18:32:36 | 显示全部楼层
同求
发表于 2023-10-23 20:43:53 | 显示全部楼层
同问,感谢
GMT+8, 2025-12-13 13:34 , Processed in 0.031051 second(s), 6 queries , Gzip On, Redis On.
