查看: 8657|回复: 18
[资料] Linux 101 Hacks 与 Sed and Awk 101 Hacks
发表于 2012-11-24 15:28:21 | 显示全部楼层 |阅读模式
101 Hacks.rar (4.94 MB , 下载次数: 343 )
包括下面2本书(pdf格式)。部分目录内容如下:
Linux 101 hacks:
Chapter 1: Powerful CD Command Hacks ......................... 9
Hack 1. Use CDPATH to define the base directory for cd command ...9
Hack 2. Use cd alias to navigate up the directory effectively ......... 10
Hack 3. Perform mkdir and cd using a single command ................ 13
Hack 4. Use “cd -” to toggle between the last two directories ....... 14
Hack 5. Use dirs, pushd and popd to manipulate directory stack..... 14
Hack 6. Use “shopt -s cdspell” to automatically correct mistyped
directory names on cd ......................................................... 17
Sed and Awk 101 Hacks:
Chapter 1: Sed Syntax and Basic Commands                   .........    9
1. Sed Command Syntax          ..............................................    10
2. Sed Scripting Flow            ..................................................    12
3. Print Pattern Space (p command)            .............................    13
4. Delete Lines (d command)                 ..................................    17
5. Write Pattern Space to File (w command)             .................    19
发表于 2016-11-1 16:34:41 | 显示全部楼层
好东西
发表于 2017-5-21 17:18:26 | 显示全部楼层
谢谢楼主分享~
发表于 2017-12-4 15:13:24 | 显示全部楼层
Thanks a lot
发表于 2017-12-17 21:51:12 | 显示全部楼层
謝謝分享
发表于 2018-1-7 12:54:57 | 显示全部楼层
Thank you
发表于 2018-1-9 06:56:06 | 显示全部楼层
謝謝分享
发表于 2018-1-9 08:47:12 | 显示全部楼层
挺好的书
发表于 2018-4-21 01:23:01 | 显示全部楼层
thanks
发表于 2018-7-6 16:46:39 | 显示全部楼层
It is useful to me and thanks.
GMT+8, 2025-11-30 21:30 , Processed in 0.029998 second(s), 7 queries , Gzip On, Redis On.
