查看: 13474|回复: 29
【悬赏】下载了深度破解版verdi2011,但是就是不能使用,悬赏求帮助
发表于 2012-11-22 16:07:43 | 显示全部楼层 |阅读模式
悬赏100资产已解决
:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L:L
我花了两百多银子在:http://bbs.eetop.cn/viewthread.php?tid=346889&extra=&page=2
下载了crossbowjkf 大侠的verdi2011,
按照帖子后续说明进行操作,
解压缩后确实1.3G,放到了/usr/synopsys/目录下,
直接在任意路径下打开控制台输入命令:   set path = /usr/synopsys/verdi/bin $path;
然后输入:verdi,回车,提示如下错误:
/usr/synopsys/verdi/bin/verdi:line 10:dirname:command not found
/usr/synopsys/verdi/bin/verdi:line 14:dirname:command not found
/usr/synopsys/verdi/bin/verdi:line 331:/platform/LINUX/bin/Novas :no such file or directory
/usr/synopsys/verdi/bin/verdi:line 331:exec /platform/LINUX/bin/Novas :cannot execute no such file or directory
此前前还下载了另外一个达人bestwonbin 的软件:http://bbs.eetop.cn/viewthread.php?tid=304428&highlight=verdi
,感觉和这个一样,他的需要手动拷贝:sfk和patch_novas201101到安装目录的platform/LINUX/bin文件夹下面,执行patch_novas201101,
但是提示cp和chmod两个命令无效,
继续设置环境变量,在etc/profile中增加如下语句:
export NOVAS_INST=/usr/synopsys/Verdi201101
export PATH=$NOVAS_INST/bin:/PATH
export LD_LIBRARY_PATH=$NOVAS_INST/share/PLI/ius6.1_vhpi/LINUX:/NOVAS_INST/share/PLI/IUS/LINUX:/LD_LIBRARY_PATH
然后据他的帖子描述敲verdi应该就可以用了,
但是我操作后提示错误和上面的一样:
/usr/synopsys/verdi201101/bin/verdi:line 10:dirname:command not found
/usr/synopsys/verdi201101/bin/verdi:line 14:dirname:command not found
/usr/synopsys/verdi201101/bin/verdi:line 331:/platform/LINUX/bin/Novas :no such file or directory
/usr/synopsys/verdi201101/bin/verdi:line 331:exec /platform/LINUX/bin/Novas :cannot execute no such file or directory
请大家帮忙指导一下好吗,非常感谢!
:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake:handshake
最佳答案
查看完整内容
export PATH=$NOVAS_INST/bin:/PATH export LD_LIBRARY_PATH=$NOVAS_INST/share/PLI/ius6.1_vhpi/LINUX:/NOVAS_INST/share/PLI/IUS/LINUX:/LD_LIBRARY_PATH 感觉有问题,:后面应该是$,怎么在你这变成了斜杠/ 还有,楼主你能说明一下你这两个有什么区别吗? /ussr与/usr 我看到你发出来的都是/ussr,貌似我没见过这个目录 你设置的是set path = /usr/synopsys/verdi/bin $path 但是错误却是/ussr ...
发表于 2012-11-22 16:07:44 | 显示全部楼层
/ussr与/usr
但是错误却是/ussr
发表于 2012-11-22 16:26:34 | 显示全部楼层
after you have modified your Cshell or bash, you should reboot or relogin! add all the needed path in!
 楼主| 发表于 2012-11-22 17:24:23 | 显示全部楼层
就是重启一下吗?我现在重启试试,搞定的话钱是你的了
发表于 2012-11-22 19:09:51 | 显示全部楼层
如果你用cshell:试一下:
> set path = ( /usr/synopsys/verdi/platform/LINUX/bin /usr/synopsys/verdi/bin $path );
> cd your_path
> Novas
发表于 2012-11-22 21:28:47 | 显示全部楼层
换csh或者TCSH
dirname是个命令,你安装一下
发表于 2012-11-22 21:54:37 | 显示全部楼层
brute-force crack is not a good idea, in fact, you can implement it  by the correct lic.
 楼主| 发表于 2012-11-23 11:20:59 | 显示全部楼层
after you have modified your Cshell or bash, you should reboot or relogin! add all the needed path i ...
飞扬紫百合 发表于 2012-11-22 16:26
老大,我重启了服务器,结果无法登录系统了,输入root权限用户名和密码后提示如下错误提示:
could not connect to session bus:
failed to execute dbus-launch to autolaunch D-Bus session
点击确定后弹出如下错误提示:
could not acquire name on session bus
我的系统是SUSE11 64位的,
启动过程有三个选项:
1、默认
2、failsafe-默认
3、xen-默认
三个我分别选择了,结果提示错误一样,
我是新手,刚刚接触linux,请大侠帮助解决下,多谢
 楼主| 发表于 2012-11-23 11:25:23 | 显示全部楼层
export LD_LIBRARY_PATH=$NOVAS_INST/share/PLI/ius6.1_vhpi/LINUX:/N ...
lsqswl 发表于 2012-11-22 17:32
ussr是笔误,提示的是usr,
/和$的问题我不了解,
就是按照下载文件的提示做的,
不过系统重启后无法登录了,
等好了以后可以更改过来试一下,
多谢
 楼主| 发表于 2012-11-23 11:27:06 | 显示全部楼层
如果你用cshell:试一下:
> set path = ( /usr/synopsys/verdi/platform/LINUX/bin /usr/synopsys/verdi/b ...
thelastone 发表于 2012-11-22 19:09
好的,系统好了以后我试一下,多谢
GMT+8, 2025-12-29 22:42 , Processed in 0.029964 second(s), 6 queries , Gzip On, Redis On.
