查看: 11856|回复: 44
A high-swing MOS cascode bias circuit for operation
发表于 2006-12-22 08:03:13 | 显示全部楼层 |阅读模式
A high-swing MOS cascode bias circuit for operation at any current level 工作在饱和区的边缘
abbr_S cascode bias circuit for operation at any current level 工作在饱和区的边缘.pdf
305.09 KB, 下载次数: 285 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-12-22 10:29:58 | 显示全部楼层
reeeeee
发表于 2007-1-2 16:56:35 | 显示全部楼层
发表于 2007-1-2 16:57:23 | 显示全部楼层
发表于 2007-1-14 16:52:18 | 显示全部楼层
hao..
发表于 2007-1-14 17:04:00 | 显示全部楼层
下了就顶.个人原则
发表于 2007-1-14 18:19:51 | 显示全部楼层
发表于 2007-1-15 02:57:21 | 显示全部楼层
wan to learn how to calculate the small signal
发表于 2007-1-15 09:32:46 | 显示全部楼层
ABSTRACT
ABSTRACT
In this paper, we propose a very simple bias circuit that allows for
maximum output voltage swing of MOSFET cascode stages. The
proposal is valid for any current density and is technology-
independent. Starting from the saturation voltage and from the
current density of the cascode stage we determine the aspect ratio
of the transistors in the bias circuit in order to maximize the output
voltage ~ swing. Experimental results validate the strategy for
designing the bias network.
发表于 2007-1-15 09:35:04 | 显示全部楼层
CONCLUSIONS
6. CONCLUSIONS
A very simple bias circuit, valid for any current density, which
allows for maximum output voltage swing of cascode stages has
been presented and analyzed. Starting from the multiplication
factor of the output impedance required for the cascode stage
relative to the single stage and from the output swing it is possible
to determine the “optimally” biased network. Experimental results
corroborated the design methodology .of the bias network. The
biasing circuit is very useful for low-voltage design
GMT+8, 2025-12-26 01:36 , Processed in 0.025285 second(s), 6 queries , Gzip On, Redis On.
