查看: 2017|回复: 9
HDL.Works.HDL.Companion.v2.5.R3.for.Linux-BEAN
发表于 2012-11-19 14:37:27 | 显示全部楼层 |阅读模式
HDL Companion is the HDL designer's Swiss army knife. It will help you to get and keep a good overview of any HDL design, including third party IP, legacy code and other HDL sources. Complete design directories and design files are dragged into HDL Companion and a complete design overview is created in seconds, uncovering information regarding numerous aspects of the design. The GUI offers many ways to navigate through the design and explore the details you're looking for.
The embedded fuzzy parsers accept any Verilog, VHDL or mixed HDL design code; even if the code is incomplete or contains errors. Syntactically correct HDL can also be linted to find problems not reported by the compilers.
HDL Companion has a unique setup of three main windows and a console window, which together offer a complete overview of your design, from high level structure to the details in the source code. The excellent navigation capabilities, including signal tracing, offer you an easy way to find an object and show its details.
The Console Window shows all syntax errors and warnings, which can easily be located in the HDL source using hot links from the Console Window to the Scriptum Window. The Console Window also functions as a Tcl interpreter, where any Tcl script or shell command can be executed.
Other features include a language sensitive text editor, revision control and interfaces to all major simulation and synthesis tools.
For more details. please see:
  1. http://www.hdlworks.com/products/companion/index.html
    复制代码
UnRAR code/password:
  1. eetop.cn
    复制代码
Please verify your download files file first against the MD5 checksums listed below:
  1. HDL.Works.HDL.Companion.v2.5.R3.for.Linux-BEAN.part1.rar  a92728d78e7ab0d763f8a7a5fb405a31
  2. HDL.Works.HDL.Companion.v2.5.R3.for.Linux-BEAN.part2.rar  1eb1a0bdd0d7ac7950042115fa2235bd
  3. HDL.Works.HDL.Companion.v2.5.R3.for.Linux-BEAN.part3.rar  10f58384d2a507f42d9492517b7efc6c
    复制代码
15 MB, 下载次数: 30 , 下载积分: 资产 -5 信元, 下载支出 5 信元
15 MB, 下载次数: 29 , 下载积分: 资产 -5 信元, 下载支出 5 信元
7.12 MB, 下载次数: 29 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2012-11-19 20:59:31 | 显示全部楼层
有windows版本的吗
 楼主| 发表于 2012-11-20 08:57:43 | 显示全部楼层
发表于 2012-11-20 09:29:33 | 显示全部楼层
does it something like HDL Writer?
 楼主| 发表于 2012-11-20 14:34:04 | 显示全部楼层
alexbaby 发表于 2012-11-20 09:29
Much more than that BUT no HDL simulators...... You need to find one.
HDL Companion Features:
  • Global view
  • Detailed view
  • Hierarchical view
  • Signal tracing
  • Search and replace
  • Linting
  • HTML generation
  • IP integration
  • HDL editor
  • Integration with other EDA Tools
发表于 2012-11-22 06:39:07 | 显示全部楼层
crack ?
 楼主| 发表于 2012-11-22 15:35:02 | 显示全部楼层
Cracked executable included!  Read the .nfo carefully.
发表于 2016-2-26 22:13:50 | 显示全部楼层
发表于 2016-2-26 22:19:14 | 显示全部楼层
发表于 2016-2-26 22:20:40 | 显示全部楼层
GMT+8, 2025-12-23 09:44 , Processed in 0.023548 second(s), 7 queries , Gzip On, Redis On.
