查看: 5103|回复: 4
[求助] encounter PR中SI timing 分析问题
发表于 2012-11-14 02:15:25 | 显示全部楼层 |阅读模式
悬赏100资产未解决
timeDesign -signoff \
                -numPaths  50 \
               -slackReports
               -outDir   "  "
ERROR (EXTSNZ-127) : The layer name "VIA12" is used in the LEF/DEF file or in the OpenAccess
(OA) database but the definition for it cannot be found in the tech file.
Ensure that the command file has a proper name mapping for the tech file
layer to corresponding names in LEF/cellLibrary/DEF/OA. Refer to the user
manual for command syntax.
产生的qrcTechFile
是Techgen  .ict文件是产生,
问题?
 楼主| 发表于 2012-11-16 00:16:26 | 显示全部楼层
需要一个.map文件,作为item映射,这个map文件怎么写?
是基于CCL script的
 楼主| 发表于 2012-11-16 00:22:59 | 显示全部楼层
以下map文件问题在哪?
extraction_setup \
-technology_layer_map \
#<Tech File Name>  #<LEF/DEF Name>
-metal1 METAL1 \
-via1 VIA12 \
-metal2  METAL2 \
-via2   VIA23 \
-metal3  METAL3 \
-via3   VIA34  \
-metal4  METAL4 \
-via4   VIA45 \
-metal5  METAL5 \
-via5   VIA56 \
-metal6  METAL6 \
-via6   VIA67 \
-metal7  METAL7 \
-via7   VIA78 \
-metal8  METAL8
发表于 2012-11-16 02:12:15 | 显示全部楼层
回复 3# Andreatong
    你试试看这这么写map文件:
layer M1 icecaps Metal1
layer M2 icecaps Metal2
layer POLY1 icecaps Poly
layer VIA12 icecaps Via1
layer VIA23 icecaps Via2
 楼主| 发表于 2012-11-17 23:16:53 | 显示全部楼层
thanks
GMT+8, 2025-12-17 02:07 , Processed in 0.018495 second(s), 7 queries , Gzip On, Redis On.
