发表于 2012-11-10 00:22:14
显示全部楼层
report_clock_timing
-type [skew | interclock_skew | jitter | summary | latency
[ [-launch | -capture]
[-rise | -fall]
| [-histogram [-histogram_range interval size ]]
[-logic_level [-source {clock_root | generated_clock}]]
[-early | -late]
[-clock clock_list ]
[-from_clock from_clock_list ]
[-to_clock to_clock_list ]
[-from from_list ]
[-to to_list ]
[-nworst worst_entries ]
[-greater_than lower_limit ]
[-view view_name ]
[-verbose]
[-format column_list ]
[-tcl_list]
[{> | >>} filename ]
Generates a clock skew report for the current design. The software generates a separate report for each specified clock or pair of clocks. You specify the clocks using the -clock parameter, and clock pairs using the -from_clock and -to_clock parameters. You can use the - nworst and -greater_than parameters with the -from_clock and - to_clock parameters to generate reports with skew to the specified sink pins. You can use the - early and -late parameters to specify the type of skew to be reported.
Note: To remove common path pessimism from the reported skew, use the setAnalysisMode -cppr both command before using the report_clock_timing command. The report contains a separate column for common path adjustment values.
You can use the report_clock_timing command to perform MMMC based SSTA analysis. In MMMC mode, the command reports the latency and clock skew for all individual views. You can use the report_clock_timing -view parameter to report clock timing for a user-specified view. |
