查看: 1819|回复: 0
[原创] MFRC522单片机技术资料分享
发表于 2012-11-7 16:32:27 | 显示全部楼层 |阅读模式
 Features
  · Highly integrated analog circuitry to demodulate and decode responses
  · Buffered output drivers to connect an antenna with minimum number of external components
  · Supports ISO/IEC 14443A / MIFARE(R)
  · Typical operating distance in Reader/Writer mode for communication to a ISO/IEC 14443A / MIFARE(R) up to 50 mm depending on the antenna size and tuning
  · Supports MIFARE(R) Classic encryption in Reader/Writer mode
  · Supports ISO/IEC 14443A higher transfer speed communication up to 848 kbit/s
  · Support of the MFIN / MFOUT
  · Additional power supply to directly supply the smart card IC connected via MFIN / MFOUT
  · Supported host interfaces
  - SPI interface up to 10 Mbit/s
  - I2C interface up to 400 kbit/s in Fast mode, up to 3400 kbit/s in High-speed mode
  - serial UART in different transfer speeds up to 1228.8 kbit/s, framing according to the RS232 interface with voltage levels according pad voltage supply
  · Comfortable 64 byte send and receive FIFO-buffer
  · Flexible interrupt modes
  · Hard reset with low power function
  · Power-down mode per software
  · Programmable timer
  · Internal oscillator to connect 27.12 MHz quartz
  · 2.5 - 3.3 V power supply
  · CRC Co-processor
  · Free programmable I/O pins
  · Internal self test本资料由www.xpjm.net整理提供,仅供参考。
GMT+8, 2025-9-13 04:26 , Processed in 0.015338 second(s), 8 queries , Gzip On, Redis On.
