查看: 19119|回复: 57
CST 2012 SP6更新说明
发表于 2012-10-14 23:25:37 | 显示全部楼层 |阅读模式
CST 2012 SP6已经在9月29日发布,更新如下:
Service Pack 2012.06
General / Environment / Visualization
Made field plot phase animation more consistent.
Improved stability when editing transformed objects.
GPU Computing
Added support for NVIDIA Quadro 6000.
Added 297.03 and 295.73 to the list of verified NVIDIA drivers.
CST MICROWAVE STUDIO - Transient Solver
Corrected inconsistent behavior of magnetic conductivity defined together with a dispersive epsilon material.
Fixed issue during adaptive port mesh refinement in combination with magnetic higher order dispersive materials.
Corrected time measurement for adaptive port mesh refinement.
Fixed online AR-Filters early convergence for excitations on multiple modes.
CST MICROWAVE STUDIO - Frequency Domain (FD) Solvers
With inhomogeneous single ended ports and many samples, the general purpose tetrahedral FD solver sometimes terminated abnormally.
Calculate fields at axis marker now uses the fast resonant solver with Run after adaptive mesh refinement if applicable activated.
The frequency domain solver with curved tetrahedral mesh and waveguide ports rarely may have displayed an error message concerning periodic ports not being supported even without periodic boundaries.
With frequency distributed computing or a continued solver run, and curved model edges in the waveguide ports, the general purpose tetrahedral FD solver using the new port mode solver possibly had calculated inaccurate results.
CST MICROWAVE STUDIO - Asymptotic Solver
Fixed numerical comparison problem with farfield sources for asymptotic solver.
Repaired incorrect scaling of field sources (wrong directivity if amplitude != 1).
CST PCB STUDIO
2DTL: Ground pins are excluded from top circuit, now. Performance has been increased concerning solder mask approximation.
Fixed incorrect layout check result.
On some boards the route between power supply and some IO-pins could not be found in IRDrop simulation.
Now always the original terminal name is used in the 3D Mesh.
CST DESIGN STUDIO
Fixed manual synchronization of 3D and schematic parameters via VBA or block dialog box.
Improved the keyboard navigation in the excitation list in AC- and OP Task dialog boxes by using of TAB and
ENTER Keys.
Repaired scaling of imported ASCII signals in transient tasks.
Result template Voltage drop from Z-parameter: fixed interpretation of input data.
Avoided to initialize unnecessary extra storage for DS blocks.
有需要的可以留言,然后我上传论坛。
 楼主| 发表于 2012-10-14 23:48:37 | 显示全部楼层
下面是SP6的补丁文件,需要的话请自行下载。 CST_STUDIO_SUITE_2012_SP6.part01.rar (14.5 MB , 下载次数: 372 )
CST_STUDIO_SUITE_2012_SP6.part02.rar (14.5 MB , 下载次数: 311 )
CST_STUDIO_SUITE_2012_SP6.part03.rar (14.5 MB , 下载次数: 222 )
CST_STUDIO_SUITE_2012_SP6.part04.rar (14.5 MB , 下载次数: 303 )
CST_STUDIO_SUITE_2012_SP6.part05.rar (14.5 MB , 下载次数: 193 )
CST_STUDIO_SUITE_2012_SP6.part06.rar (14.5 MB , 下载次数: 188 )
CST_STUDIO_SUITE_2012_SP6.part07.rar (14.5 MB , 下载次数: 181 )
CST_STUDIO_SUITE_2012_SP6.part08.rar (14.5 MB , 下载次数: 196 )
CST_STUDIO_SUITE_2012_SP6.part09.rar (14.5 MB , 下载次数: 186 )
CST_STUDIO_SUITE_2012_SP6.part10.rar (14.5 MB , 下载次数: 175 )
CST_STUDIO_SUITE_2012_SP6.part11.rar (14.5 MB , 下载次数: 175 )
CST_STUDIO_SUITE_2012_SP6.part12.rar (14.5 MB , 下载次数: 201 )
CST_STUDIO_SUITE_2012_SP6.part13.rar (14.5 MB , 下载次数: 182 )
CST_STUDIO_SUITE_2012_SP6.part14.rar (14.5 MB , 下载次数: 172 )
CST_STUDIO_SUITE_2012_SP6.part15.rar (14.5 MB , 下载次数: 181 )
CST_STUDIO_SUITE_2012_SP6.part16.rar (14.5 MB , 下载次数: 185 )
CST_STUDIO_SUITE_2012_SP6.part17.rar (7.54 MB , 下载次数: 165 )
发表于 2012-10-15 11:23:13 | 显示全部楼层
每个补丁都是200多兆,装的时候临时文件15GB !
 楼主| 发表于 2012-10-15 23:11:10 | 显示全部楼层
如果大家觉得cst安装以后太占空间,可以把cst安装目录下的patchs和两个以linux开头的文件夹里面的文件全部删除,可以接受接近10G的空间。删除后唯一的影响就是不能卸载sp补丁。
发表于 2012-10-16 08:41:15 | 显示全部楼层
sp补丁怎么卸载?
 楼主| 发表于 2012-10-17 20:19:27 | 显示全部楼层
可以在CST software update manager中卸载!
发表于 2012-10-24 13:43:19 | 显示全部楼层
Good Job , Thanks for sharing , but iust installed SP5
发表于 2012-10-25 20:33:05 | 显示全部楼层
感觉2012不如2011好用,启动慢.
发表于 2012-10-26 23:28:39 | 显示全部楼层
更新太快了吧
发表于 2012-11-1 15:22:27 | 显示全部楼层
stack processor 6 is sp6
GMT+8, 2025-12-17 08:05 , Processed in 0.020401 second(s), 4 queries , Gzip On, Redis On.
