查看: 1885|回复: 0
[求助] when i use IES catch the problem
发表于 2012-9-29 11:42:56 | 显示全部楼层 |阅读模式
when i use IES to post-simulation,i meet with the problem as below:
ncelab : *W,FLFEXS: Expected string but found name "abc_top_max.sdf.X" in SDF annotation command file  /a/b/c/sdf.cmd, line 1,trying to continue.
ncealb: *W,FLFFNF:Compiled SDF file (abc_top_max.sdf.X) not found,specified in SDF annotation command file /a/b/c/sdf.cmd, line 3.
so.the annotation is failed.
Surely,I check my sdf.cmd,the format is the same as the cdnshelp description.
thanks.
GMT+8, 2025-12-25 03:02 , Processed in 0.022879 second(s), 6 queries , Gzip On, Redis On.
