查看: 9072|回复: 8
vcs启动问题
发表于 2006-12-16 22:40:43 | 显示全部楼层 |阅读模式
装了linux vcs 7.1.1版本的,在运行时出现如下信息,不知道是什么原因,请大侠指教,多谢!
[service@localhost]:-] vcs -RI fir_check.v fir_test.v fir1.v
*** Using c compiler gcc instead of cc ...
???????????????????????? Chronologic VCS (TM)
????????????? Version 7.1.1 -- Fri Dec 15 19:31:04 2006
?????????????? Copyright (c) 1991-2003 by Synopsys Inc.
???????????????????????? ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
***** Warning: ACC/CLI capabilities have been enabled for the entire design.
????? For faster performance enable module specific capability in pli.tab file
Parsing design file 'fir_check.v'
Parsing design file 'fir_test.v'
Parsing design file 'fir1.v'
Top Level Modules:
?????? fir_test
TimeScale is 1 ns / 1 ns
Starting vcs inline pass...
1 module and 0 UDP read.
recompiling module fir_test
if [ -x ../simv ]; then chmod -x ../simv; fi
gcc??-o ../simv? 5NrI_d.o 5NrIB_d.o J4Qq_1_d.o SIM_l.o??/EDA/synopsys/vcs7.1.1/gui/virsim/linux/vcdplus/vcs7_1_0_1/libvirsim.a????/EDA/synopsys/vcs7.1.1/linux/lib/libvcsnew.a???? -ldl -lm? -lc -ldl
make: gcc: Command not found
make: *** [product_timestamp] Error 127
Make exited with status 2
CPU time: .710 seconds to compile + .150 seconds to link
发表于 2006-12-18 12:39:56 | 显示全部楼层
没用过vcs,不过这应该是gcc没能正确找到吧,只需在你的path中加入gcc的路径就可以了。
发表于 2007-1-15 02:00:20 | 显示全部楼层
i also got use the software for synopsys, very nice if i got one
发表于 2007-1-15 03:34:55 | 显示全部楼层
vcs
Hello,
Can you tell me if you have license for vcs 7.11?
If yes, could you please email it to me, Thanks....
my email is ardenmann@yahoo.com
发表于 2007-4-17 16:19:06 | 显示全部楼层
需要安装GCC
从网上google装上就可以了
发表于 2009-3-22 23:44:50 | 显示全部楼层
真麻烦,好难搞呀
发表于 2010-1-23 23:14:39 | 显示全部楼层
发表于 2012-12-20 14:48:25 | 显示全部楼层
装个libsted 和gcc-c++ rpm包就好了
发表于 2014-8-10 17:17:06 | 显示全部楼层
GMT+8, 2025-12-21 04:29 , Processed in 0.021653 second(s), 7 queries , Gzip On, Redis On.
