查看: 8845|回复: 28
[招聘] 国内中科院控股的微电子公司在上海招CAD engineer
发表于 2012-9-12 10:37:49 | 显示全部楼层 |阅读模式
国内一家中科院控股的微电子公司 主要做power方向的anolog IC design 研发实力雄厚 目前招CAD engineer 具体职责与内容如下:
Description:
As CAD Engineer you will provide application support for our Analog and PowerManagement IC Design simulation and verification flow.
General Responsibilities:
1.Collaborate with     design teams to define simulation and verification strategies for Analog     and Power Management IC design projects.
  • 2.Create methods     deemed to close verification gaps.
  • 3.Explain/define     design flow requirements to internal developers and/or external EDA     vendors.
  • 4.Write scripts to     customize/automate design flows with Perl, Cadence SKILL, Tcl, Shell and     “Make”.
  • 5.Create means deemed     to speed up the Analog and Mixed Signal simulation effort.
  • 6.Create web based     documentation and FAQs.
  • 7.Debug tool/flow     issues and prepare test cases within a Configuration Managed (CM) IC     Design environment.
More Details:
1.Gather     and consolidate Tool/Designkit/Environment needs for design groups.
  • 2.Strive     to overcome EDA problems.
  • 3.Drive     for results to get requirements implemented.
  • 4.Implement     incoming/outgoing compliance checks.
  • 5.Update     projects to use the newest Designkit version.
  • 6.Document     requirements and Lessons Learned.
  • 7.Organize     training and EDA vendor presentations.
Qualification
  • 1.Degree     in electrical engineering or similar.
    5+ years relevant working experiencewith Bachelor Degree;
       3+years relevant working experience with Master Degree;
  • 2.Professional     experience in tool specific languages (Cadence     SKILL, TCL)
  • 3.Ability     to effectively multi-task and manage time across multiple simultaneous     assignments.
  • 4.Candidate     must demonstrate a detailed understanding of     analog circuit simulation, mixed-signal and fast-spice simulation.
  • 5.Experience     with the Cadence software suite and DesignSync would be very useful.
  • 6.Strong     communication skills.
  • 对这个职位有意向的 可以将简历发送到sophie.zhu@allways-consulting.com
发表于 2012-9-12 11:06:21 | 显示全部楼层
请问一下是哪个研究所控股的?谢谢
 楼主| 发表于 2012-9-12 17:38:25 | 显示全部楼层
回复 2# whxijinping
你好 方便的话咱们邮箱联系吧 论坛里不方便透露客户信息 见谅~
发表于 2012-9-12 17:40:11 | 显示全部楼层
得好好学习CAD
 楼主| 发表于 2012-9-14 10:15:10 | 显示全部楼层
回复 4# 1187559767
对职位有兴趣或者有合适的朋友麻烦帮我推荐下~ 谢谢
 楼主| 发表于 2012-9-17 09:44:54 | 显示全部楼层
都没有做CAD的人么……
发表于 2012-9-17 10:02:42 | 显示全部楼层
中科院这个牌子在工业界不怎么吃香,所以有一定的难度
 楼主| 发表于 2012-9-17 11:04:39 | 显示全部楼层
回复 7# whxijinping
唉 其实中科院控股只是想说明这虽然是个小公司 但资金还是比较雄厚 有保障的 拿到的项目也是比较好的 真正做事的人都是从知名的外资公司过去的 跟中科院没啥关系呀……
 楼主| 发表于 2012-9-18 17:49:29 | 显示全部楼层
顶顶顶~~
发表于 2012-9-18 17:57:49 | 显示全部楼层
其实做cad的很少的,特别是做analog/rf相关的cad,做的深点的就更少了,因为一个大的ic设计公司里面也就为数不多一些人,我知道这些,因为我就是干这个的,帮你顶下。
GMT+8, 2025-12-30 17:43 , Processed in 0.023436 second(s), 5 queries , Gzip On, Redis On.
