查看: 4253|回复: 3
[求助] 为什么VSS的IR-Drop比VDD的大呢
发表于 2012-9-7 16:24:11 | 显示全部楼层 |阅读模式
我在block 设计时候,给了几个虚拟的P/G pair,然后给了1.8v的供电,但是得出来的结果是VSS的IR-Drop比VDD的大,这个应该作何解释呢?
下面是ICC报出来的一些report:
Total Current from Pad Cells:    0.00 mA (0.00%)
Total Current from Virtual Pads:  277.78 mA (100.00%)
Maximum IR drop in pre_pns : 74.15 mV
Maximum current in pre_pns : 75.334 mA
Maximum EM of wires in pre_pns : 5.398853e+01 A/cm, layer METAL2
Maximum EM of vias in pre_pns : 1.338229e+05 A/cm_square, layer VIA23
The PNS synthesizes the net VDD successfully
The maximum IR drop of the synthesized net VDD is  74.151 mV
Maximum IR drop in pre_pns : 245.09 mV
Maximum current in pre_pns : 126.914 mA
Maximum EM of wires in pre_pns : 9.712683e+01 A/cm, layer METAL2
Maximum EM of vias in pre_pns : 3.097430e+05 A/cm_square, layer VIA23
Warning: Target IR drop for net VSS cannot be satisfied. (PNA-108)
The maximum IR drop of the synthesized net VSS is 245.091
 楼主| 发表于 2012-9-7 16:25:37 | 显示全部楼层
自己先顶一个吧,report中上面的是VDD的分析,下面的是VSS的分析,期待大婶的精彩解答!!!
发表于 2012-12-8 16:38:47 | 显示全部楼层
回复 1# SKILLER
   请问你是用哪个命令或者哪个选项得到这个报告的,我的怎么都没有 呢?
发表于 2024-3-6 11:19:33 | 显示全部楼层
请问楼主找到原因了吗?
GMT+8, 2025-9-21 10:07 , Processed in 0.473643 second(s), 5 queries , Gzip On, Redis On.
