楼主: qlz991
HDL Designer V2010.2a
发表于 2013-2-18 15:43:07 | 显示全部楼层
Great work! Thanks a lot!
发表于 2013-2-18 15:53:09 | 显示全部楼层
I've searched a license generator for this version and realised that generator for 2007-2008 Mentor progects works correct. Here it is.
To generate license edit corresponding .src license file:
mdltech_fl.src - for counted floating license, update HostName and HostID
         fields in SERVER line to match your host parameters.
         Besides, your should correct DAEMON line to match rigth
         path to you mgcld.exe location.
         Note: HOSTID=ANY doesn't work.
mdltech_nl.src - for uncounted nodelocked license, update HOSTID field
         in FEATURE line to match your host HOSTID.
You can use lmutil to obtain you HOSTID:
Run "lmutil.exe hostid -n -ether" and take first value in produced string.
Run corresponding .bat-file to generate license:
make_float.bat         - floating license generation.
make_nodelocked.bat    - nodelocked license generation.
After all, you'll be given right license.dat.
Copy it to proper location and modify LM_LICENSE_FILE environment variable
to point the location of generated and copied license.dat.
HDL Designer About screen
keygen_mentor_products_2010.rar
1.46 MB, 下载次数: 65 , 下载积分: 资产 -2 信元, 下载支出 2 信元
License generator
发表于 2013-8-15 21:55:37 | 显示全部楼层
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
聽起來很受用,謝謝分享哩
发表于 2013-8-15 23:03:23 | 显示全部楼层
i sagree
发表于 2013-8-25 14:10:30 | 显示全部楼层
有破解吗?
发表于 2013-8-25 15:37:57 | 显示全部楼层
頂一下!感謝無私分享!!
发表于 2013-8-30 03:44:46 | 显示全部楼层
这个是09的还是10的。
发表于 2013-9-13 08:30:35 | 显示全部楼层
谢谢楼主的辛勤劳动,帮了大忙了
发表于 2014-1-2 09:57:02 | 显示全部楼层
有最新的2012版本吗?大家都很期待啊。各们大神请绐个下载地址。
发表于 2014-1-22 08:38:13 | 显示全部楼层
linux version please
GMT+8, 2025-12-8 02:09 , Processed in 0.038273 second(s), 5 queries , Gzip On, Redis On.
