查看: 24086|回复: 59
想详细了解BSIM3v3 和 BSIM4的推荐看这本书
发表于 2006-12-12 16:53:33 | 显示全部楼层 |阅读模式
MOSFET Models for SPICE Simulation, Including BSIM3v3 and BSIM4
    by
William Liu, 2001
Drawing upon his extensive experience designing with BSIM, William Liu provides a brief history of the model, discusses the various advantages of BSIM over other models, and explores the reasons why BSIM3 has been adopted by the majority of circuit manufacturers. He then provides engineers with the detailed practical information and guidance they need to master all of BSIM's features. He:
* Summarizes key BSIM3 components
* Represents the BSIM3 model with equivalent circuits for various operating conditions
* Provides a comprehensive glossary of modeling terminology
* Lists alphabetically BSIM3 parameters along with their meanings and relevant equations
* Explores BSIM3's flaws and provides improvement suggestions
* Describes all of BSIM4's improvements and new features
* Provides useful SPICE files, which are available online at the Wiley ftp site
发表于 2006-12-12 17:56:33 | 显示全部楼层
没找到下载的地方
抱歉!
你找到这本书了吗?
 楼主| 发表于 2006-12-13 13:32:15 | 显示全部楼层
没有啊,就是要群策群力!
 楼主| 发表于 2006-12-13 13:35:12 | 显示全部楼层
贴点信息吧!
I am the author William Liu. I notice there is no link to the book content (as of May, 2001). Therefore, I thought I would add that here. I am sorry to have to rate my own book a five star before I can put put forth the book content in this review space. Nonetheless, it is indeed my view that the book is a five star, an opinion which I believe, can be justified by the content shown next.
Anyway, here is the content:
CHAPTER 1 MODELING JARGONS
1-1 SPICE Simulator and SPICE Model 1-2 Numerical Convergence 1-3 Digital and Analog Models 1-4 Smoothing Function and Single Equation 1-5 Chain Rule 1-6 Quasi-Static Approximation 1-7 Terminal Charges and Charge Partition 1-8 Charge Conservation 1-9 Non-Quasi-Static and Quasi-Static y-Parameters 1-10 Source-Referencing and Inverse Modeling 1-11 Physical vs. Table-Lookup Models 1-12 Scalable Model and Device Binning
CHAPTER 2 BASIC FACTS OF BSIM3
2-1 What Is and What's Not Implemented in BSIM3 2-2 D.C. Equivalent Circuit and Leakage Current 2-3 Large-Signal Equivalent Circuit 2-4 Small-Signal Equivalent Circuit and y-Parameters 2-5 Noise Equivalent Circuit 2-6 Special Operating Conditions: VDS < 0, VBS > 0, VGS < 0, or VBD > 0
CHAPTER 3 BSIM3 PARAMETERS
3-1 List of Parameters According to Function 3-2 Alphabetical Glossary of Parameters 3-3 Flow Diagram of SPICE Simulation
CHAPTER 4 IMPROVABLE AREAS OF BSIM3
4-1 Lack of Robust Non-Quasi-Static Model; Transient Analysis 4-2 Problem with the 40/60 Partition: The "Killer NOR Gate" 4-3 Lack of Channel Resistance (NQS Effect; Small-Signal Analysis) 4-4 Incorrect Transconductance Dependency on Frequency 4-5 Lack of Gate Resistance (and Associated Noise) 4-6 Lack of Substrate Distibuted Resistance (and Associated Noise) 4-7 Incorrect Source/Drain Asymmetry at VDS = 0 4-8 Incorrect Cgb Behaviors 4-9 Capacitances with Wrong Signs 4-10 Cgg Fit and Other Capacitance Issues 4-11 Insufficient Noise Modeling (No Excess Short-Channel Thermal Noise) 4-12 Insufficient Noise Modeling (No Channel-Induced Gate Noise) 4-13 Incorrect Noise Figure Behavior 4-14 Inconsistent Input-Referred Noise Behavior 4-15 Possible Negative Transconductances 4-16 Lack of GIDL (Gate Induced Drain Leakage) Current 4-17 Incorrect Subthreshold behaviors 4-18 Threshold Voltage Rollup 4-19 Problems associated with a nonzero RDSW 4-20 Other Nuisances
CHAPTER 5 IMPROVEMENTS IN BSIM4
5-1 Introduction 5-2 Physical and Electrical Oxide Thicknesses 5-3 Strong Inversion Potential For Vertical Nonuniform Doping Profile 5-4 Threshold Voltage Modifications 5-5 VGST,eff In Moderate Inversion 5-6 Drain Conductance Model 5-7 Mobility Model 5-8 Diode Capacitance 5-9 Diode Breakdown 5-10 GIDL (Gate Induced Drain Leakage) Current 5-11 Bias-Dependent Drain-Source Resistance 5-12 Gate Resistance
5-13 Substrate Resistance 5-14 Overlap Capacitance 5-15 Thermal Noise Models 5-16 Flicker Noise Model 5-17 Non-Quasi-Static AC Model 5-18 Gate Tunneling Currents 5-19 Layout-Dependent Parasitics
APPENDIX
A. BSIM3 Equations B. Capacitances and Charges for All Bias Conditions C. Non-Quasi-Static y-parameters D. Fringing Capactiance E. BSIM3 Non-Quasi-Static Modeling F. Noise Figure G. BSIM4 Equations INDEX
 楼主| 发表于 2006-12-13 13:43:12 | 显示全部楼层
评价
This is clearly the best and newest book on MOSFET models. It's Liu's third book, and it's delightful. That's a strange word for a technical book, but it's true! This book is both practical (down to earth) and occasionally funny.
I must admit... I haven't read all 588 pages yet, but the sections I have read are all clearly written, well illustrated and there is just enough background information to make the topics interesting. For example when he discusses the possibility of BSIM3 calculating a negative back-gate transconductance, gmb, or a negative mutual transconductance, gm, he points out that a negative gm has actually been reported in a real device, and gives the reference. Then he gives a checklist you can use to help prevent the negative gmb problem in your model.
I was particularly interested and amused by his explanation of the "Killer NOR Gate" in section 4.2 "Problems with the 40/60 Partition." This circuit caused a lot of interesting e-mail discussion a couple of years ago.
His chapter 3 contains a very good 130-page "ALPHABETICAL GLOSSARY OF BSIM3 PARAMETERS." Anybody who works with BSIM3 knows you need a handy list of all the model parameters and what they mean. Liu devotes a couple of paragraphs to each, and he recommends leaving many of them equal to zero!
I'm more of a SPICE model user, not so much a theorist, and I found this book to be exactly what I needed.
The other recent classics on this subject are Cheng & Hu's MOSFET Modeling & BSIM3 User's Guide (1999), Arora's MOSFET Models for VLSI Circuit Simulation (1993) and Foty's MOSFET Modeling with SPICE (1996).
 楼主| 发表于 2006-12-13 13:46:07 | 显示全部楼层
Editorial Reviews
Editorial Reviews
Book Description
An expert guide to understanding and making optimum use of BSIM
Used by more chip designers worldwide than any other comparable model, the Berkeley Short-Channel IGFET Model (BSIM) has, over the past few years, established itself as the de facto standard MOSFET SPICE model for circuit simulation and CMOS technology development. Yet, until now, there have been no independent expert guides or tutorials to supplement the various BSIM manuals currently available. Written by a noted expert in the field, this book fills that gap in the literature by providing a comprehensive guide to understanding and making optimal use of BSIM3 and BSIM4.
From the Back Cover
Drawing upon his extensive experience designing with BSIM, William Liu provides a brief history of the model, discusses the various advantages of BSIM over other models, and explores the reasons why BSIM3 has been adopted by the majority of circuit manufacturers. He then provides engineers with the detailed practical information and guidance they need to master all of BSIM’s features. He:
Explores BSIM3’s flaws and provides improvement suggestions
Describes all of BSIM4’s improvements and new features
发表于 2006-12-13 14:00:02 | 显示全部楼层
Where can down load this book??
发表于 2006-12-13 19:23:31 | 显示全部楼层
发表于 2007-1-19 10:20:03 | 显示全部楼层
发表于 2007-4-24 16:26:31 | 显示全部楼层
哪位老大把这本书给发上来吧!
GMT+8, 2025-12-29 01:41 , Processed in 0.024801 second(s), 5 queries , Gzip On, Redis On.
