发表于 2012-7-30 23:03:58
显示全部楼层
yeah, sometime ADE will not rerun if the main netlist does not change. you may try run spectre manually to avoid that.
about the simulation result same btw pre-layout and post-layout, i cannot really comment much without looking at the netlist.... is the netlist big? if not, can you copy and paste some of them here? |
