查看: 7062|回复: 3
shell 运行 calibre -xrc -phdb 出现错误提示
发表于 2012-7-26 10:35:42 | 显示全部楼层 |阅读模式
calibre -xrc -phdb -nowait -turbo Header.conf | tee pexrunlog_phdb.log
calibre -xrc -pdb -rcc -nowait -turbo Header.conf | tee pexrunlog_pdb.log
calibre -xrc -fmt -rcc -nowait Header.conf | tee prerunlog_fmt.log
calibre -xrc -phdb 的错误提示:
ERROR: Error SPC1 on line 351 of SmicSP11P_cal013_log_sali_plmtx_1233.lvs_xRC - superfluous specification statement: layout primary.
ERROR: Compilation of the SVRF rules failed.
calibre -xrc -pdb -rcc 错误提示:
--- RULE FILE = Header.conf
WARNING: As of version 2008.4, the following SVRF command is deprecated: PEX INCLUDE/EXCLUDE ...
       Use the following SVRF command instead: PEX EXTRACT INCLUDE/EXCLUDE ...
WARNING: As of version 2009.1, the following SVRF command is deprecated: PEX REPORT LUMPED filename ASCII {ID | LAYOUT | SOURCE}
       Use the following SVRF command instead: PEX REPORT FILENAME {LAYOUTNAMES | SOURCENAMES}
calibre -xrc -fmt -rcc 错误提示:
       Use the followi
不知道什马情况阿,求教!
发表于 2012-11-13 08:13:14 | 显示全部楼层
ddddddddddd
发表于 2019-10-14 10:38:44 | 显示全部楼层
把calibre.rcx规则文件的LAYOUT PRIMARY定义删除
发表于 2023-7-12 12:04:21 | 显示全部楼层
是将 LAYOUT PRIMARY 整行删除 ,还是  弄成  LAYOUT  PRIMARY  " " 里面是空格 ?  这种问题的根源是什么,请大神指点一下
GMT+8, 2025-12-20 08:20 , Processed in 0.177396 second(s), 5 queries , Gzip On, Redis On.
