查看: 3050|回复: 0
pex 运行出错
发表于 2012-7-25 22:53:42 | 显示全部楼层 |阅读模式
命令 calibre -xrc -phdb -nowait -turbo Header.conf
log文件:
-----          STANDARD VERIFICATION RULE FILE COMPILATION MODULE          -----
--- RULE FILE = Header.conf
       Use the following SVRF command instead: PEX EXTRACT INCLUDE/EXCLUDE ...
       Use the following SVRF command instead: PEX REPORT FILENAME {LAYOUTNAMES | SOURCENAMES}
ERROR: Error SPC1 on line 351 of SmicSP11P_cal013_log_sali_plmtx_1233.lvs_xRC - superfluous specification statement: layout primary.
求真相!!!!!!!!
GMT+8, 2025-12-26 15:59 , Processed in 0.027675 second(s), 6 queries , Gzip On, Redis On.
