查看: 3310|回复: 1
[讨论] encounter中如何生成power IO/PAD 和PG net
发表于 2012-7-20 16:28:32 | 显示全部楼层 |阅读模式
Can anyone tell me which command to create power io(physicall cells,also) and PG net? The following command effect?
1. addInst (add physicall cells,it also can create io cells)
2. addNet (I know that it can create the physical net,but how can we say it is a pg net? "physical net" unequal "PG net")
Thanks advanced!
发表于 2016-3-29 21:56:27 | 显示全部楼层
最好先在网表里例化吧,这样比较方便
GMT+8, 2025-9-16 06:49 , Processed in 0.015656 second(s), 5 queries , Gzip On, Redis On.
