查看: 3109|回复: 1
[求助] 在PostRoute OPT时总是报licenses checkout failed?NanoRoute OPT时也报
发表于 2012-7-18 09:34:26 | 显示全部楼层 |阅读模式
#Start globalDetailRoute on Wed Jul 18 09:26:28 2012
#cpu time = 00:00:00, elapsed time = 00:00:00, memory = 931.00 (Mb)
Width and spacing based sheet resistance table is used ...
#NanoRoute Version v08.10-p008 NR081027-0018/USR58-UB
**ERROR: (SOCLIC-90):   This command does not have the necessary license to run, and there are no optional licenses installed that can enable this command using the current base-license of 'socexl'..
Use 'setLicenseCheck -status' to see the current licenses in use and for more information.
#Current checked out license: SOC_Encounter_GPS
#ERROR (NRCM-62) Licenses checkout failed.
#Cpu time = 00:00:03
#Elapsed time = 00:00:03
#Increased memory = 0.00 (Mb)
#Total memory = 931.00 (Mb)
#Peak memory = 1031.00 (Mb)
#WARNING (NRIF-19) Fail to complete globalDetailRoute on Wed Jul 18 09:26:31 2012
信息如上,不知道哪位大侠知道是什么原因吗?
发表于 2012-7-18 10:20:43 | 显示全部楼层
没有license吧
GMT+8, 2025-12-29 04:32 , Processed in 0.017309 second(s), 7 queries , Gzip On, Redis On.
