之前原程序用8bit数据进fifo变成64bit,再经过sdram(64bit)出来,再经过fifo还原出来,数据能完全还原,现在我改用32bit进fifo,我要做哪些更改,才能把原数据还原,不丢失?一下是我改的程序(加了tangate的是我改的),望高手指教!
1、出fifo,到sdram
`timescale 1ns / 100ps
module ccd_fifo_ctrl(
clk,
resetn,
//sdram control signal
SDRAM_BUS_REQ,
SDRAM_BUS_ACK,
SDRAM_ADS_n,
SDRAM_Addr_out,
SDRAM_Data_out,
//SDRAM_Data_valid,
//SDRAM_Data_in,
SDRAM_R_Wn,
//Camera output signal
ccd_clk,
ccd_vs,
ccd_hs,
ccd_de,
ccd_data,
ccd_sel,
field_sel,
write_frame_cnt
input clk;
input resetn;
output [1:0]write_frame_cnt;
output SDRAM_BUS_REQ;
input SDRAM_BUS_ACK;
output SDRAM_ADS_n;
output [21:0] SDRAM_Addr_out;
output [63:0] SDRAM_Data_out;
//input SDRAM_Data_valid;
//input [31:0] SDRAM_Data_in;
output SDRAM_R_Wn;
//Camera signal
input ccd_clk;
input ccd_vs;
input ccd_hs;
input ccd_de;
input [31:0] ccd_data;
input ccd_sel; //0-->sensor1, 1-->sensor2
input field_sel;
//---------------state--------------------
parameter c_w_idle = 5'b00001;
parameter c_w_req = 5'b00010;
parameter c_w_ads = 5'b00100;
parameter c_w_data = 5'b01000;
parameter c_w_wait = 5'b10000;
reg [4:0] c_state;
//fifo control signal
wire fifo_empty;
wire [63:0] fifo_rdata;
//-----------sdram ack input delay-----------
reg sdram_bus_ack_d1;
always @(posedge clk or negedge resetn)
begin
if(!resetn)
sdram_bus_ack_d1 <= 1'b0;
else
sdram_bus_ack_d1 <= SDRAM_BUS_ACK;
end
//-----------sdram req--------------
reg SDRAM_BUS_REQ;
begin
if(!resetn)
SDRAM_BUS_REQ <= 1'b0;
else if((c_state == c_w_req))
SDRAM_BUS_REQ <= 1'b1;
else
end
//------------sdram address---------------
reg [2:0] ccd_hs_syn;
reg [2:0] ccd_vs_syn;
reg ccd_hs_rising;
reg ccd_vs_rising;
begin
if(!resetn)
begin
ccd_hs_syn <= 3'b000;
ccd_vs_syn <= 3'b000;
end
else
begin
ccd_hs_syn <= {ccd_hs_syn[1:0], ccd_hs};
ccd_vs_syn <= {ccd_vs_syn[1:0], ccd_vs};
end
end
begin
if(!resetn)
ccd_hs_rising <= 1'b0;
else if(!ccd_hs_syn[2] && ccd_hs_syn[1])
ccd_hs_rising <= 1'b1;
else
end
begin
if(!resetn)
ccd_vs_rising <= 1'b0;
else if(!ccd_vs_syn[2] && ccd_vs_syn[1])
ccd_vs_rising <= 1'b1;
else
end
reg [21:0] write_low,write_high,SDRAM_Addr_out;
always @ (posedge clk or negedge resetn)
if(!resetn)
SDRAM_Addr_out <= 0;
else
SDRAM_Addr_out <= {sensor_high_addr , write_low[19:0]};
if(!resetn)
write_low <= 0;
else if (ccd_vs_rising)
write_low <= 0;
else if(sdram_bus_ack_d1 && (SDRAM_BUS_ACK == 1'b0))
write_low <= write_low + 4'd8;
reg [1:0] sensor_high_addr;
always @(posedge clk)
begin
if(!resetn)
sensor_high_addr <= 2'b10;
else if(ccd_vs_syn[1:0] == 2'b01)
sensor_high_addr <= sensor_high_addr + 1'b1;
end
assign write_frame_cnt = sensor_high_addr;
//-----------SDRAM_R_Wn----------------
assign SDRAM_R_Wn = 1'b0;
//-----------SDRAM_Data_out-------------
assign SDRAM_Data_out = fifo_rdata;
//-----------SDRAM ADS-----------------
reg SDRAM_ADS_n;
begin
if(!resetn)
SDRAM_ADS_n <= 1'b1;
else if(c_state == c_w_ads)
SDRAM_ADS_n <= 1'b0;
else
end
//------------write data counter-------------
reg [7:0] wcnt;
begin
if(!resetn)
wcnt <= 8'h0;
else
begin
if(c_state == c_w_data)
wcnt <= wcnt + 1'b1;
else
wcnt <= 8'h0;
end
end
//------------state machine------------
begin
if(!resetn)
c_state <= c_w_idle;
else
begin
case(c_state)
c_w_idle:
if(fifo_empty == 1'b0)
c_state <= c_w_req;
c_w_req:
if(SDRAM_BUS_ACK)
c_state <= c_w_ads;
c_w_ads:
c_state <= c_w_data;
c_w_data:
if(wcnt == 8'h7)
c_state <= c_w_wait;
c_w_wait:
if(SDRAM_BUS_ACK == 1'b0)
default:
endcase
end
end
//-------------fifo rd-------------------
reg fifo_rd;
always @(c_state)
begin
fifo_rd <= 1'b1;
else
fifo_rd <= 1'b0;
end
//---------------ccd write data---------------------
reg [15:0] ccd_clr_dly;
always @(posedge ccd_clk)
begin
ccd_clr_dly <= {ccd_clr_dly[14:0] , ccd_hs};
end
reg [2:0] ccd_de_cnt;
always @(posedge ccd_clk or negedge resetn)
if(!resetn)
ccd_de_cnt <= 3'b000;
else if(ccd_clr_dly[15:14] == 2'b10)
else if (ccd_de_cnt == 3'b001 && ccd_de)//tangate 加上的,原先没有
ccd_de_cnt <= 3'b000;//tangate 加上的,原先没有
else if(ccd_de)
ccd_de_cnt <= ccd_de_cnt + 1'b1;
reg fifo_wr;
if(!resetn)
fifo_wr <= 1'b0;
else if (ccd_de_cnt == 3'b1 && ccd_de)//tangate 原先为7
fifo_wr <= 1'b1;
else
fifo_wr <= 1'b0;
reg [63:0] fifo_wdata;
if(!resetn)
fifo_wdata <= 64'h0;
else if(ccd_de)
fifo_wdata <= {ccd_data, fifo_wdata[63:32]};//tangate 原先为【63:8】
wire fifo_empty_flag;
ccd_fifo_dc u1(
.Reset(~resetn | ccd_vs_rising),
.RPReset(1'b0),
.WrClock(ccd_clk),
.WrEn(fifo_wr),
.Data(fifo_wdata),
.RdClock(clk),
.RdEn(fifo_rd),
.Q(fifo_rdata),
.Empty(),
.Full(),
.AlmostEmpty(fifo_empty_flag)
reg [1:0] fifo_empty_syn;
begin
if(!resetn)
fifo_empty_syn <= 2'b11;
else
fifo_empty_syn <= {fifo_empty_syn[0], fifo_empty_flag};
end
assign fifo_empty = fifo_empty_syn[1];
endmodule
2、出sdram,到fifo
module Sdram_Bayer2RGB(
input clk_write,
input resetn,
input Hdmi_De,
input Hdmi_hde,
input Hdmi_vde,
output reg FIFO_Full,
input FIFO_WR,
input [63:0] FIFO_WData,
input clk_read,
output reg[31:0] data_out,
input wire Hdmi_Vsync
wire [23:0] Hdmi_Pixdata;
wire read_de;
wire [63:0] Fifo2_q;
wire [6:0] Fifo2_wrusedw;
reg Fifo2_rdreq;
ff32 ff32(
//.aclr(!Hdmi_vde),
.aclr(Hdmi_Vsync),
.data(FIFO_WData),
.rdclk(clk_read),
.rdreq(Fifo2_rdreq),
.wrclk(clk_write),
.wrreq(FIFO_WR),
.q(Fifo2_q),
.wrusedw(Fifo2_wrusedw)
always @ (posedge clk_write)
FIFO_Full <= Fifo2_wrusedw[6];
always @(posedge clk_read or negedge resetn)
if(!resetn)
else if (!Hdmi_De)
else if ((ccd_de_cnt == 3'b001) && Hdmi_De)//tangate 加上的,原先没有
else if(Hdmi_De)
always @(*)
if (ccd_de_cnt == 3'b000 && Hdmi_De)
Fifo2_rdreq <= 1'b1;
else
Fifo2_rdreq <= 1'b0;
reg Fifo2_rdreq1;
if(!resetn)
Fifo2_rdreq1 <= 1'b0;
else
Fifo2_rdreq1 <= Fifo2_rdreq;
reg [63:0] fifo_rdata;
if(!resetn)
fifo_rdata <= 64'h0;
else if (Fifo2_rdreq1)
fifo_rdata <= Fifo2_q;
else if(Hdmi_De)
fifo_rdata <= fifo_rdata >> 32;//tangate 原先为8
assign de_out = de_delay[13];//29
reg [29:0] de_delay;
always @(posedge clk_read)
begin
if(!resetn)
de_delay <= 30'b0;
else
de_delay <= {de_delay[28:0],Hdmi_De};
end
always@(posedge clk_read)
begin
if(Hdmi_De)
begin
data_out <= fifo_rdata[31:0];
end
else
data_out<=32'h00;
end
endmodule |
