查看: 7020|回复: 8
RedHat下IC610安装bad ELF interpreter求助
发表于 2012-7-12 15:58:43 | 显示全部楼层 |阅读模式
按照IC610安装说明(图文版)
解压好了CDROM 1~5,进入CDROM1开始./SETUP
然后选择y,装installscape,报错:
initializing Installscape using JVM at /home/eda/installscape/runtime/LNX86/bin/java. This might take some time...//这里应该过一会就跳出窗口的,结果出了这两行:
/home/eda/installscape/iscape/bin/iscape.sh: home/eda/installscape/iscape/runtime/LNX86/bin/java: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory.
求助,在线等。。。
 楼主| 发表于 2012-7-12 17:35:50 | 显示全部楼层
可能是64位的问题,尝试下载RPM解决
发表于 2012-7-16 10:09:43 | 显示全部楼层
yum 从光盘安装看看
发表于 2012-7-16 11:10:28 | 显示全部楼层
lib/ld-linux.so.2 is missing~!
 楼主| 发表于 2012-7-18 09:59:13 | 显示全部楼层
回复 4# 飞扬紫百合
   是的,然后装RPM,然后发现redhat高版本不适合装cadence,就换了ubuntu成功了,thanks anyway
 楼主| 发表于 2012-7-18 10:00:22 | 显示全部楼层
回复 3# zzczx
   最后还是发现redhat高版本不适合装IC610,换了ubuntu就好啦,thankyou
发表于 2012-7-18 10:39:00 | 显示全部楼层
ic615 can run on centOS 6.2 ...
hspice also work on cent OS 6.2
ADP  also work
Laker also work ..
but need install some library step by step  , and many probelm
and license server can not on cents OS 6 => need old RHEL
new I7 server use cent OS will better ..
发表于 2013-4-3 17:26:16 | 显示全部楼层
我用的是centos6,装IC610的时候也出现了1楼的问题。难道centos6也太高级了,装不了IC610吗?
发表于 2015-9-1 14:38:36 | 显示全部楼层
Myself working in CentOS 7..
Whether it is compatible.?
GMT+8, 2025-12-5 13:37 , Processed in 0.333499 second(s), 6 queries , Gzip On, Redis On.
