楼主: nazhaahai
[资料] tessent mbist mbistarchitect license mentor所有工具license
发表于 2012-8-29 03:14:21 | 显示全部楼层
回复 20# lsqswl
I go ahead responding you here. What you said in another post is absolutely correct. And what I have further done is use the env setting to start the license server. (No dash in between the hostname and eth0)
The starting license setting is pretty the same as starting Calibre, I don't know how you dealing with them both.
alias lmlim3="$TESSENT_HOME/bin/lmgrd -c $TESSENT_HOME/lic/license.dat"
alias lmlim4="$TESSENT_HOME/bin/lmstat -c $TESSENT_HOME/lic/license.dat"
So everytime when you need to use mbist, you have to start license server first(like Calibre). I don't know if there is better solution for this. The following picture is about successfully starting mbistarchitect.
Hope it helps.
发表于 2012-8-29 03:15:39 | 显示全部楼层
BTW, it is quite time consuming for the computer to run even the example program. Maybe that should be my computer problem. You can tell me something about your program running situations.
 楼主| 发表于 2012-8-29 09:57:48 | 显示全部楼层
回复 22# 悉你
   是你生成的license太多了。其实只是需要mbistarchitect 这一句而已
发表于 2012-9-3 00:14:31 | 显示全部楼层
回复 21# 悉你
Thank you for your help and your problem is working out as follows:
    if you wantn't to run lmlim3 and lmlim4 when computer restart,youcan add a line such as "/cadtools/tessent/bin/lmgrd -c /cadtools/license/mentor.dat -l /cadtools/tessent/mg.log&" to "/etc/rc.local" using command "vi /etc/rc.local".
发表于 2012-9-3 10:14:03 | 显示全部楼层
呵呵,还得patch ecc,又费了2信元,不过还是谢谢分享了!
发表于 2012-9-4 09:58:21 | 显示全部楼层
locked
发表于 2012-9-6 09:13:37 | 显示全部楼层
是不是根本就没有解掉
发表于 2012-9-24 16:57:45 | 显示全部楼层
我下的是mbist2007那个帖子里的文件,然后上传到服务器里文件结构如下图:
请问我该怎么样才能安装啊?本人学生不懂。望大侠指导。
另外还有这两个文件
发表于 2012-9-25 23:52:36 | 显示全部楼层
    mbistarchitech就是启动不起来,也提示
//  License server does not support this feature (mbistarchitect)
//  Warning: Failed to acquire 'MBISTArchitect' license.
上面提到的方法都试了就是不行!!!! 成功安装并启动mbistarchitect的高手能否吧过程再发一下呢?谢谢
发表于 2012-9-27 10:32:29 | 显示全部楼层
回复 32# zsefvgy13
需要下载一个patch文件,patch一下,启动license server就好了。
GMT+8, 2025-9-17 22:50 , Processed in 0.019207 second(s), 6 queries , Gzip On, Redis On.
