查看: 2505|回复: 1
[招聘] 【社聘】LSI中国2012年7月职位更新
发表于 2012-7-6 14:13:56 | 显示全部楼层 |阅读模式
有意者,请将简历发至:
Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:
http://www.weibo.com/u/1752448637
1.
Read Channel Emulation Engineer-Shanghai(若干)
Job Description
- The successful candidate will be responsible for verification and the associated design works(synthesis and Place&Route) on the FPGA and Palladium platform.
- Some design for peripheral logic but mainly verifying the blocks within a System on a Chip design. This will include the documentation of test plans and procedures.
- The candidate must be familiar with FPGA design flow.
- Candidate should be proficient in verilog design language and ASIC & FPGA CAD tools.
- Teamwork and good communication skills are critical
- Perl, Matlab, and C language and systems engineering skills is a plus
Requirements/Qualifications (Education)
- Education: BSEE or MSEE with 5+ years experience.
2.
Read Channel Verification Engineer-Shanghai(若干)
JOB DESCRIPTION:
As a member of the Read Channel team, candidate must be willing to work as an extended
member of the design team. Duties will include functional verification of Storage read
channel mixed-signal IP. Candidate will be expected to contribute to design and development
of System Verilog based verification environment and will be responsible for verification
closure of block/chip/system level functions for mixed signal based IP. Experience with
System Verilog and functional coverage methodologies are required. Must be willing to
follow a disciplined verification methodology and to work closely with a multi-location,
international design team. Excellent teamwork and communication skills are required.
PREFERRED EXPERIENCE:
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team
3.
Preamp Verification Manager -Shanghai
1个)
Job Description
In this position, you will lead digital mixed-signal verificaiton within a complex mixed-signal ASIC. Responsible for verification methodology development and improvement, efficiency and quality initiatives as well as techinical, team and project leadership. Must have a deep understanding of logic design and the advanced verification methodology. Must have experience with both IP level verification and SoC level verification is desired. Candidates need to be self-motivated, able to work well on teams, lead teams and have excellent communication skills
- MS or Ph.D.degree in Electrical or Electronic Engineering
- 5+ years of digital functional verification experience on complex SoC or mixed-signal ASIC product development.
- 2+ years verification manager experience
- Expertise with tools and methodologies used in digital or mixed-signal design and verification
- Proven teamwork and leadership skills
- Excellent analytical and problem solving skills
- Excellent oral and written communication skills
- Able to travel internationally (to United States and throughout Asia)
4.
Digital Design Engineer-Shanghai (若干)
Job Description
- Candidates for this position should have experience in the design and design management of large, high-speed, mixed signal SoCs. The designs must have contained a variety of both hard and soft-macro IP blocks. The candidate should be an expert in all parts of the SoC flow from IP deliverable hand-offs (in RTL or gate), to synthesis, DFT and test insertion, floorplanning, P&R, timing closure, signal integrity, power analysis and verification. After at least 5 years of design experience the candidate should have 3 years of design management experience. MS or higher degree in EE is required.
- MSEE or higher degree in EE required.
5.
HDD Read Channel Architect -Shanghai
1个)
Job Description
- We are looking for an engineer with a track record of excellent performance to join our read channel architecture team. In this role you would be part of a dedicated team developing LSI's leading hard disk drive ASIC technology.
- This job spans the invention process from the conception of a new idea, through reduction to practice in software, close collaboration with design teams and verification of the design through to validation of performance through bench testing. In your role you will with work closely with Design and Verification teams in Shanghai and with the RC Architecture team in the United States.
- Our core requirements are a deep knowledge of digital communications technology; familiarity with detection and coding for magnetic recording; some experience implementing signal processing and detection algorithms in software and good programming skills in C/C++ and scripting languages. Experience with design verification and bench testing would both be very desirable.
- PhD in Electrical Engineering or equivalent. Deep knowledge of the principles of digital communications. Familiarity with signal processing and programming
6.
Physical Design Engineer-Shanghai1个)
Job Description
Strong individual contributor needed to support product line growth. The candidate will work on leading edge storage solutions in ASIC, full custom and SoC environment. The ideal candidate will have demonstrated experience/exposure to digital physical design techniques including ASIC through full custom high-speed digital designs from synthesis through manufacture. Excellent communication skills are needed, as existing teams span multiple locations.
High level of physical design experience required. Expertise with netlist driven routers, signal integrity, power analysis, cts design, design rule and connectivity verification is required. Familiarity with analog physical design, basic circuit designs, manufacturing and IC packaging desirable. Must be technically adept, a strong team player, ability to manage multiple priorities and have excellent interpersonal and communication skills, CET-6 preferred.
Degree Preferred:
BSEE +5 years experience
7.
Mixed-Signal read-channel/SoC Silicon Validation Engineer -Shanghai
1个)
Job Description
We are looking for engineers who have experience working in a lab characterizing high-speed mixed signal (analog and digital) read channel/SoC. The candidate must know how to use advanced waveform generators, oscilloscopes, network analyzers and logic analyzers. The engineer must also be expert in data analysis techniques and in various scripting languages (Perl, TCL, Python). Experience in lab automation (such as through GPIB scripting) is also desirable.
- A moderate level (2-4 yrs) understanding of complex analog and digital circuits is required. It is not required, however preferred if candidates have knowledge on and/or experience in read channel/SoC.
- Excellent written and good English communication skills are required.
- Candidates should hold BSEE plus 2-4 yrs experience or MSEE (preferred) 1-2 yrs experience; and are expected to be highly motivated and resourceful in troubleshooting and problem solving. Global Team player needed. Must successfully interact with remote manager.
8.
Serdes Analog/Mixed-signal Design Engineer -Shanghai(若干)
Job Description
- Design and simulate mixed-signal circuitry for high-speed transceiver cores or products
- Create design documents based on the mixed-signal design flow
- Supervise physical layouts of analog circuits
- Work with test engineers to validate designs in silicon
- BSEE/MSEE with more than 2 years of direct experiences in design of mixed-signal circuits, such as high-speed transceivers, amplifiers, phase-locked loops, and digital-to-analog converters. Knowledge in high-speed Serdes is a plus
9.
SerDes Field Coreware Engineer  -Shanghai1个)
Job Description
The Field Coreware Engineer is a challenging and cutting-edge position with responsibilities to work closely with LSI internal IP development, foundation IP, methodology, and design center engineering/development teams to support complex ASIC designs. This position will support LSI/3rd Party IP for customer ASIC and internal ASSP designs providing “Best in Class” support
Strong communications skills are important for this position. This is a position for developing and honing verbal and written communication skills, and for interfacing to many different people and engineering organizations within and external to LSI. Position requires regular interface with LSI customers. A successful candidate will have a strong design background, debug skills, good scripting skills, and hands on experience with IP integration. This position will require travel and onsite support at times at the customer site.
- 5-10+ years experience as an application, design or development engineer
- Experience developing IP or integrating/implementing IP in an SOC (System on Chip)
- Prior experience with RTL coding and verification a plus
- Knowledge in one or more of the following IP:
o SerDes
o Memory IF: DDR, etc,
o Protocol IP : PCIe, Ethernet (example: 10G-KR4), etc…
o Processors/Subsystems
o SOC interconnect: AMBA, etc.
- Must have the ability to understand Specifications
- Experience with EDA tools such as Simulators (Synopsys VCS, Cadence NC-Verilog, Mentor ModelSim), Synopsys IC Compiler, Synopsys PrimeTime SI
- Understanding of the ASIC Design Flow
o Design Closure STA (Static Timing Analysis) Constraints
o Simulation/Debug
o Basic understanding of DFT (Design for Test)
o Basic Understand Power Estimation & Optimization
- Experience Debugging Simulations
- Basic Understanding of System Architecture/Applications
- Prototyping/Emulator knowledge a plus
- Soft/People Skills:
o Customer support skills (Communication, Positioning etc.)
o Issue Solving
o Conflict Management
- Willing to learn, expand horizons
- Positive attitude and ownership taking a must
10.
ASIC Customer Design Engineer-Shanghai(若干)
Job Description
- LSI Corporation offers an excellent opportunity to contribute to a team environment and to grow personal career path. You will be working with internal and external customers to develop state of the art IC solutions utilizing LSI's leading edge CMOS cell-based ASIC technologies. You will have responsibility for ASIC designs through all of the key development and implementation phases including RTL analysis, synthesis, design optimization, timing verification, simulation, test insertion, physical design, vector generation, and post-prototype test support. Candidates will have opportunity to work on the latest 40nm/28nm designs.
Detail design tasks include
- Presales support (die size support, memory generation, addressing customer questions and concerns.)
- RTL analysis & synthesis
- Top level and block level physical design Implementation (bonding, floor planning, power structure insertion, place and route, timing closure)
- Test structure insertion/silicon testing debug
- Formal verification
- Static timing analysis
- Cross talk analysis
- Power verification
- Physical verification
- Overtime, candidates are expected to develop the most of above skills. Candidates who have the desire to seek the in-depth and broad technical challenge should apply.
Education: BS/MS Electrical, Computer Engineering or Equivalent
- 2+ years experience in ASIC design and implementation. Familiar with all aspects of ASIC design implementation flow and specializing in physical design or DFT implementation. The ideal candidate should have successfully completed at least one mid-size ASIC or ASSP tapeout.
- Experience with Synopsys Astro or ICC is a plus. Other physical design tool experience will also be considered. Scripting skill is a strong plus.
- Experience in debugging prototypes considered a strong plus. Knowledge and hands on use of test insertion / vector generation / verification a plus. Some experience with Signal integrity a bonus.
- Experience in working with customers is desired. Must possess excellent communication skills and strong self-motivation. Be able to effectively communicate with other members of the design team, supporting organizations, and management. This position requires frequent interface with LSI customers
- Candidates have ONE OR MORE good skill sets of the following areas are highly encouraged to apply:
- RTL Analysis/Synthesis/STA: The ideal candidate should have strong skills for the front-end of design
- implementation which includes RTL Analysis, Synthesis Strategies, and STA setup for complex ASIC
- environments. This would include strategies for power management.
OR
Physical Design Implementation: The ideal candidate should be strong in the Physical Design (at least at block level) which includes floor planning, design closure, & STA. Having strong DRC & LVS skills are a plus. Strong
- Synopsys Astro/ICC experience a plus. Having Mentor Calibre skills a plus.
- OR
- Physical Verification: The ideal candidate should have in-depth understanding of transistor level IC fabrication process, familiar with major foundries(TSMC or SMIC) runsets and verification flow, custom layout experience is a plus, successfully done LVS/DRC/ERC/Antenna check for multiple tapeouts is a strong plus. Understanding of DFM is a plus. Calibre experience is a plus.
- OR
- DFT: The ideal candidate should be strong in all DFT (Design for Test) for all aspects. This would include
- scan/TDF, TestKompress, MEMBIST/BISR, JTAG and etc. Having STA skills is a plus for all aspects of test. Responsible for support / debug of customer designs after delivery of prototypes
11.
Software Quality Assurance(SQA)-Shanghai(若干)
Education and Experience Requirements
BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 6+ years of firmware development.
M.S. preferred with 4+ years in software / hardware validation
Knowledge, Skills, and Abilities
Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
Meticulous, methodical, uncompromising, and creative in
testing
Experience in software debugging, problem creation and trapping
Experience in devising testing / validation methodology is strong plus
Communicate effectively in a team, able to multitask effectively in fast-paced environment.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (strong plus).
Knowledge and hands-on experience with storage protocols is preferred (SAS / SATA)
12.
Junior SQA engineer-Shanghai(若干)
As a Junior Software Quality Assurance (SQA) Engineer (软件测试工程师/嵌入式软件测试工程师), you will work with an exceptionally talented and dynamic development team based in Shanghai, to test and validate cutting-edge firmware for our enormously successful second generation of mass storage controller in the consumer and enterprise segments. Participate in all aspects of design and product development through introduction and release. Duties include setting up interoperability lab, participating and refining methodology in interoperability testing. You will have the opportunity to create cutting edge products that transforms data storage.
BS in Electrical Engineering, Computer Science, or Computer Engineering is required with 2+ years of software/hardware validation.
- Quick learner with high level of self-motivation and dedication, with ability to deliver high quality products on time
- Meticulous, methodical, uncompromising, and creative in testing
- Experience in software debugging, problem creation and trapping
- Communicate effectively in a team, able to multitask effectively in fast-paced environment.
- C / C++ Programming experience is optional but preferred
- Prior experience with PC / Notebook / HDD / SSD testing is optional but preferred
13.
Firmware Engineer-Shanghai(若干)
M.S. preferred with 4+ years in firmware development.
Must demonstrate expertise in design and implementation of event-driven, real time firmware solutions using C/C++ programming
Must be able to work with ASIC and software engineers in a collaborative environment
Must have an excellent computer science background and demonstrated strength in designing efficient embedded firmware for storage or networking products
Firmware/System debug skills utilizing debugger, protocol analyzer is required
Good understanding of RTOS concepts including task switching, deadlocks, and resource management issues is required
High level of skill in problem recreation, trapping and resolution, possess good written and verbal communication skills.
Understanding of NAND Flash concepts, knowledge of Flash management techniques, including wear leveling, garbage collection (optional but strong plus).
14.
Test Operations Engineer -Shanghai
(若干)
Job Description
- To support new product introduction into subcontractors and facilitate high volume ramp
- Manage execution deliverables covering test programs and all the essential test hardware and co-work with supply chain management to meet/exceed on time deployment at subcontractors
- Drive KPIs at subcontractors to meet/exceed LSI performance metrics expectations
- Drive cost reduction and margin improvement initiatives to achieve the manufacturing cost objectives
- Support new technology/best practices evaluation/assessment, early adoption and introduction into subcontractors
- Ensure test process compliance to prevent manufacturing execursions
- Ensure compliance of quality requirements at subcontractors
- University graduate (EE degree) with 5 years or more in product, test, and high volume manufacturing operations experiences in the semiconductor area
- Solid background in high speed digital and mixed-signal testing is essential
- Working experiences with ATE andancillary test equipments. Teradyne Catalyst/UltraFlex, Advantest T2000, Delta/Seiko Epson handlers and TEL/Accretech/Opus probers will be of advantage
- C++ and/or Perl programming skills
15.
Test Engineer -Shanghai
1个)
Job Description
- To support prototype and production releases of new products. Manage debug of test program, design and debug of test hardware, and meet product release schedule.
- Support test program development for implementing changes in new test methodologies for test coverage improvement.
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via test time reduction and multiple site test solutions for production release
- Support test chip test development and characterization of new IP used in LSI products.
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM, Fabless, or Foundry environment
- ATE programming skills would be essential ,
-T2000 platform using experience is must
16.
Systems Application Engineer (FCD)-Shanghai1个)
Job Description
- Provide Tier 1 customer support and support field applications engineers
- Act as technical lead on customer management issues
- Manage and prioritize customer issues and customer expectations releasing firmware updates back to customers
- Train and teach customers on tools and capabilities of products
- HW, Board level and FW debug using a variety of diagnostic tools
- Define and articulate technical product requirements to developers through market requirement and product requirement documents based on customer feedback
- Meet with architecture and engineering management level customers to understand product roadmap requirements. Provide feedback to LSI for product improvements.
- Analyze competitive offerings and promote development of product features to stay ahead of competition
- Minimal travel required.JD
- BS EE or CS required, MS preferred
- Min 8+ years experience in product design, field or product engineering role
- Create and propose product concepts to executive level staff
- Excellent verbal and written communication skills. High technical comprehension a must . Must be able to translate complex ideas into easily communicated messages
- Experienced with High Speed I/O interfaces from physical to protocol level (SAS, SATA, InfiniBand, FC, Ethernet, PCI Express), Memory technology (SRAM, DRAM, Flash, etc), Python programming. Must have familiarity with Server and Storage system architecture
17.
Systems Application Engineer(RSD) –Shenzhen/Shanghai
(若干)
Job Description
Provide product support for customers that use LSI’s I/O standard products. Product support involves helping the customer with the initial integration of the I/O standard product and debug of any software or hardware issues that arise. Work with the technical publications group on data manuals, systems engineering notes, and other documentation support. Provide training for customers and the Field Application Engineering organization. Work with the development engineering departments, hardware and software in debugging and supporting new products. Also involves working with silicon and software in a system environment
- Considering candidates with BSEE/BSCE. 5+ years of experience required.
- The ideal candidate will have a technical understanding of SAS, SCSI and PCI Express. Candidate will have embedded firmware debug experience and posses systems level knowledge. Good communication/interpersonal skills and the ability to listen and incorporate feedback is essential. The ability to handle multiple tasks at the same time is also required.
- C coding experience or equivalent coursework required.
- Logic analyzer, oscilloscope and protocol analyzer experience a plus.
18.
Program Managers-Shenzhen1个)
Scope of programs:
- International Programs with contributors from several organizations and/or Business Units
- Programs with high business impact, above $20Mio total over product lifetime
- Programs with high development cost and effort, above 5 man years
- Programs with concurrent engineering of customer product and IP customization
Responsibilities:
- Project Definition:
Ensure that Goals, Objectives & Scope for the Program is defined, understood and agreed to
Work with engineering and management to form the project team.
Develop a Project Plan with clear ownership and deliverables milestones together with LSI and Customer teams
Work with engineering to calculate and forecast the effort and investment for successful project execution
Drive concurrent Risk Management as integral part of the project planning and execution
- Project Execution:
Call regular project review meetings, internal and with the customer
Coordinate and align the customer execution with internal LSI organizations and deliverables.
Ensure effective communication between all parties involved
Provide regular project reports (to the customer and internal)
Continuously track/maintain and measure project schedule progress against plan
Perform continuous Risk Management and elevate critical issues and risks.
Manage the Change Management Process (with the customer and internal to LSI)
Manage the Action Management Process
Facilitate Project Lessons Learned (internal and with the customer)
- Requirements:
Minimum 5 years experience in the fields of management, sales/marketing and engineering
Good understanding of the ASIC design process & methodology
Detailed knowledge of project management methodology, processes and tools
PMI certification is a plus
Expert knowledge in Microsoft Project, Excel, and Outlook
Basic knowledge in Microsoft Word and PowerPoint
Engineering degree or equivalent
Ability to adopt and execute a structured working methodology
Fluent verbal and writing language skills in native language and English
Strong communication skills
Excellent interpersonal and leadership skills
Self motivated and self driving
19.
Product Marketing Manager –Beijing/Shanghai/Shenzhen1个)
Job Description
The Product Marketing Manager will define and execute winning strategies for PCIe SSD storage products in the Asia Pacific marketplace. The PMM will drive customer design wins at targeted end customers, OEMs and SI/VAR Channel. This person is responsible for Proof of Concept (POC) and pre-sales activities, forecasting revenue, and speaking at marketing events. The PMM will support sales by developing marketing tools, creating pricing strategies and proposals, and facilitating product demonstration and evaluation. This person will operate cross-functionally with multiple LSI organizations including Product Management (internal), Corporate Marketing, Channel Marketing and Sales
- Over 10 years experience with 5+ years technology product marketing experience. Enterprise storage solution sales/marketing role in the last 3 years is a plus
- MBA desired
- Willingness to travel over 30% of the time
- Experience in enterprise storage solution technologies: Oracle/SAP database, virtualization, caching software, SAN and NAS. Knowledge of solid state storage a plus
- Demonstrated ability to establish strong end user customer and partner relationships, data center customer engagement experience highly desired
- Strong leadership skills. Drive to succeed, achievement orientation, self-motivation.
- Systems thinking, with the ability to identify and unravel issues before they hit the schedule.
- A positive, energetic, can-do attitude. Not requiring a lot of hand-holding.
20.
Product Quality Engineer-Shenzhen/Shanghai
JD
Review/Approve/Improve Supplier NPI/ODM/CM manufacturing/Supplier product and process quality
Key Supplier quality interface with NPI Engineering, providing critical Quality Input into NPI Phases.
Review/Improve/Audit/manage Supplier/ODM/CM Manufacturing Site Quality
Develop/Train/Improve Supplier/ODM/CM quality processes
On-site support for FAI, quality issue management
Frequent communication with Taiwan, China and US.
On-site support/Review/Improve/audit SOUTH Asia CM/ODM/NPI Electronics Manufacturing
Track and report on a monthly basis
Supplier performance through DPPM/MTBF/AFR goals.Supplier performance through their in-process metrics as applicable
Provide analytical summary and recommendations based on metrics
Perform on-site supplier, Assessments, audits and surveys.
Analyze supplier process for quality constraints and recommend improvements
Verify corrective action implementation for past quality or audit issues
Perform qualification surveys of new suppliers
Drive corrective actions to root cause and closure.
Conduct periodic meetings with suppliers/ quality teams/ supplier and LSI management
Manage audit, survey, and quality plan schedules.
Develop detailed quality plans and monitor supplier’s compliance to the plan.
Provide input to Quarterly Score Card
JR
BSEE or above, or Scientific discipline
Strong demonstrated Engineering and Technical skills appropriate for the assignment
Strong Quality Tools and Data Analytics skills
Excellent accountability and project management skills
Outstanding Relationship Management abilities
Demonstrated competency with quality terminology such as but not limited to:
Common Cause
Special Cause
Root Cause Analysis
Demonstrated competency with elements of ISO
Demonstrate competency with quality management tools and their limitations such as, but not limited to:
SPC,
CpK
Pareto ranking
FMEA
Process Management
DPPM
MTBF AFR
Must have excellent verbal and written skills.
Proficient with Microsoft Access, Excel, PowerPoint and Word
5 years Experience with all forms of Electronics Manufacturing, Process and Quality issue management
Excellent and fluent in English and Mandarin
 楼主| 发表于 2012-7-11 16:02:30 | 显示全部楼层
各位同学,有问题可直接联系我。另外,欢迎推荐啊!
GMT+8, 2025-12-23 12:59 , Processed in 0.018658 second(s), 5 queries , Gzip On, Redis On.
