查看: 27786|回复: 72
ubuntu 12.04 amd64 cadence ic5141 usr6安装
发表于 2012-6-23 12:07:05 | 显示全部楼层 |阅读模式
最近看ubuntu 12.04 出来了,忍不住,装了下玩玩。同时试了一些EDA软件。附件是折腾cadecnce ic5141的过程,希望有人需要。
IC5141 USR6在UBUNTU 12.04下安装.doc
20.5 KB, 下载次数: 1003 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2012-7-15 13:31:55 | 显示全部楼层
搂主,按照你的文档,我也在ubuntu12.04LTS 桌面版中安装来ic5141 use6.
但是安装过程中有下面问题:
64)  34570: Virtuoso(R) Analog VoltageStorm Option  412854    available (lnx86)
65)  34580: Virtuoso(R) Analog ElectronStorm Option 412854    available (lnx86)
66)  70000: Virtuoso(R) AMS Designer Environment    543811    available (lnx86)
67)  70110_64bit: 64bit Dracula(R) Design Rule Chec 538991    available (lnx86)
68)  70110: Dracula(R) Design Rule Checker          1218754   available (lnx86)
69)  70120_64bit: 64bit Dracula(R) Layout Vs. Schem 618419    available (lnx86)
70)  70120: Dracula(R) Layout Vs. Schematic Verifie 1294731   available (lnx86)
71)  70130_64bit: 64bit Dracula(R) Parasitic Extrac 592886    available (lnx86)
72)  70130: Dracula(R) Parasitic Extractor          1273056   available (lnx86)
73)  70510_64bit: 64bit Dracula(R) Physical Verific 648826    available (lnx86)
74)  70510: Dracula(R) Physical Verification Suite  1322872   available (lnx86)
75)  70520_64bit: 64bit Dracula(R) Physical Verific 755556    available (lnx86)
76)  70520: Dracula(R) Physical Verification and Ex 1424579   available (lnx86)
77)  71110_64bit: 64bit Diva(R) Design Rule Checker 104077    available (lnx86)
78)  71110: Diva(R) Design Rule Checker             757652    available (lnx86)
79)  71120_64bit:                                   119167    available (lnx86)
80)  71120: Diva(R) Layout Vs. Schematic Verifier   700531    available (lnx86)
81)  71130: Diva(R) Parasitic Extractor             547297    available (lnx86)
82)  71510: Diva(R) Physical Verification Suite     822144    available (lnx86)
83)  71520: Diva(R) Physical Verification and Extra 827846    available (lnx86)
84)  90001: Virtuoso(R) Multi-mode Simulation       1156139   available (lnx86)
Are your selections correct? [y/n]
Please press y (yes) or n (no) :
Please press y (yes) or n (no) : y
Generating detailed installation data...
Determining available disk space
sort: 打开失败: +2: 没有那个文件或目录
Determining required disk space
Disk checks successful
然后。下面一步有下面问题:
Checking data files...
Executing control programs (pre-load) ...
sort: 打开失败: +3: 没有那个文件或目录
expr: 语法错误
SL-8: No information available on :.
Call the Cadence Customer Response Center (CRC) at 1-800-Cadenc2
(1-800-223-3622) to get the right /home/hxw/cadence_ic5141/install/tmp/mediaMap.lnx86 file.
请问是什么原因?是不是解压安装文件一定要在ubuntu中解压?还有这个提示是表示:安装文件不完整吗?
谢谢!
发表于 2012-7-19 08:52:24 | 显示全部楼层
Thanks for sharing, I am using ubuntu
发表于 2012-7-19 10:23:00 | 显示全部楼层
Thanks!!!!!!!!!!!!!!!!!!!!
发表于 2012-7-22 15:17:52 | 显示全部楼层
问题原因找到了:
      cadence 官方支持的系统中,32位的系统,只支持redhat4;64位的系统中支持的比较多,可以支持高于4的版本。所以ubuntu12.04的64位操作系统是可以安装ic5141的,而我用unbuntu 12.04 的32位的系统安装失败。已经改用redhat AS4 update 7系统,安装ic5141成功。
发表于 2012-7-23 16:49:33 | 显示全部楼层
尝试一下
发表于 2012-7-26 10:44:33 | 显示全部楼层
发表于 2012-9-3 11:02:44 | 显示全部楼层
谢谢你
发表于 2012-9-9 13:12:19 | 显示全部楼层
回复 1# snobi
  能发个IC user6给我吗?正需找中。。。
发表于 2012-9-14 03:09:15 | 显示全部楼层
尝试一下, 谢谢!
GMT+8, 2025-12-30 08:04 , Processed in 0.029059 second(s), 6 queries , Gzip On, Redis On.
