查看: 1752|回复: 0
[招聘] 【社会招聘】LSI诚招Digital Design Engineer
发表于 2012-6-1 11:09:25 | 显示全部楼层 |阅读模式
有意者,请将简历发至:Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:http://www.weibo.com/u/1752448637
1.
Job Description
- Candidates for this position should have experience in the design and design management of large, high-speed, mixed signal SoCs. The designs must have contained a variety of both hard and soft-macro IP blocks. The candidate should be an expert in all parts of the SoC flow from IP deliverable hand-offs (in RTL or gate), to synthesis, DFT and test insertion, floorplanning, P&R, timing closure, signal integrity, power analysis and verification. After at least 5 years of design experience the candidate should have 3 years of design management experience. MS or higher degree in EE is required.
Requirements/Qualifications (Education)
- MSEE or higher degree in EE required.
2.
Job Description
- Working with an Architecture/Algorithm Development Team to finalize system architecture
- for optimal implementation of digital signal processing algorithms, including architectural
- Definition and tradeoffs, die size, power estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,formal verification and static timing analysis. Unix shell, Perl scripting, C/RTL co-simulation.
- Sound theory background of communication and Digital signal processing
GMT+8, 2025-12-23 06:37 , Processed in 0.016236 second(s), 5 queries , Gzip On, Redis On.
