查看: 3213|回复: 9
[资料] 發本書high k dielectric 的書
发表于 2012-5-18 23:39:08 | 显示全部楼层 |阅读模式
受惠於站上的先進太多...回饋一些東西....發本high-k dielectric的書
Amazon 網址:
http://www.amazon.com/Bias-Temperature-Instabilities-MOSFETs-high-k-dielectrics-Temperature/dp/383836404X/ref=sr_1_3?s=books&ie=UTF8&qid=1337354432&sr=1-3
Bias-Temperature-Instabilities in MOSFETs with high-k dielectrics: Electrical behavior, modeling and process impact under Bias Temperature stress in high-k metal gated MOSFETs
Book Description[size=0.86em]Publication Date: June 22, 2010
New MOSFET architectures are presently being developed in which dielectrics with high permittivity are introduced to replace SiO2-based dielectrics, which are at the end of the scaling roadmap, and where also metal gates are used to replace poly-Si gate to avoid poly-depletion effects. Key in the success of this development is the electrical behavior of such high k/metal gate devices, and more specifically the Bias-Temperature- Instabilities, which are well-known reliability problems in MOS gate stacks. In this thesis, these Bias-Temperature effects will be investigated: the electrical behavior of the devices under Bias- Temperature stress will be characterized, models to explain the instability effects will be developed, the impact of processing, material composition and deposition techniques, annealing conditions etc. will be investigated, and ways to improve these BTI effects will be proposed. This work should ultimately lead to optimized gate stacks with higher BTI robustness
Bias-Temperature Instabilities in MOSFETs with high-k dielectrcs.pdf
8.68 MB, 下载次数: 91 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2012-5-19 17:06:30 | 显示全部楼层
很专业  专业非专业人士看不懂
发表于 2012-5-19 18:09:47 | 显示全部楼层
谢谢共享。
发表于 2012-5-20 07:00:49 | 显示全部楼层
谢谢共享。
发表于 2012-5-20 13:53:24 | 显示全部楼层
好东西
发表于 2012-5-21 19:52:35 | 显示全部楼层
高K材料是研究热点,了解一下!
发表于 2016-9-13 22:54:43 | 显示全部楼层
非常不错
发表于 2016-9-13 23:50:09 | 显示全部楼层
Thanks, useful text.
发表于 2016-9-13 23:56:51 | 显示全部楼层
Useful.
发表于 2018-10-4 02:43:57 | 显示全部楼层
Great
GMT+8, 2025-12-28 12:20 , Processed in 0.026038 second(s), 7 queries , Gzip On, Redis On.
