查看: 1951|回复: 0
[招聘] Cadence BJ 招聘研发工程师
发表于 2012-5-17 11:37:38 | 显示全部楼层 |阅读模式
1. Member of consulting staff for RF simulator (Location: BJ)
Job Description
The position is for analog circuit simulation engineer responsible for designing, implementing and maintaining SPICE-like circuit simulation software for use with analog, RF and mixed signal circuit simulators. The engineer will be responsible for leading multiple development efforts through the development process, including writing specifications based on marketing and product requirements, designing and implementing product improvements and fixes, and working with a cross-functional team to ensure the software is tested, integrated and documented. The engineer must be proficient in C/C++ Unix development, and have a thorough knowledge of numerical methods for analog circuit simulation. The engineer must have a proven ability to learn from and work with an engineering and cross-functional team to deliver innovative products in a production environment.
Position Requirements
1.Prior experience in development of Spice or steady-state (harmonic balance, shooting, noise) simulation technologies;
2.Strong understanding of matrix solvers and numeric calculations;
3.Familiarity with Spice or Spectre net list format and usage;
4.Skilled in C++ programming, familiar with development under Linux/Unix
5.Familiarity with Analog, RF or microwave design is a strong plus;
6.Good English communication skill both verbally and writing;
7.Good problem solving skill and team work spirit;
8.Education Requirement: PhD in EE, CS, or related.
If you have interest,PLS send your CV to zhangyl@cadence.com
2. Member of Consulting Staff (Location: BJ)
Position Description
-The position is for analog circuit simulation engineer responsible for designing, implementing and maintaining device compact models in SPICE-like circuit simulation software for use with analog, RF and mixed signal circuit simulators. The engineer will be responsible for leading multiple development efforts through the development process, including writing specifications based on marketing and product requirements, designing and implementing product improvements and fixes, and working with a cross-functional team to ensure the software is tested, integrated and documented. The engineer must be proficient in C/C++ Unix development, and have a thorough knowledge of device physics, device compact models. The engineer must have a proven ability to learn from and work with an engineering and cross-functional team to deliver innovative products in a production environment.
1.Well devices physics, device compact models;
2.Familiar with matrix solver & mathematic calculation;
3.Familiar with Spice, Spectre format & usage;
4.Skilled in C++ programming, familiar with development under Linux/Unix environment;
5.Be familiar with Analog-signal design is a plus;
GMT+8, 2025-12-21 16:06 , Processed in 0.011069 second(s), 3 queries , Gzip On, Redis On.
