查看: 3662|回复: 1
[招聘] 漕河泾美资公司资深版图职位
发表于 2012-5-17 10:40:23 | 显示全部楼层 |阅读模式
Sr.IC Layout Designer---NO.82 上海
Purpose:
The primary objective of this role is to transform IC schematics and related design material into physical IC layout representations.
Responsibilities:
1. Perform challenging IC mask design of advanced analog mixed signal and flash memory IC'S
2. Develop layout floor plans to optimize die size and circuit performance;
3. Plan and construct circuits, including critical signal and power bussing to analog layout guidelines;
4. Perform DRC and LVS verification of layout;
5. Other duties and when required.
Requirements:
1. Thorough understanding of IC layout design including use of CAD tools such as DRC, LVS and skill programs
2. Must be good at problem solving
3. Must have the ability to communicate effectively
4. Minimum of 4 years experience in IC layout. Use of cadence Virtuoso XL, Calibre Drc.
Other Attributes
Use of Cadence Virtuoso-XL, P-cells, Calibre DRC/LVS Qualification Bachelor Degree or higher preferred
有兴趣可以发简历到hamy_wang@126.com,Q:577477313
发表于 2012-5-28 09:27:22 | 显示全部楼层
回复 1# hamy
在校学生啊
GMT+8, 2025-11-15 16:34 , Processed in 0.018738 second(s), 6 queries , Gzip On, Redis On.
