查看: 9467|回复: 4
Calibre201103 安装求助
发表于 2012-5-6 16:46:27 | 显示全部楼层 |阅读模式
各位好,我按照 http://bbs.eetop.cn/viewthread.php?tid=311773 这个帖子安装了Calibre201103
.bashrc如下:
##############Mentor Calibre201103##############################
alias lmlim1='/home/Cicy/Soft/Mentor/Calibre_2011/x86_cal_2011.3_18.12/bin/lmgrd  -c  /home/Cicy/Soft/Mentor/licenses/calibre.dat'
alias lmlim2='/home/Cicy/Soft/Mentor/Calibre_2011/x86_cal_2011.3_18.12/bin/lmstat -c  /home/Cicy/Soft/Mentor/licenses/calibre.dat'
export MGC_HOME=/home/Cicy/Soft/Mentor
export CALIBRE_HOME=/home/Cicy/Soft/Mentor/Calibre_2011/x86_cal_2011.3_18.12
export MGLS_LICENSE_FILE=/home/Cicy/Soft/Mentor/licenses/calibre.datMGLS_LICENSE_FILE
export PATH=$CALIBRE_HOME/binPATH
##########Sentaurus license############################
SEN_HOME=/home/Cicy/Soft/Synopsys/Sentaurus
export PATH=$PATHSEN_HOME/bin
SCL_HOME=/home/Cicy/Soft/Synopsys/Sentaurus/linux
export PATH=$PATH:$SCL_HOME/bin
export SNPSLMD_LICENSE_FILE=27000@localhost
LM_LICENSE_FILE=/home/Cicy/Soft/Synopsys/Sentaurus/admin/license/synopsys.dat
export LM_LICENSE_FILE
STDB=/home/Cicy/Work/STDB
export STDB
LANG=en_US
export LANG
运行lmlim1时显示
  0:35:20 (lmgrd) license manager: can't initialize:Cannot find license file.
0:35:20 (lmgrd) The license files (or license server system network addresses) attempted are
0:35:20 (lmgrd) listed below.  Use LM_LICENSE_FILE to use a different license file,
0:35:20 (lmgrd) or contact your software provider for a license file.
0:35:20 (lmgrd) Filename: "/usr/local/flexlm/licenses/license.dat"
0:35:20 (lmgrd) License Path: "/usr/local/flexlm/licenses/license.dat"
0:35:20 (lmgrd) FLEXnet Licensing error:-1,359
0:35:20 (lmgrd) System Error:2 No such file or directory
0:35:20 (lmgrd) For further information, refer to the FLEXnet Licensing documentation,available at "www.acresso.com".
0:35:20 (lmgrd) Using license file "/usr/local/flexlm/licenses/license.dat"
不知道为什么lmgrd总是去用/usr/local/flexlm/licenses/license.dat这个license,并且根本没有这个文件
如果把license放到这个位置再运行lmlim1
0:38:12 (lmgrd) FLEXnet Licensing (v11.6.1.0 build 66138 i86_re3) started on localhost.localdomain (linux) (5/7/2012)
0:38:12 (lmgrd) Copyright (c) 1988-2008 Acresso Software Inc. All Rights Reserved.
0:38:12 (lmgrd) US Patents 5,390,297 and 5,671,412.
0:38:12 (lmgrd) World Wide Web:  http://www.acresso.com
0:38:12 (lmgrd) License file(s): /usr/local/flexlm/licenses/license.dat
0:38:12 (lmgrd) lmgrd tcp-port 1357
0:38:12 (lmgrd) Starting vendor daemons ...
0:38:12 (lmgrd) Started mgcld (internet tcp_port 46061 pid 6216)
[Cicy@localhost ~]$  0:38:12 (mgcld) FLEXnet Licensing version v11.6.1.0 build 66138 i86_re3
0:38:12 (mgcld) License server system started on localhost
0:38:12 (mgcld) No features to serve, exiting
0:38:12 (mgcld) EXITING DUE TO SIGNAL 36 Exit reason 4
0:38:12 (lmgrd) mgcld exited with status 36 (No features to serve)
0:38:12 (lmgrd) mgcld daemon found no features.  Please correct
0:38:12 (lmgrd) license file and re-start daemons.
0:38:12 (lmgrd)
0:38:12 (lmgrd) This may be due to the fact that you are using
0:38:12 (lmgrd) a different license file from the one you expect.
0:38:12 (lmgrd) Check to make sure that:
0:38:12 (lmgrd) /usr/local/flexlm/licenses/license.dat
0:38:12 (lmgrd) is the license file you want to use.
是在搞不懂是什么原因阿,是不是path不完全阿,path时候只有两个文件修改了。
求教
发表于 2012-5-6 19:44:29 | 显示全部楼层
0./usr/local/flexlm/licenses/license.dat是lmgrd預設license file的路徑及檔名 !!
1.您確定license file有放置在/home/Cicy/Soft/Mentor/licenses/calibre.dat ??
2.先不用lmlim1試試,打開shell終端
cd  /home/Cicy/Soft/Mentor/Calibre_2011/x86_cal_2011.3_18.12/bin
./lmgrd  -c /home/Cicy/Soft/Mentor/licenses/calibre.dat
提供參考 !!
 楼主| 发表于 2012-5-7 11:17:22 | 显示全部楼层
你好,解决了,是因为系统里面自启动了一个lmgrd进程,我把它关了就好了
发表于 2012-7-10 15:33:25 | 显示全部楼层
值得参考!
发表于 2014-1-20 20:39:41 | 显示全部楼层
您好 请问怎么关掉 我一直没找到
GMT+8, 2025-11-7 17:06 , Processed in 0.061160 second(s), 7 queries , Gzip On, Redis On.
