查看: 11512|回复: 17
[讨论] hspice cpu比快大賽
发表于 2012-5-5 09:47:03 | 显示全部楼层 |阅读模式
hspice cpu比快大賽  , 一般測 cpu都用 super pie ..沒看過用 spice 做 benchmark
先前有拿到朋友一個 cpu  test 資料
可能來評沽 server cpu 要買那類會較快
拿 hspice 來比 ,  想知道不同 cpu  os 下要跑多久
hspice sim 時間看 hspice list file
格式  hspice_version /  OS/  cpu +clock /  RAM  / sim_time
ex
hspice 2009.03 / centOS5 /   Q6600   2.4G  / 4G  /      993s
hspice 2009.03 / win2000 / Q6600  2.4G /  2G  / 1400s
hspice 2009.03  /  centos 4.5 x64 / I7 920 4G  / 4G /   238.31s
hspice 2009.03 /  redhat 8 / Pentium4   3GHz / 2G /   1131s
hspice 2009.03 / RHEL4 x64 /  opteron252  2.6G  / 8G /    727s
hspice 2009.03  / RHEL4  / xeon ex4400  2.4G   /  ?  /     508.2sec
另外如果有 hsim , eldo  , tspice , adit   smartspice  ,也一起來 test 看看
就拿 hspice 本身的 example 來 ,  see    pll.rar (1.12 KB , 下载次数: 30 )
attach file is pll.sp
下面就是 pll.sp
.option  post probe
$ wideband FM example, Grebene gives:
$  f0=1meg kf=250kHz/V
$  kd=0.1 V/rad
$  R=10K C=1000p
$  f_lock = kf*kd*pi/2 = 39kHz, v_lock = kd*pi/2 = 0.157
$  f_capture/f_lock ~= 1/sqrt(2*pi*R*C*f_lock)
$                    = 0.63,    v_capture ~= 0.100
.tran 0.01u 25000u
.option runlvl=5
.option delmax=0.01u
.probe v_in=v(inc,0) v_out=v(out,outb)
.probe v(in) v(osc) v(mout) v(out) v(e)
vcc vcc 0 6
vee vee 0 -6
$ input
vin inc 0 pwl 0u,-0.2 500u,0.2
xin inc 0 in inb vco f0=1meg kf=125k phi=0 out_off=0 out_amp=0.3
$ vco
xvco1 e eb osc oscb 0 vee vco1
.ic v(osc)=-1.4 v(oscb)=-0.7
$ phase detector
xpd1 in inb osc oscb mout moutb vcc vee pd1
$ filter
rf mout e 10k
cf  e   0 1000p
rfb moutb eb 10k
cfb eb   0 1000p
$ final output
rout out e 100k
cout out 0 100p
routb outb eb 100k
coutb outb 0 100p
.subckt vco in inb out outb f0=100k kf=50k phi=0.0 out_off=0.0 out_amp=1.0
gs 0 s poly(2) c 0 in inb    0 '6.2832e-9*f0' 0 0 '6.2832e-9*kf'
gc c 0 poly(2) s 0 in inb    0 '6.2832e-9*f0' 0 0 '6.2832e-9*kf'
cs s 0 1e-9
cc c 0 1e-9
e1 s_clip 0 pwl(1) s 0  -0.1,-0.1 0.1,0.1
e out 0 s_clip 0 out_off '10*out_amp'
eb outb 0 s_clip 0 out_off '-10*out_amp'
.ic v(s)='sin(phi)' v(c)='cos(phi)'
.ends
.subckt vco1 in inb e7 e8 vcc vee vco_cap=228.5p
qout vcc vcc b7 npn1
qoutb vcc vcc b8 npn1
rb vcc c0 5k $ 1ma
q0 c0 b0 vee npn1
q7 vcc b7 e7 npn1
r4 vcc b7 1k
i7 e7 0 1m
q8 vcc b8 e8 npn1
r5 vcc b8 1k
i8 e8 0 1m
q9 b7 e8 e9 npn1
q10 b8 e7 e10 npn1
c0 e9 e10 vco_cap
q11 e9 in 2  npn1
q12 e10 in 2 npn1
q15 2 c0 b0 npn1
q16 3 c0 b0 npn1
rx 2 3 8k
q13 vcc inb 3 npn1
q14 vcc inb 3 npn1
rt b0 vee 350
.ends
.model npn1 npn
+ eg=1.1 af=1 xcjc=0.95 subs=1
+ cjs=0 tf=5p
+ tr=500p cje=0.2p cjc=0.2p fc=0.8
+ vje=0.8 vjc=0.8 mje=0.33 mjc=0.33
+ rb=0 rbm=0 irb=10u
+ is=5e-15 ise=1.5e-14 isc=0
+ vaf=150 bf=100 ikf=20m
+ var=30 br=5 ikr=15m
+ rc=0 re=0
+ nf=1 ne=1.5 nc=1.2
+ tbf1=8e-03
.subckt pd1 in inb in2 in2b out outb vcc vee
rl vcc n1 1k
rlb vcc n1b 1k
q3 n1  in  c1 npn1
q4 n1b inb c1 npn1
q5 n1  inb c2 npn1
q6 n1b in  c2 npn1
q1 c1 in2  e npn1
q2 c2 in2b e npn1
ie e 0 0.5m
c1 n1 0 1p
c1b n1b 0 1p
q7 vcc n1 e7 npn1
q8 vcc n1b e8 npn1
r1 e7 out 625
r2 out vee 300
r1b e8 outb 625
r2b outb vee 300
.ends
.end
 楼主| 发表于 2012-5-6 13:15:08 | 显示全部楼层
沒人想知道嗎
我是很想知道 不同 cpu
跑 hspice 會差多少
发表于 2012-5-6 17:57:14 | 显示全部楼层
2011.09/Win7 X64/Athlon X2 245/ 2.9G/3G/ 654.34 seconds
用的BIN64下的hspice.exe
 楼主| 发表于 2012-5-6 20:44:39 | 显示全部楼层
thank you
有沒有 新 i7 cpu + linux os ?
发表于 2013-3-12 07:54:34 | 显示全部楼层
回复 4# andy2000a
Intel I7 920  2.6G o 4G  cent 4.5 64bit   238.31s
Intel T5600   1.83G    RHEL4   cputime 1012.9s
amd 6core 1055T  2.8GHZ RHEL4.5 x64    cputime 555.59s
intel i7-2670QM  2.2G burst 2.97G win7   485.82sec
intel I7 930 2.8G  rhel4.8  cputime  345s
intel E5020  2G   rhel4.8  cputime  495sec
Inetl I5 3.1G centOS 64  263.3sec
Intel I7 3770k 3.9 over clock 4.5G  cent 64  cputime=185.46sec
Intel I7 3770k 3.9 o 4.7G  centOS 64 175.92s
Intel I7 3770k 3.9 o 5G  cent 64   164.99s
Intel i72 3770k over 4.2G  cent64 208~213s
有沒有人有 AMD FX8250 ?  8150
发表于 2013-3-12 09:26:14 | 显示全部楼层
最好找一个有包括mosfet的例子,仿真工具在不同的精度设置,电路规模,多核设置的情况下表现都不一样
发表于 2013-3-13 13:05:18 | 显示全部楼层
用过,推土机确实不咋地回复 5# peterlin2010
发表于 2014-3-12 18:14:58 | 显示全部楼层
kamyixia
 楼主| 发表于 2014-3-13 21:07:39 | 显示全部楼层
目前 同CLOCK 下 INTEL I7 最快..
至於 AMD CPU 慢多
不過 Intel ATOM 更是慢 . but bay trail 還不知道 如何?
发表于 2015-7-28 11:16:04 | 显示全部楼层
cpu core 多就快了吧!
GMT+8, 2025-12-27 02:16 , Processed in 0.024503 second(s), 7 queries , Gzip On, Redis On.
