查看: 6277|回复: 10
[求助] Verilog同步问题求助(新手)
发表于 2012-4-19 16:14:17 | 显示全部楼层 |阅读模式
这是老师布置的一个习题了,不多说,看问题和代码就是了:
作业题目:帧同步搜索电路
设计要求:
输入数据data8 bit并行数据流,基本结构为数据帧,帧长为10字节,帧同步字为HFF”。clk为输入同步时钟。如下图所示:
真的“帧同步”
假的“帧同步”
1、搜索出数据流中的帧同步字信号,并给出帧同步标志。
2、系统工作开始后,要连续3次确认帧同步字进入锁定状态后才输出帧同步标志。
3、在锁定状态时,如连续出现3次错误的帧同步字,则帧同步标志输出无效,系统重新进入搜索状态;否则继续输出有效的帧同步标志。
4、过滤掉虚假的帧同步字(数据载荷中随机的HFF”)。
5、完成综合后的时序仿真验证。
代码:
`timescale 100ns/1ns
module pace(flag,clk,data);
parameterL = 8 ;
outputflag;
inputclk;
input[L-1:0] data;
parameters0 = 4'b1111 , s1 = 4'b0001 , s2 = 4'b0010 ,
s3 = 4'b0011 , s4 = 4'b0100 , s5 = 4'b0101 ,
s6 = 4'b0110 , s7 = 4'b0111 , s8 = 4'b1000 ,
s9 = 4'b1001 , s10 = 4'b1010 ;
parameterFF = 8'hFF;
reg[2:0] current_state,next_state;
reg[L-1:0] data_t,data_s;
regflag;
regi;
always @ (posedge clk)
begin
data_s<= data;
end
current_state<= next_state;
case(current_state)
s10:next_state <= s0;
s0:
if(data_t== FF)
next_state<= s1;
else
next_state<= s2;
s1:
if(data_t== FF)
next_state<= s3;
else
next_state<= s4;
s2:begin
next_state<= s0;
end
s3:
if(data_t== FF)
next_state<= s5;
else
next_state<= s6;
s4:begin
next_state<= s2;
end
s5:
if(data_t== FF)
next_state<= s5;
else
next_state<= s7;
s6:begin
next_state<= s2;
end
s7:
if(data_t== FF)
next_state<= s5;
else
next_state<= s8;
s8:
if(data_t== FF)
next_state<= s5;
else
next_state<= s9;
s9:
if(data_t== FF)
next_state<= s1;
else
next_state<= s2;
default:
next_state<= s0;
endcase
case(current_state)
s10:
begin
i<= 0;
flag<= 0;
end
s0:
begin
data_t<= data_s;
flag<= 0 ;
end
s1:
begin
i<= i + 10;
data_t<= data_s;
flag<= 0;
end
s2:
begin
i<= i + 1;
data_t<= data_s;
flag<= 0;
end
s3:
begin
i<= i + 10;
data_t<= data_s;
flag<= 0;
end
s4:
begin
flag<= 0;
end
s5:
begin
i<= i + 10;
data_t<= data_s;
flag <= 1;
end
s6:
begin
flag<= 0;
end
s7:
begin
i<= i + 10;
data_t<= data_s;
flag<= 1;
end
s8:
begin
i<= i + 10;
data_t<= data_s;
flag<= 1;
end
s9:
begin
i<= i + 10;
data_t<= data_s;
flag<= 0;
end
endcase
endmodule
testbench为:
module pace_test();
regclk;
wireflag;
parametert = 100;
//integerindex = 0;
integerindex ;
parameterN = 8,M = 100;
reg[7:0] data_v = 800'hFF0405060708FF010203FF040506FF0809010203FF040506070809010203FF040506070809010203FF040506070809010203FF040506070809010203FF040506070809010203FF040506070809010203FF040506070809010203FF040506070809010203;
always #t clk = ~clk ;
/*always #t
begin
data[7+ N * index : 0 + N * index] <= data_v[7 + N * index : 0 + N * index];
index<= index + 1;
end
always @(posedge clk or index)
begin
for(index= 0 ; index < M ; index = index + 1)
end
initial
begin
for(index = 0 ; index < M ; index = index + 1 )
#tdata[7 + index * N : 0 + index * N ] = data_v[7 + index * N : 0 + index * N ];
end
pacezhen(.data(data),.flag(flag),.clk(clk));
endmodule
原代码可以通过编译,但testbench老式报错,具体错误请看图了
发表于 2012-4-19 17:05:12 | 显示全部楼层
有点复杂的,整个架构图出来先。
发表于 2012-4-19 17:13:17 | 显示全部楼层
看上去挺复杂的。
发表于 2012-4-19 18:35:31 | 显示全部楼层
没看内容  真多啊 这个错 应该是 变量定义的 问题
输出data 应该定义成 reg 型
发表于 2012-4-20 12:01:58 | 显示全部楼层
对,看了几遍好象没有data的定义的说,不知道是不是忘记了。
 楼主| 发表于 2012-4-21 12:09:03 | 显示全部楼层
回复 5# gaurson   定义了啊,是[7:0]data 啊,我修改了testbench,能出结果了,就是与想要得结果不一致。新的testbench请看原文,一修改了。
发表于 2012-4-22 11:35:44 | 显示全部楼层
这个跟检测出10010有啥区别吗?
发表于 2012-4-23 11:56:29 | 显示全部楼层
看不到波形文件
发表于 2012-5-11 21:27:58 | 显示全部楼层
呵呵,UESTCer.
发表于 2017-5-3 17:08:35 | 显示全部楼层
朋友这个问题解决了吗?能不能看一看???
GMT+8, 2025-12-14 11:42 , Processed in 0.038161 second(s), 9 queries , Gzip On, Redis On.
