查看: 9009|回复: 15
Can ic6141/ic6151 be successfully setup in RHEL5.4 64bit?
发表于 2012-4-19 14:26:09 | 显示全部楼层 |阅读模式
i trid but failed ,both ic6141 and ic6151 give the same error message :
[user@localhost ~]$ virtuoso
/eda/IC6141/tools/dfII/bin/32bit/virtuoso: symbol lookup error: /eda/IC6141/tools/QT/lib/libQtGui.so.4: undefined symbol: XRenderFindStandardFormat
who can tell me why?
does anyone successfully setup  ic6141/ic6151in other platfrom? could you pls share your experience?
发表于 2012-4-19 16:06:08 | 显示全部楼层
setenv CDS_AUTO_64BIT ALL
发表于 2012-5-1 07:38:08 | 显示全部楼层
請問 IC610 能在 rhel  or centOS6 上跑起來嗎 ?
发表于 2012-5-4 06:50:48 | 显示全部楼层
i can get it work on ubuntu 32bit
发表于 2012-5-5 08:34:12 | 显示全部楼层
My system is Scientific Linux 5.7 _64bit and everything is fine. All programs working in 64bit mode. Here is list:
-        Cadence (IC615.500.4, EDI10, MMSIM10, ASSURA, IUS9.2, ..)
-        Mentor (QuestaSim10.1, Calibre2011.2.34, Catapult, ..)
-        Agilent (ADS2011.10)
-        Matlab2012a
-        Xilinx ISE Design Suite 13.4
-        Synopsys in plan
发表于 2012-5-5 10:43:30 | 显示全部楼层
发表于 2012-5-5 10:44:24 | 显示全部楼层
why do you need 64-bit machines for cadence?anything specific?
发表于 2012-5-6 08:23:14 | 显示全部楼层
From Cadance:
1. Check to see how much swap and memory you have on your workstation.
At a minimum, we strongly recommend 2+GB RAM and 5+GB swap...and
more is better.
In MMSIM6.0, we now have a Spectre executable with 64 bit addressing. This
means no 4GB process size limit, but if the circuit is large, the RAM
requirements could get really high. With an RCX parasitic resimulation,
64 GB (Yes, GigaBytes) of RAM might be required to simulate a parasitic
resimulation.
What will be if you run simultaneously other progs?
发表于 2012-11-19 22:26:58 | 显示全部楼层
解決了嗎? 分享一下!
发表于 2013-1-30 23:12:55 | 显示全部楼层
thanks a lot
GMT+8, 2025-12-14 02:56 , Processed in 0.023792 second(s), 9 queries , Gzip On, Redis On.
