查看: 2101|回复: 0
[招聘] 【社会招聘】LSI上海研发中心Serdes Team最新职位
发表于 2012-4-16 16:49:11 | 显示全部楼层 |阅读模式
LSI上海研发中心Serdes Team是国内一流的设计团队,承接的项目都是业界最领先的。目前正在诚招以下工程师:
1.
1.
Serdes Analog/Mixed-signal Design Engineer (New!!!)
Job Description
- Design and simulate mixed-signal circuitry for high-speed transceiver cores or products
- Create design documents based on the mixed-signal design flow
- Supervise physical layouts of analog circuits
- Work with test engineers to validate designs in silicon
Requirements/Qualifications (Education)
- BSEE/MSEE with more than 2 years of direct experiences in design of mixed-signal circuits, such as high-speed transceivers, amplifiers, phase-locked loops, and digital-to-analog converters. Knowledge in high-speed Serdes is a plus
2.
Serdes
ASIC Design Engineer
(New!!!)
Job Description
- Looking for a candidate who is familiar with digital IC design methodologies, understands all stages of ASIC design flows, and is experienced with state-of-the-art design tools. The candidate has solid knowledge of timing closure and synthesis flow and is experienced in logic design and verification.
- Minimum requirements:* Knowledge of HDL and experience in behavioral and RTL coding, Verilog preferred
- Knowledge of logic synthesis and timing analysis.* DSP and communications background is a plus
- B.S. required, MS/Ph.D. a plus. At least 3 years of experience.
有意者,请将简历发至:Tracey.zheng@lsi.com
如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.
也可加我msn: zql975504@hotmail.com
或者微博啊:http://www.weibo.com/u/1752448637
GMT+8, 2025-12-21 06:59 , Processed in 0.016079 second(s), 4 queries , Gzip On, Redis On.
