查看: 20479|回复: 19
[讨论] 关于Cadence OA版本和软件Encounter、PVS的讨论
发表于 2012-4-15 21:26:12 | 显示全部楼层 |阅读模式
自己使用的RHEL4.8 64位的系统,安装了Encouter Digital Implimentation 10.12.002和IUS 10.20.030和Physical Verification System这三个软件。PVS 10.1是最后安装的,郁闷的地方就出现了。用论坛上的补丁对三个软件进行了破解后,Encounter使用没问题,IUS我只测试了nclaunch、simvision,ncelab,ncsim等,也没问题,IUS包含的其他软件还没有测试。最后使用PVS10.1的时候,问题就来了。
       敲入命令ipvs的时候,运行提示如下:
               === Host status report for process 27404 ===
   Total RAM available: 3884 MB
  Total Swap available: 1027 MB
Before main segment of ipvs, this process' parameters were:
           Page faults: 0
       Resident memory: 15184 kB
        Virtual memory: 105808 kB
          Memory usage:   2.659 %
        Total CPU time: 0:00:00.32
     Overall CPU usage:  88.888 %
Processes with most virtual memory were:
VM=3798  PID=19766 USER=liude    RSS=65    MEM%= 97.765 CPU= 0:07:32.89 CPU%=  7.808 FLT=      210
VM=3750  PID=19765 USER=liude    RSS=6     MEM%= 96.528 CPU= 0:00:00.77 CPU%=  0.013 FLT=        2
VM=3738  PID=19755 USER=liude    RSS=2     MEM%= 96.227 CPU= 0:00:00.02 CPU%=  0.000 FLT=        8
VM=3736  PID=19757 USER=liude    RSS=2     MEM%= 96.185 CPU= 0:00:00.03 CPU%=  0.000 FLT=        8
VM=226   PID=12960 USER=liude    RSS=38    MEM%=  5.837 CPU= 0:00:41.03 CPU%=  0.414 FLT=       58
VM=194   PID=13005 USER=liude    RSS=22    MEM%=  5.006 CPU= 0:02:34.26 CPU%=  1.574 FLT=       54
VM=193   PID=12998 USER=liude    RSS=23    MEM%=  4.969 CPU= 0:00:04.48 CPU%=  0.045 FLT=      304
VM=160   PID=12958 USER=liude    RSS=26    MEM%=  4.123 CPU= 0:00:06.54 CPU%=  0.066 FLT=       25
VM=158   PID=12967 USER=liude    RSS=8     MEM%=  4.090 CPU= 0:00:01.23 CPU%=  0.012 FLT=        6
VM=157   PID=12990 USER=liude    RSS=15    MEM%=  4.044 CPU= 0:00:13.74 CPU%=  0.138 FLT=        6
Swap usage (all processes):   0.000 %
After failure in main segment of ipvs, this process' parameters were:
           Page faults: 0
       Resident memory: 19460 kB
        Virtual memory: 114784 kB
          Memory usage:   2.885 %
        Total CPU time: 0:00:00.38
     Overall CPU usage:  80.851 %
Time since last report: 0:00:00.11
    Recent page faults: 0
      Recent CPU usage:  54.545 %
VM=3798  PID=19766 USER=liude    RSS=65    MEM%= 97.765 CPU= 0:07:32.90 CPU%=  7.808 FLT=      210 INTV= 0:00:00.10 IFLT=0 ICPU%= 10.000
VM=3750  PID=19765 USER=liude    RSS=6     MEM%= 96.528 CPU= 0:00:00.77 CPU%=  0.013 FLT=        2 INTV= 0:00:00.10 IFLT=0 ICPU%=  0.000
VM=3738  PID=19755 USER=liude    RSS=2     MEM%= 96.227 CPU= 0:00:00.02 CPU%=  0.000 FLT=        8 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=3736  PID=19757 USER=liude    RSS=2     MEM%= 96.185 CPU= 0:00:00.03 CPU%=  0.000 FLT=        8 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=226   PID=12960 USER=liude    RSS=38    MEM%=  5.837 CPU= 0:00:41.03 CPU%=  0.414 FLT=       58 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=194   PID=13005 USER=liude    RSS=22    MEM%=  5.006 CPU= 0:02:34.27 CPU%=  1.574 FLT=       54 INTV= 0:00:00.11 IFLT=0 ICPU%=  9.090
VM=193   PID=12998 USER=liude    RSS=23    MEM%=  4.969 CPU= 0:00:04.48 CPU%=  0.045 FLT=      304 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=160   PID=12958 USER=liude    RSS=26    MEM%=  4.123 CPU= 0:00:06.54 CPU%=  0.066 FLT=       25 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=158   PID=12967 USER=liude    RSS=8     MEM%=  4.090 CPU= 0:00:01.23 CPU%=  0.012 FLT=        6 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
VM=157   PID=12990 USER=liude    RSS=15    MEM%=  4.044 CPU= 0:00:13.74 CPU%=  0.138 FLT=        6 INTV= 0:00:00.11 IFLT=0 ICPU%=  0.000
========= End of status report =========
An exception has propagated all the way to the main segment of
  /home/EDATOOLS/cadence/PVS10.10.221/tools.lnx86/pvs/bin/64bit/ipvs
called with 1 arguments.
==== begin exception ====
Unknown exception in main.cpp, line 428
Details: Caught unknown exception
====   end exception ====
Execution aborted.  Exiting with status 1.
          可以看到没有提示license的问题,是二进制文件ipvs出现了问题,见红色的部分。后来查阅使用手册,发现需要设置正确的OA_HOME这一环境变量。我此时的OA_HOME设置的是encounter的oa路径,版本是22.41.011,之后改成PVS对应的OA版本,即22.41.001,再运行ipvs的时候,就提示没有license了。其说明文档里面说PVS的license string是Physical_Verification_Sys和Physical_Verification_Sys_Deb,我查了一下license,发现里面有这俩个feature。难道是启动license的cdslmd版本过高?之后,将license里面的cdslmd改成PVS对应版本的cdslmd。敲入ipvs命令,仍然提示没有license。大家看图。 Screenshot.png 我觉得有两种可能,一是破解补丁对PVS的破解不彻底;二是license里面的feature之后的字符串有问题。
          进行上述更改后,发现启动IUS10.2仍然没有任何问题,启动encounter的时候,提示OA软件的版本低,无法使用OA库相关的命令,但还可以走传统流程。真实郁闷极了,你说cadence一天升级OA库的版本干什么,吃饱了撑得难道是。
         总结一下,最好的方法就是论坛里面有大侠可以提供一个更新版本的PVS,然后破解补丁能更万能,就好了。
         高版本的Encounter不兼任低版本的OA工具(太说不过去了),低版本的PVS又不兼任高版本的OA工具(这还说的过去)。期待有高手能解决。或者有人能提供PVS的license。
发表于 2012-4-16 08:44:34 | 显示全部楼层
高版本的Encounter不兼任低版本的OA工具,这也有可能啊,工具到某一版可能改动比较大。
进来我发现EDI10.1用的OA版本比EDI9.1要低
发表于 2012-4-16 08:47:07 | 显示全部楼层
CDS的OA普及的不好,SNPS的Milkway普及的也不用好。
很少有用户使用这些通用的数据可吧
发表于 2012-4-16 09:26:42 | 显示全部楼层
我覺得最好不要設置OA_HOME這個env,自己可以alias一個命令加入OA PATH或者寫個啟動腳本,另外PVS不止這兩個feature的,可以搜索一下幫助文檔
发表于 2012-10-19 09:58:11 | 显示全部楼层
請求PVS破解补丁
发表于 2012-10-19 10:49:50 | 显示全部楼层
在这里小灌一下水
发表于 2012-10-19 16:33:42 | 显示全部楼层
不要设置OA_HOME,工具自动找到对应的OA安装路径
发表于 2013-2-22 10:33:17 | 显示全部楼层
弱弱问一下,pvs怎么安装,跟以前cadence的软件安装不一样啊。
发表于 2013-11-11 09:16:31 | 显示全部楼层
    楼主,能否告知你安装的是PVS哪个版本?patch工具是哪个?license里的feature需要那几个?非常感谢!!我安装的pvs10.1,已启动ipv就告知没有license可用,我的feature总共有如下几条: Physical_Verification_Sys Physical_Verification_Sys_L Physical_Verification_Sys_XL Physical_Verification_Sys_Deb.不知道是否就需要这几条feature 。
发表于 2013-11-11 11:18:52 | 显示全部楼层
Physical Verification System这个工具到底有什么作用啊?物理验证不是就是跑一下LVS和DRC、ERC之类的吗?现在应该是比较常用的是Calibre吧?这个是Cadence出的用来代替Dracula的吗?请LZ详细讲解一下吧
GMT+8, 2025-12-24 06:11 , Processed in 0.027021 second(s), 6 queries , Gzip On, Redis On.
