楼主: KHL
Plexim Plecs Standalone v3.2.7 win32/64 + Crack
发表于 2013-3-5 06:40:40 | 显示全部楼层
The bean crack does not work with all versions of Plecs. Till now the only version which works correctly is v3.2.3 x32 cracked the mtct (M a s t e r   T u r k i s h   C r a c k  T e a M) crack.
I use that for several months now and no license problem yet.
发表于 2013-3-9 15:42:40 | 显示全部楼层
回复 65# 1andro1
Can you share v3.2.3? Thanks!
发表于 2013-3-10 12:09:07 | 显示全部楼层
the bean crack works with a particular system date(s) only (lousy doctors..). for example 3.3.4 works if the date is say 20.12.2012. There is a small free program called runasdate that changes the date of the application, but doesn't touch the system date.  I've managed to run 3.3.4 in combination with runasdate.
发表于 2013-3-10 18:22:20 | 显示全部楼层
great job rp2004.
I have tried to change the system clk but Plecs complained about that and corrupted the files. Then I move to older version of Plecs.
发表于 2013-3-10 18:38:49 | 显示全部楼层
回复 66# tman2018
Do you still need v323 or you will use the rp2004 idea?
发表于 2013-3-10 21:12:55 | 显示全部楼层
maybe is a good idea to share 323_x32 and 323_x64 in case my method fails one day.
发表于 2013-3-10 22:49:37 | 显示全部楼层
回复 69# 1andro1
Hi, I still need 3.2.3 to give it a try. Thanks for the help!
发表于 2013-3-13 05:55:32 | 显示全部楼层
Here is the link for the package
http://dfiles.eu/files/573e12p7x
the crack is inside the archive.
发表于 2013-3-13 05:56:54 | 显示全部楼层
发表于 2013-3-13 06:09:10 | 显示全部楼层
I did not see that explanations for cracking are in turkish, so here is the english
after installing the plecs do not run it. copy the patch in the instal dir and run it and press patch. Unfortunately the comments in the patch are also in turkish but there should not be any problems. At least in my case was in that way.
Also plecs 323 does not opens the files from the v3.3.4 and upper
GMT+8, 2025-9-18 05:37 , Processed in 0.016513 second(s), 3 queries , Gzip On, Redis On.
