楼主: KHL
Plexim Plecs Standalone v3.2.7 win32/64 + Crack
发表于 2012-7-2 14:21:12 | 显示全部楼层
after some time of running it says "license problem detected" and closes up. something is wrong with the medicine
发表于 2012-7-3 22:56:59 | 显示全部楼层
has someone encountered the same "license problem detected" after say 5 minutes of running? I think there was a 30 day time limit embodied in the software that wasn't cured by the pill. If you move the PC's date say 2 months ahead you'll get the same message.
 楼主| 发表于 2012-7-4 22:58:51 | 显示全部楼层
之前安裝好能跑我就丟上來了
所以沒有測試調整日期後的狀況
有找到新的破解我會再丟上來
发表于 2012-7-5 01:28:34 | 显示全部楼层
the previous versions were running OK, but 3.2.7 is giving me these license problems. If I set the date of the PC a couple of days back plecs seems to run OK (at least for 15 minutes). If I set it a couple of months back it gives me "broken pipe" error message. If I set the date a couple of years ahead, install it and then set the date back to normal it continues to produce "license problem" error message. Pain..., unfortunately the older versions (that used to run problem free) are now behaving in the same manner. Tested on a couple of PCs - the same problem. The BEAN guys didn't do a good job this time
发表于 2012-7-6 05:57:34 | 显示全部楼层
感谢哥哥~·
发表于 2012-7-6 06:29:32 | 显示全部楼层
哥哥,我也遇到5分钟就报错的问题,请尽快解决啊
发表于 2012-7-6 22:58:36 | 显示全部楼层
回复 17# xiaofeng2001
xiaofeng2001, you said you had the same error message but resolved the problem. What did you do to resolve it?
(I do not exclude that the Google chrome translator I used might have been incorrect and you were actually saying that you had the same problem and asked somebody to resolve it)
发表于 2012-7-7 08:25:34 | 显示全部楼层
非常谢谢。
发表于 2012-7-9 00:26:29 | 显示全部楼层
Guys, do you have the same license error or not? It looks that to trigger the error one has to run the prog for a couple of hours first. The license error appears in a day or two after that when running the prog for a couple of minutes. Have you observed this issue too?
发表于 2012-7-15 20:00:53 | 显示全部楼层
找了好久……感谢楼主的分享~~
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 04:21 , Processed in 0.017949 second(s), 5 queries , Gzip On, Redis On.
