查看: 5992|回复: 13
systemvue2011_03_sp1_download_and_crack
发表于 2012-4-13 15:56:15 | 显示全部楼层 |阅读模式
Agilent SystemVue 2011.03 SP1 Windows
« on: August 14, 2011, 08:46:20 20:46 »
1)  Install by running "SystemVue2011_03.exe".
    (http://edocs.soco.agilent.com/display/downloads/SystemVue+2011.03+SP1+Download)
2)  Skip setup License with License Wizard.
3)  After Install replace agsl.dll in
    "C:\Program Files\SystemVue2011.03\bin\agsl.dll"
    with the attaced patched version.
4)  Put attached license file into suitable location like:
    C:\Program Files\SystemVue2011.03.
5)  Add to environment (System Properties - Advanced - Enviroment Variables -
    System variable - New...
    Variable name: SYSTEMVUE_LICENSE_FILE
    Variable value: C:\Program Files\SystemVue2011.03\license.lic
    Note: If you put the license somewhere else then 'value'
    must point to the location of the license.lic file.
  Enjoy.
Download Link:
Patch:
http://www.mediafire.com/?0y4s7gq3z7tdstv
eetop.cn_SV_2011.3_SP1_PATCH.rar (603.22 KB , 下载次数: 388 )
发表于 2012-4-13 20:07:31 | 显示全部楼层
非常感谢楼主了
发表于 2012-6-13 20:30:47 | 显示全部楼层
下来看看!
发表于 2012-6-14 07:33:41 | 显示全部楼层
五体投地式的THX
发表于 2012-6-28 12:12:30 | 显示全部楼层
下来看看
发表于 2012-7-14 14:30:34 | 显示全部楼层
Agilent 开发ESL工具的意图是什么,LZ能介绍一下么。不太了解
发表于 2012-12-6 09:35:53 | 显示全部楼层
感谢楼主
发表于 2012-12-6 22:27:15 | 显示全部楼层
这个可以有。
发表于 2013-6-1 17:51:53 | 显示全部楼层
感谢楼主
发表于 2014-8-5 22:09:54 | 显示全部楼层
请问楼主 systemvue2011_03_sp1是否支持Win7 64bit的操作系统呢?
GMT+8, 2025-9-14 00:42 , Processed in 0.021898 second(s), 9 queries , Gzip On, Redis On.
