查看: 5561|回复: 8
[求助] encounter,加载tsmc18_5lm.lef和tsmc18_5lm.lef tsmc18_5lm_antenna.lef
发表于 2012-4-4 15:05:24 | 显示全部楼层 |阅读模式
Loading Lef file tsmc18_5lm.lef...
ERROR (LEFPARS-1505): MANUFACTURINGGRID statement was defined before UNITS.
Refer to the LEF Language Reference manual for the order of LEF statements. Error in file tsmc18_5lm.lef at line 43, on token UNITS.
**ERROR: (ENCLF-3):
Error found when processing LEF file 'tsmc18_5lm.lef'
**ERROR: (ENCLF-26):
No technology information is defined in the first lef file.
Please rearrange the lef file order and make sure the technology lef file is the
first one, exit and restart Encounter.
encounter 1> **ERROR: **ERROR: (ENCSYT-16013):
Load LEF file tsmc18_5lm.lef tsmc18_5lm_antenna.lef failed
我已经在tsmc18_5lm.lef文件中,加入MANUFACTURINGGRID 0.005 ;,并放在UNITS后面了。。。谢谢
PS:
VERSION 5.2 ;
NAMESCASESENSITIVE ON ;
UNITS
    DATABASE MICRONS 2000  ;
END UNITS
发表于 2013-3-2 21:20:29 | 显示全部楼层
回复 1# jackychan2010
    问题解决了吗?怎么弄,急求
发表于 2013-8-23 16:41:47 | 显示全部楼层
问题解决了吗?我也出现了,不过我用的是IP的lef文件加载也有这样的错
发表于 2014-8-5 17:57:14 | 显示全部楼层
same question.
help!!
发表于 2014-8-6 13:49:10 | 显示全部楼层
exit encounter,重来,
发后端版面,
发表于 2015-4-1 21:46:02 | 显示全部楼层
回复 4# tommhk2002
   有解决么。我也是这个问题 。。
发表于 2015-5-6 21:27:38 | 显示全部楼层
学些顶贴!!!!!!!!!
发表于 2015-10-19 11:09:31 | 显示全部楼层
encounter is good for rtl to gds
发表于 2016-1-26 18:10:47 | 显示全部楼层
学习学习
GMT+8, 2025-12-19 21:39 , Processed in 0.032185 second(s), 7 queries , Gzip On, Redis On.
