查看: 26731|回复: 39
hspice for linux 安装求助
发表于 2012-4-3 21:40:59 | 显示全部楼层 |阅读模式
新安装了hspice2010,但是后面出现下面的问题,弄了好久都没有解决
安装后启动证书的时候出现:
20:27:05 (snpslmd) ------------------------------------------------------------------
20:27:05 (snpslmd) Checking the integrity of the license file....
20:27:05 (snpslmd) Valid SSS feature found. INVALID license file fingerprint.
20:27:05 (snpslmd) This feature is required to enable other keys in your license file.
20:27:05 (snpslmd)
我用hspice运行一个文件出现
lic: FLEXlm: v8.5b
lic: USER:   zl212                HOSTNAME: localhost.localdomain
lic: HOSTID: 00248c10ab03         PID:      7944
lic: Using FLEXlm license files:
lic: /home/eda/hspice/synopsyslic/synopsys.dat
lic: Invalid (inconsistent) license key  The license-key and data for the featu
lic: Unable to checkout hspice
lic:
Command exited with non-zero status 2
real 0.01
user 0.00
sys 0.00
好像是证书出问题了,我的证书如下(按照安装教程来的,反复生成的好几遍
SERVER localhost.localdomain 00248c10ab03 27000
DAEMON snpslmd /home/eda/hspice/scl/linux/bin/
FEATURE SSS snpslmd 1.0 31-dec-2020 uncounted 2E00C6E3F48CCF8B9D42 \
VENDOR_STRING="69656 d1d88 34cc3 33d3d 4f4ed 4941b 79f43 8258f \
ecc22 fcf" HOSTID=00248c10ab03 ISSUER="Team ZWT 2006" \
NOTICE="Licensed to mammoth//ZWT 2006 [PLEASE DO NOT DELETE THIS \
SSS KEY]" SN=RK:1978-0:001224:0 START=1-jan-2006
PACKAGE EFA_Synopsys_1 snpslmd 2019.12 90E0B0A13D267AFCA610 COMPONENTS="3D 3P A3200DX A42MX A500K \
A54SX A54SXA A7 AARKOS-A ABB_CHCRC_LIBRARY ace_core acega acehdl acehdl/beta_status \
acehdl/internal_use acehdl_beta acehdl_gui ACEX1K ACS ACT2-1200XL ACT3 \
AdvanceCalibration_all AdvancedCalibration_all AIM_DEBUG AIM_DEBUG_MEMSSE AIM_DECRYPT \
AIM_DEVELOPER AIM_DEVELOPER_MEMSSE AIM_ENCRYPT aiu_foundation alien2lig alien2lig_all \
alien2lig_ise alien2lig_ise_all ALTGEN1 ALTGEN2 amat-calib_all amga amps amps/cso amps/pfx \
amps/tr AN-Impl3D AN-Impl3D_all AN-Impl3D_ise AN-Impl3D_ise_all any_technology APACM APATD \
APCS APDP APEX20K APEX20KC APEX20KE APEXII APGA4AP APGACS APGADP APGAHPO APGApwr APGASolar \
APGASolarII" ck=223
PACKAGE EFA_Synopsys_2 snpslmd 2019.12 D060B0A16A7E8B7CA76A COMPONENTS="APGATime APHPO Apollo \
ApolloGA APPower APpwr APRV aPrv APSolar APSolarII APTime APXtalk arc arc/bcx arc/c2x \
arc/c3x arc/cns arc/dnx arc/dpx arc/gds2 arc/giper arc/lefdef arc/ppx arc/pro arc/r3x arc1 \
arc2 arcexpert arcfc arcviewer arcviewer/raph arcxl ARKOS-A ARKOS-B ARKOS-C ARKOS-D ARKOS-E \
ARKOS-Ice ARKOS-Mcomp ARKOS-Rtlcomp ARKOS-Scomp ARKOS-Simul ARM7TDMI artistIF Astro \
Astro_DFM AstroBeta AstroExp Astro-Express AstroGA AstroMR8 AstroRail Astro-Rail AstroRailSA \
AstroRailSABeta AstroSpecialBeta AstroXtalk Astro-Xtalk ATMEL ATMWB_ATMLAYER ATMWB_UTOPIA \
AU" ck=39
PACKAGE EFA_Synopsys_3 snpslmd 2019.12 004070D1EBD6E556DFB6 COMPONENTS="AUT_NUMBER_MAJOR_PACKAGES \
avanwaves avanwaveswin awe_rcr BASIC_ANALYSES BASIC_ANALYSES_MEMSSE BATCH_MEASURE \
BATCH_MEASURE_MEMSSE BATT_TOOL BATT_TOOL_MEMSSE BC-FPGA BC-FPGA-HDL BC-FPGA-VHDL BC-HDL \
BC-Schedule BC-VHDL Behavioral-Analyzer Behavioral-Compiler BETA_LIBRARY BOA-BRT BUILD_DATE \
BUILD_NUMBER BUNDLE_MCAD_PROJECTION c_exe_ax c_exe_cbx c_exe_drc c_exe_gx c_exe_ipc \
c_exe_lvs CA-Chip-Edit CA-CP-Advanced CA-CP-Basic CA-CP-Standard Cadabra_DHC cadence \
CADENCE_DIVA_NETLISTER cadence_epic CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE \
CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE CA-Foundation CA-Frame CA-Hier-Timer \
CA-Optimization CA-Timer CA-Utils CBA-ApolloGA-Interface CBA-Blk-Export CBA-Blk-Import \
CBA-CadenceSE-Interface CBA-DS-Beta CBA-Frame CBA-Logical-DS CBA-Logical-MA CBA-Physical-DS \
CBA-Physical-MA CBA-Transport CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen CD-GDI CD-GDII-Link" \
ck=165
PACKAGE EFA_Synopsys_4 snpslmd 2019.12 60C0B0713B24276E2048 COMPONENTS="CD-Model-Developer \
CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Present-Builder CD-Present-Layer-Gen CD-REX cdsaavmx \
cdsaawaves cdsmetalib cdsnet CD-Vhdlgen-Gen CD-Vhdlgen-GUI chipviewer cktcheck cmod cmod/ax \
cmod/cbx cmod/drc cmod/gx cmod/gxadv cmod/hdrc cmod/hlvs cmod/ipc cmod/lvs cmod/viewer \
CmView CoCentric-FXD-GUI CoCentric-FXD-Interpolator CoCentric-FXD-Simulation \
CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-FilterDesign-adv \
CoCentric-SYS-FilterDesign-qed CoCentric-SYS-HWflow CoCentric-SYS-HWFlow \
CoCentric-SYS-HWSimIF CoCentric-SYS-LIB-ecc CoCentric-SYS-LIB-speech CoCentric-SYS-RDK \
CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000 CoCentric-SYS-RDK-docsis \
CoCentric-SYS-SimIF-matlab CoCentric-SYS-Simulator CoCentric-SYS-VirSim Columbia ColumbiaTE \
COMPONENT_LIBRARY COMPONENT_LIBRARY_MEMSSE CONCEPT_FRAMEWAY CONCEPT_NETLISTER \
Constraint_Translation Converter COOLRUNNER COOLRUNNER2 coreAssembler coreBuilder \
coreConsultant coremill CORENL_CHAR CORENL_CHAR_MEMSSE coreSynthesis" ck=159
PACKAGE EFA_Synopsys_5 snpslmd 2019.12 A080D0916EA7BE4F9173 COMPONENTS="COSIM-LFG COSIM-MTI \
COSIM-NCV COSIM-SRO COSIM-VCS COSIM-VXL COSMOS COSMOS_EDIF_XLATE COSMOS_GUIDE \
COSMOS_HIERARCHY_MGR COSMOS_LE COSMOS_SCHEMATIC Cosmos_scope COSMOS_SCOPE COSMOS_SKETCH \
COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER COSMOS_VO COSSAP_adpcm COSSAP_adsl COSSAP_amr \
COSSAP_arm COSSAP_bde COSSAP_celp COSSAP_chart COSSAP_cw_filter_hdl COSSAP_cw_filter_sds \
COSSAP_dab COSSAP_dcg_ad21020 COSSAP_dcg_ansic COSSAP_dcg_ariel32c COSSAP_dcg_fe \
COSSAP_dcg_gc COSSAP_dcg_krc COSSAP_dcg_lsic30s COSSAP_dcg_m96000 COSSAP_dcg_mp \
COSSAP_ddk_arm COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610 COSSAP_ddk_hawk \
COSSAP_ddk_nec COSSAP_ddk_oak COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x \
COSSAP_ddk_tic5xx COSSAP_dect COSSAP_dvb COSSAP_ecc COSSAP_gsmdve COSSAP_gsmdve_utils \
COSSAP_gsmefrsc COSSAP_gsmeq COSSAP_gsmfrcc COSSAP_gsmfrsc COSSAP_gsmhrcc COSSAP_gsmhrsc \
COSSAP_gsmphy COSSAP_is136 COSSAP_is95" ck=213
PACKAGE EFA_Synopsys_6 snpslmd 2019.12 30D080D1D7E68B138CB6 COMPONENTS="COSSAP_matlab COSSAP_mfd \
COSSAP_mpeg2 COSSAP_pdc COSSAP_qed COSSAP_sds COSSAP_srcfd COSSAP_vcg_generic \
COSSAP_vcg_synopsys COSSAP_vcg_vantage COSSAP_vdefcg COSSAP_vdefcg_vlgxl COSSAP_vsiccg \
COSSAP_vsiccg_cyc COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs \
COSSAP_vsiccg_vlgxl COSSAP_vsivcg COSSAP_vsivcg_vlgxl COSSAP_xdcg COSSAP_xvcg COSSAP_xvsi \
COVENTOR_LIB10 COVENTOR_LIB10_MEMSSE COVENTOR_LIB11 COVENTOR_LIB11_MEMSSE COVENTOR_LIB12 \
COVENTOR_LIB12_MEMSSE COVENTOR_LIB13 COVENTOR_LIB13_MEMSSE COVENTOR_LIB14 \
COVENTOR_LIB14_MEMSSE COVENTOR_LIB15 COVENTOR_LIB15_MEMSSE COVENTOR_LIB8 \
COVENTOR_LIB8_MEMSSE COVENTOR_LIB9 COVENTOR_LIB9_MEMSSE CoverMeter CoverMeterOBC \
CoverMeterOBCVCSAMSCompiler CPI-100 CRS_COVERMETER CRS_VCM CRS_VCS CRS_VCSi CTV-Interface \
CUSTOM_LIB Cyclone-Code-Generator Cyclone-Core Cyclone-cosim Cyclone-Elaborator Cyclone-GUI \
Cyclone-HDL-Analyzer Cyclone-Simulator Cyclone-VHDL-Analyzer CYPRESS DataExpansion \
DataExpansionCoverage DataExpansionSim DATAIO" ck=232
PACKAGE EFA_Synopsys_7 snpslmd 2019.12 F07040614F45B6EE7910 COMPONENTS="DataReplay DataReplaySim \
DC64 DC-Beta DC-Cadence-Interface DC-Expert DCExpert-PrimeTime DC-Falcon-Interface \
DC-FPGA-Accelerator DC-FPGA-Add-On DC-FPGA-Add-On-to-DC DC-FPGA-Features DC-Layout-Interface \
DCM-Delay-Calculation DC-Min-Area-Retime DC-SDF-Interface DC-Ultra DC-Ultra-Features \
DC-Ultra-Opt DC-XG Debussy Debussy_shared delaymill Delta39k DEMO Design-Analyzer \
Design-Analyzer-DAP Design-Budgeting Design-Compiler Design-Estimator Design-Estimator-FPI \
DesignSource DesignSource-Estimator-Package DesignSource-Package DESIGNSTAR DESIGNSTAR_NET \
DesignTime Design-Vision DesignWare DesignWare-1394 DesignWare-1394-Source \
DesignWare-6811-Source DesignWare-8051 DesignWare-8051MCU DesignWare-8051-Source \
DesignWare-AMBA-tlm DESIGNWARE-AMBA-VIP Designware-Basic DesignWare-BIST \
DesignWare-BIST-Source DesignWare-Cardbus Designware-Developer DesignWare-Developer-MGI \
DesignWare-Ethernet DesignWare-ETHERNET DesignWare-ETHERNET-Source DesignWare-FloatingPoint \
DesignWare-Foundation DesignWare-Foundation-Exp DesignWare-Foundation-Expert \
DesignWare-Foundation-Power DesignWare-Foundation-Ultra" ck=190
PACKAGE EFA_Synopsys_8 snpslmd 2019.12 00D000F173EA06302AA3 COMPONENTS="Designware-FPGA-Basic \
DESIGNWARE-I2C-VIP DesignWare-ISA-PnP DesignWare-MEMCTL-Source DesignWare-MemoryBist \
DesignWare-MemoryBist-Source DesignWare-MGI DesignWare-MPEG DesignWare-MPEG2 \
DesignWare-MPEG2-Source DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source \
DesignWare-MPEG-Source DesignWare-Package DesignWare-PCI DesignWare-PCIbasic \
DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source DESIGNWARE-REGRESSION \
DesignWare-Regression DESIGNWARE-SIO-VIP DesignWare-SystemIO DesignWare-SystemIO-Source \
DesignWare-TCA DesignWare-TCA-Source DesignWare-USB DesignWare-USB2 DesignWare-USB2-Source \
DesignWare-USB-Source DesignWare-VERA DESIGNWARE-VERIFICATION Dessis Dessis_all Dessis_ise \
Dessis_ise_all Dessis-3D Dessis-3D_all Dessis-3D_ise Dessis-3D_ise_all Dessis-BONSIM_all \
Dessis-DensityGrad Dessis-DensityGrad_all Dessis-DensityGrad_ise Dessis-DensityGrad_ise_all \
Dessis-Ferro Dessis-Ferro_all Dessis-Ferro_ise Dessis-Ferro_ise_all Dessis-FloatingGate \
Dessis-FloatingGate_all Dessis-FloatingGate_ise Dessis-FloatingGate_ise_all \
Dessis-GateLeakage Dessis-GateLeakage_all Dessis-GateLeakage_ise Dessis-GateLeakage_ise_all \
Dessis-Hetero Dessis-Hetero_all Dessis-Hetero_ise Dessis-Hetero_ise_all Dessis-Hydro" ck=205
PACKAGE EFA_Synopsys_9 snpslmd 2019.12 00A03031411D403F2F34 COMPONENTS="Dessis-Hydro_all \
Dessis-Hydro_ise Dessis-Hydro_ise_all Dessis-kpGain Dessis-kpGain_all Dessis-kpGain_ise \
Dessis-kpGain_ise_all Dessis-Laser Dessis-Laser_all Dessis-Laser_ise Dessis-Laser_ise_all \
Dessis-LED Dessis-LED_all Dessis-LED_ise Dessis-LED_ise_all Dessis-MixedMode \
Dessis-MixedMode_all Dessis-MixedMode_ise Dessis-MixedMode_ise_all Dessis-Mono-Semicond \
Dessis-Mono-Semicond_all Dessis-Mono-Semicond_ise Dessis-Mono-Semicond_ise_all \
Dessis-MonteCarlo Dessis-MonteCarlo_all Dessis-MonteCarlo_ise Dessis-MonteCarlo_ise_all \
Dessis-Noise Dessis-Noise_all Dessis-Noise_ise Dessis-Noise_ise_all Dessis-Optic \
Dessis-Optic_all Dessis-Optic_ise Dessis-Optic_ise_all Dessis-Parallel Dessis-Parallel_all \
Dessis-Parallel_ise Dessis-Parallel_ise_all Dessis-Parallel4 Dessis-Parallel4_all \
Dessis-Parallel4_ise Dessis-Parallel4_ise_all Dessis-PMI Dessis-PMI_all Dessis-PMI_ise \
Dessis-PMI_ise_all Dessis-Radiation Dessis-Radiation_all Dessis-Radiation_ise \
Dessis-Radiation_ise_all Dessis-Reliability Dessis-Reliability_all Dessis-Reliability_ise \
Dessis-Reliability_ise_all Dessis-Schroedinger Dessis-Schroedinger_all \
Dessis-Schroedinger_ise Dessis-Schroedinger_ise_all Dessis-SiGe Dessis-SiGe_all \
Dessis-SiGe_ise" ck=75
PACKAGE EFA_Synopsys_10 snpslmd 2019.12 60B0F061CD1C650D8CFC COMPONENTS="Dessis-SiGe_ise_all \
Dessis-Thermo Dessis-Thermo_all Dessis-Thermo_ise Dessis-Thermo_ise_all Dessis-Traps \
Dessis-Traps_all Dessis-Traps_ise Dessis-Traps_ise_all Dessis-VectorOptic \
Dessis-VectorOptic_all Dessis-VectorOptic_ise Dessis-VectorOptic_ise_all Devise Devise_all \
Devise_ise Devise_ise_all Devise-3D Devise-3D_all Devise-3D_ise Devise-3D_ise_all Dfisetools \
Dfisetools_all Dfisetools_ise Dfisetools_ise_all Dfisetools-Topo_all DIODE_TOOL \
DIODE_TOOL_MEMSSE Dios_all Dios-3D_all Dios-MC_all Dios-PDEF_all Dios-SDO_all DiosSmall_all \
Dip Dip_all Dip_ise Dip_ise_all DIRECTMEM DRCYCLE_TOOL DRCYCLE_TOOL_MEMSSE DS-Schem-Gen \
DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package DS-Verinet \
DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package DS-Verinet-Package DS-Vhdlnet \
DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package DV DVAM DVCA DVHJ \
DVLT DVOD DVPD DVTC DWC-AHB-ICTL-Source" ck=14
PACKAGE EFA_Synopsys_11 snpslmd 2019.12 605060F133323F50B29D COMPONENTS="DWC-AHB-Source \
DWC-AMBA-Fabric-Source DWC-APB-Advanced-Source DWC-APB-ICTL-Source DWC-APB-Periph-Source \
DWC-DMA-Controller-Source DWC-DMAC-Source DWC-GPIO-Source DWC-I2C-Source \
DWC-INTC-CNTL-Source DWC-MEMCTL-Source DWC-RAP-Source DWC-RTC-Source DWC-SSI-Source \
DWC-TIMERS-Source DWC-UART-Source DWC-UART-SRC DWC-WDT-Source DW-Developer DW-IP-Consultant \
DW-IP-DEBUG DW-IP-Developer E5 E502 E505 E520 Early-Access-Technology ECL-Compiler \
ECO-Compiler EDIF_NETLISTER EDIF_NETLISTER_MEMSSE edif2e EDIF-Netlist-Read-DC \
EDIF-Netlist-Write-DC EDIF-Netlist-Writer EDIF-Reader EDIF-Schematic-Writer \
electromigration_drc ELGRECO_Davis ELGRECO_DesignCenter ELGRECO_Simulator Emlab Emlab_all \
Emlab_ise Emlab_ise_all Emlab-Dessis Emlab-Dessis_all Emlab-Dessis_ise Emlab-Dessis_ise_all \
Emlab-Farfield Emlab-Farfield_all Emlab-Farfield_ise Emlab-Farfield_ise_all \
Emlab-Nonuniform-2D Emlab-Nonuniform-2D_all Emlab-Nonuniform-2D_ise \
Emlab-Nonuniform-2D_ise_all Emlab-Nonuniform-3D Emlab-Nonuniform-3D_all \
Emlab-Nonuniform-3D_ise Emlab-Nonuniform-3D_ise_all Emlab-Static" ck=193
后面略....................................................................................................................
要怎么解决,谢谢大家了!!!在线等
发表于 2012-4-3 23:48:18 | 显示全部楼层
這一行便告訴您license有問題了 !!
用EFA及KeyGen2009(SSS)重新去產生license吧 !!...........一步一步的小心操作,或許就OK了 !!
 楼主| 发表于 2012-4-4 00:45:25 | 显示全部楼层
回复 2# lik4965
弄了很多遍了,都是按那个安装指导上来的,不知道怎么回事,同学用的DEBAIN都没有问题,我用的CENTOS
发表于 2012-4-4 01:22:56 | 显示全部楼层
那个安装指导............網址在那裡 ??........讓我看看您可能那邊出錯了 !!
 楼主| 发表于 2012-4-4 01:33:10 | 显示全部楼层
回复 4# lik4965
http://bbs.eetop.cn/viewthread.php?tid=320005&highlight=hspice%2Bfor%2Blinux就是这个,还有个是下载软件时里面也有一个,不过大同小异
。谢谢呐
发表于 2012-4-4 01:51:54 | 显示全部楼层
回复 5# zl8702
不过,在LicGen.exe里面需要勾选上“use daemon”选项,并且也选“custom”(那个安装指导的內容)
.....未必是錯的或有問題的!!.....但我不是如此操作的...........
1. open synopsys.lpd
2.select hostid : 勾選Ethernet or custom填上hostid 如您的是00248c10ab03
  不要動EFA下面的原始設定(不要勾选上“use daemon”选项 !!)
3.產生License,其它步驟相同 !!
試試看 !!
PS.
產生License後,自行加入下面兩行,或SSS後再加入亦可 !!
FEATURE snpslmd /home/eda/hspice/scl/linux/bin/snpslmd
 楼主| 发表于 2012-4-4 01:53:50 | 显示全部楼层
我的hostid 00248c10ab03,后面的.bashrc配置应该是成功了的,license还参考比较了下同学的,就是
不明白怎么回事了
 楼主| 发表于 2012-4-4 02:19:40 | 显示全部楼层
回复 6# lik4965
明天早上弄,期待能够解决,后面可能还要继续咨询你,非常感谢
 楼主| 发表于 2012-4-4 11:08:53 | 显示全部楼层
回复 6# lik4965
还是不行呀,生成的证书上除了两行不同,其它的都一样,但是前两行又是后面自己要改的,所以就是一样的了
发表于 2012-4-4 15:32:30 | 显示全部楼层
回复  lik4965
还是不行呀,生成的证书上除了两行不同,其它的都一样,但是前两行又是后面自己要改的,所 ...
zl8702 发表于 2012-4-4 11:08
今天清明掃墓及祭拜祖先,剛回來不久 !!.............
我下載及修改了那一帖的Synopsys.src(如附件),用EFA及KeyGen(您的hostname,hostid)生成了最終的license file(eetop-hspice-try.dat) ,您試用看看 !!
...........很久沒有用舊版的synopsys license,回憶一下 !!
eetop-hspice-try.tar.gz (24.33 KB , 下载次数: 436 )
GMT+8, 2025-12-14 01:38 , Processed in 0.036094 second(s), 6 queries , Gzip On, Redis On.
