查看: 2570|回复: 3
[招聘] 急!寻找fabless IC (semiconductor)行业专家!
发表于 2012-4-3 10:08:54 | 显示全部楼层 |阅读模式
各位好,
不知在场有没有fabless IC (semiconductor) design sector行业的专家,寻求合作关系。(需要涉及到以下产品的建议)(1) IC for electric charger (main function is to improve the efficiency of the charging from 50-60% to 70% and reduce the number of components in the electronics product as the function of those components have been incorporated into the IC, thus saves overall production cost); and (2) control IC for LED lighting (main function is for heat dissipation, which allows the LED device to significantly reduce the need for heat dissipating fixtures such as aluminum/heat sink, hence saves production cost and improves design/style of the LED device).
小弟现在在一家私募基金做,在做Fabless IC行业的project,如果有认识fabless IC (semiconductor) design sector行业的专家或者本身就是的,欢迎提供联系方式。我的邮件是 wraphaelixt(at)gmail.com
谢谢!
发表于 2012-4-3 14:52:48 | 显示全部楼层
直接请个consultant
 楼主| 发表于 2012-4-3 17:41:38 | 显示全部楼层
请问有没有好的consultant推荐?
想要expert but not general business consultant~谢谢!
发表于 2012-4-4 08:35:25 | 显示全部楼层
我们合伙开公司吧
GMT+8, 2025-9-13 18:24 , Processed in 0.020543 second(s), 7 queries , Gzip On, Redis On.
