查看: 10355|回复: 8
[求助] 奇怪的cadence license问题
发表于 2012-4-2 13:33:11 | 显示全部楼层 |阅读模式
诸位大哥,
小弟的cadence 用的是floating license. 昨天还好好的
今天schematic就不能编辑了。报了下面的错误。
\w *WARNING* Unable to check out a Schematic Editor license (34500, Virtuoso_Schem_Option + 300, Virtuoso_Schematic_Editor_L or Virtuoso_Schematic_Editor_XL)
\w *WARNING* Schematic Editor: license file does not contain a license for feature 34500
\w *WARNING* Schematic Editor: license file does not contain a license for feature Virtuoso_Schem_Option
\w *WARNING* Schematic Editor: license file does not contain a license for feature Virtuoso_Schematic_Editor_L
\w *WARNING* Schematic Editor: license file does not contain a license for feature Virtuoso_Schematic_Editor_XL
但是查看lmgrd的log文件(下面)没看到什么错误呀。
其中34500表示已经运行了。 那位高人指点一下。谢了!
16:27:50 (lmgrd) -----------------------------------------------
16:27:50 (lmgrd)   Please Note:
16:27:50 (lmgrd)
16:27:50 (lmgrd)   This log is intended for debug purposes only.
16:27:50 (lmgrd)   In order to capture accurate license
16:27:50 (lmgrd)   usage data into an organized repository,
16:27:50 (lmgrd)   please enable report logging. Use Macrovision's
16:27:50 (lmgrd)   software license administration  solution,
16:27:50 (lmgrd)   FLEXnet Manager, to  readily gain visibility
16:27:50 (lmgrd)   into license usage data and to create
16:27:50 (lmgrd)   insightful reports on critical information like
16:27:50 (lmgrd)   license availability and usage. FLEXnet Manager
16:27:50 (lmgrd)   can be fully automated to run these reports on
16:27:50 (lmgrd)   schedule and can be used to track license
16:27:50 (lmgrd)   servers and usage across a heterogeneous
16:27:50 (lmgrd)   network of servers including Windows NT, Linux
16:27:50 (lmgrd)   and UNIX. Contact Macrovision at
16:27:50 (lmgrd)   www.macrovision.com for more details on how to
16:27:50 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
16:27:50 (lmgrd)   for your enterprise.
16:27:50 (lmgrd)
16:27:50 (lmgrd)
16:27:50 (lmgrd)
16:27:50 (lmgrd) The license server manager (lmgrd) running as root:
16:27:50 (lmgrd)     This is a potential security problem
16:27:50 (lmgrd)     and is not recommended.
16:27:50 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on core8 (linux) (4/1/2012)
16:27:50 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
16:27:50 (lmgrd) US Patents 5,390,297 and 5,671,412.
16:27:50 (lmgrd) World Wide Web:  http://www.macrovision.com
16:27:50 (lmgrd) License file(s): /tools/cadence/license.dat
16:27:50 (lmgrd) lmgrd tcp-port 5280
16:27:50 (lmgrd) Starting vendor daemons ...
16:27:50 (lmgrd) Started cdslmd (internet tcp_port 32791 pid 6182)
16:27:50 (cdslmd) FLEXnet Licensing version v10.8.6.0 build 54361 i86_re3
16:27:50 (cdslmd) EXPIRED: Envisia_PKS
16:27:50 (cdslmd) EXPIRED: Envisia_SE_ultra_place_route
16:27:50 (cdslmd) EXPIRED: Silicon_Ensemble_DSM
16:27:50 (cdslmd) EXPIRED: FirstEncounter
16:27:50 (cdslmd) EXPIRED: FirstEncounterSOC
16:27:50 (cdslmd) EXPIRED: FE_Classic
16:27:50 (cdslmd) EXPIRED: FE_Ultra
16:27:50 (cdslmd) EXPIRED: SOC_Encounter
16:27:50 (cdslmd) EXPIRED: Encounter_C
16:27:50 (cdslmd) EXPIRED: Envisia_SE_SI_place_route
16:27:50 (cdslmd) EXPIRED: NanoRoute_Ultra
16:27:50 (cdslmd) EXPIRED: Nano_Encounter
16:27:50 (cdslmd) EXPIRED: RTL_Encounter
16:27:50 (cdslmd) EXPIRED: Encounter_ClockSyn
16:27:50 (cdslmd) EXPIRED: RTL_Compiler_Ultra
16:27:50 (cdslmd) EXPIRED: FE_GPS
16:27:50 (cdslmd) EXPIRED: SOC_Encounter_GPS
16:27:50 (cdslmd) Server started on core8 for:    100
16:27:50 (cdslmd) 111        11400        12141
16:27:50 (cdslmd) 12500        14000        14010
16:27:50 (cdslmd) 14020        14040        14101
16:27:50 (cdslmd) 14111        14120        14130
16:27:50 (cdslmd) 14140        14410        200
16:27:50 (cdslmd) 20120        20121        20122
16:27:50 (cdslmd) 20123        20124        20127
16:27:50 (cdslmd) 20128        20220        20221
16:27:50 (cdslmd) 20222        20227        206
16:27:50 (cdslmd) 207        21060        21200
16:27:50 (cdslmd) 21400        21900        21920
16:27:50 (cdslmd) 22650        22800        22810
16:27:50 (cdslmd) 24015        24025        24100
16:27:50 (cdslmd) 24205        250        251
16:27:50 (cdslmd) 26000        274        276
16:27:50 (cdslmd) 279        283        300
16:27:50 (cdslmd) 305        312        314
16:27:50 (cdslmd) 316        318        32110
16:27:50 (cdslmd) 32140        32150        32190
16:27:50 (cdslmd) 322        32500        32501
16:27:50 (cdslmd) 32502        32510        32550
16:27:50 (cdslmd) 32600        32610        32620
16:27:50 (cdslmd) 32630        32640        32760
16:27:50 (cdslmd) 33010        33301        334
16:27:50 (cdslmd) 336        34500        34510
16:27:50 (cdslmd) 365        370        371
16:27:50 (cdslmd) 37100        373        40020
16:27:50 (cdslmd) 40030        40040        40500
16:27:50 (cdslmd) 41000        50000        50010
16:27:50 (cdslmd) 501        50110        50200
16:27:50 (cdslmd) 51022        51023        51060
16:27:50 (cdslmd) 51070        51170        550
16:27:50 (cdslmd) 570        61300        61400
16:27:50 (cdslmd) 71110        71120        71130
16:27:50 (cdslmd) 920        940        945
16:27:50 (cdslmd) 950        960        963
16:27:50 (cdslmd) 964        965        966
16:27:50 (cdslmd) 972        974        991
16:27:50 (cdslmd) 994        995        ABIT
16:27:50 (cdslmd) ALL_EBD        AMD_MACH    ANALOG_WORKBENCH
16:27:50 (cdslmd) AWB_BEHAVIOR    AWB_Batch    AWB_DIST_SIM
16:27:50 (cdslmd) AWB_MAGAZINE    AWB_MAGNETICS    AWB_MIX
16:27:50 (cdslmd) AWB_PPLOT    AWB_RESOLVE_OPT AWB_SIMULATOR
16:27:50 (cdslmd) AWB_SMOKE    AWB_SPICEPLUS    AWB_STATS
16:27:50 (cdslmd) Actel_FPGA    Advanced_Cell_Placer Advanced_Package_Designer
16:27:50 (cdslmd) Affirma_AMS_distrib_processing Affirma_NC_Simulator Affirma_NC_VHDL_Desktop_Sim
16:27:50 (cdslmd) Affirma_RF_IC_package Affirma_RF_SPW_model_link Affirma_advanced_analysis_env
16:27:50 (cdslmd) Affirma_equivalence_checker Affirma_sim_analysis_env Allegro_CAD_Interface
16:27:50 (cdslmd) Allegro_Designer Allegro_PCB_Interface Altera_MAX
16:27:50 (cdslmd) Ambit_BuildGates Ambit_libcompile Artist_Optimizer
16:27:50 (cdslmd) Artist_Statistics Atmel_ATV    BOGUS
16:27:50 (cdslmd) Base_Digital_Body_Lib Base_Verilog_Lib BlockMaster_Characterizer
16:27:50 (cdslmd) BlockMaster_Optimizer BoardQuest_Team BuildGates_Extreme
16:27:50 (cdslmd) CELL3        CELL3_ARO    CELL3_CROSSTALK
16:27:50 (cdslmd) CELL3_CTS    CELL3_ECL    CELL3_OPENDEV
16:27:50 (cdslmd) CELL3_OPENEXE    CELL3_PA    CELL3_PR
16:27:50 (cdslmd) CELL3_QPLACE_TIMING CELL3_SCAN    CELL3_TIMING
16:27:50 (cdslmd) CELL3_WIDEWIRE    CP_Ele_Checks    CPtoolkit
16:27:50 (cdslmd) CWAVES        CWB01        CWB03
16:27:50 (cdslmd) CWB04        CWB05        CheckPlus
16:27:50 (cdslmd) Clock_Tree_Generation Cobra_Simulator ComposerCheckPlus_AdvRules
16:27:50 (cdslmd) ComposerCheckPlus_Checker ComposerCheckPlus_RuleDev Composer_EDIF300_Connectivity
16:27:50 (cdslmd) Composer_EDIF300_Schematic Composer_Spectre_Sim_Solution ConcICe_Option
16:27:50 (cdslmd) Corners_Analysis DISCRETE_LIB    DRAC2CORE
16:27:50 (cdslmd) DRAC2DRC    DRAC2LVS    DRAC3CORE
16:27:50 (cdslmd) DRAC3DRC    DRAC3LVS    DRACACCESS
16:27:50 (cdslmd) DRACDIST    DRACERC        DRACLPE
16:27:50 (cdslmd) DRACLVS        DRACPG_E    DRACPLOT
16:27:50 (cdslmd) DRACPRE        DRACSLAVE    Datapath_Preview_Option
16:27:50 (cdslmd) Datapath_VHDL    Datapath_Verilog Device_Level_Placer
16:27:50 (cdslmd) Device_Level_Router Distributed_Dracula_Option EBD_edit
16:27:50 (cdslmd) EBD_floorplan    EBD_power    EDIF_Netlist_Interface
16:27:50 (cdslmd) EDIF_Schematic_Interface EMCdisplay    EMControl
16:27:50 (cdslmd) Envisia_GE_ultra_place_route Envisia_RAC    Envisia_Utility
16:27:50 (cdslmd) Envisia_LowPower_option Envisia_DataPath_option Extended_Digital_Body_Lib
16:27:50 (cdslmd) Extended_Digital_Lib Extended_Verilog_Lib FPGA_Flows
16:27:50 (cdslmd) FPGA_OPTIMIZER    FPGA_Tools    FUNCTION_LIB
16:27:50 (cdslmd) Framework    GATEENSEMBLE    GATEENSEMBLE_ARO
16:27:50 (cdslmd) GATEENSEMBLE_CROSSTALK GATEENSEMBLE_CTS GATEENSEMBLE_CTS_LE
16:27:50 (cdslmd) GATEENSEMBLE_CTS_UL GATEENSEMBLE_ECL GATEENSEMBLE_LOWEND
16:27:50 (cdslmd) GATEENSEMBLE_OPENDEV GATEENSEMBLE_OPENEXE GATEENSEMBLE_PA
16:27:50 (cdslmd) GATEENSEMBLE_PR_LE GATEENSEMBLE_PR_UL GATEENSEMBLE_QPLACE_TIMING
16:27:50 (cdslmd) GATEENSEMBLE_SCAN GATEENSEMBLE_TIMING GATEENSEMBLE_TIMING_LE
16:27:50 (cdslmd) GATEENSEMBLE_TIMING_UL GATEENSEMBLE_UNLIMITED GATEENSEMBLE_WIDEWIRE
16:27:50 (cdslmd) Gate_Ensemble_DSM Gate_Ensemble_DSM_Crosstalk Gate_Ensemble_WARP
16:27:50 (cdslmd) HDL-DESKTOP    IC_Inspector    IC_autoroute
16:27:50 (cdslmd) IC_edit        IC_hsrules    IDF_Bi_Directional_Interface
16:27:50 (cdslmd) LAS_Cell_Optimization LEAPFROG-BV    LEAPFROG-CV
16:27:50 (cdslmd) LEAPFROG-SLAVE    LEAPFROG-SV    LEAPFROG-SYS
16:27:50 (cdslmd) LID10        LID11        LINEAR_LIB
16:27:50 (cdslmd) LSE        MAG_LIB        MIXAD_LIB
16:27:50 (cdslmd) Model_Check_Analysis NCSim_Desktop    NCVLOG_CGOPTS
16:27:50 (cdslmd) NC_Verilog_Compiler NC_Verilog_Data_Prep_Compiler NC_Verilog_Simulator
16:27:50 (cdslmd) NC_VHDL_Simulator NC-simulator    Nihongoconcept
16:27:50 (cdslmd) OASIS_Simulation_Interface OpenModeler_SFI OpenModeler_SWIFT
16:27:50 (cdslmd) OpenSim        OpenWaves    PICDesigner
16:27:50 (cdslmd) PIC_Utilities    PLD        PWM_LIB
16:27:50 (cdslmd) Pearl        Pearl_Cell    Placement_Based_Synthesis
16:27:50 (cdslmd) Prevail_Board_Designer Prevail_Correct_By_Design Prevail_Designer
16:27:50 (cdslmd) Preview_Synopsys_Interface QPlace        Quickturn_Model_Manager
16:27:50 (cdslmd) RapidPART    SWIFT        Schematic_Generator
16:27:50 (cdslmd) SigNoiseCS    SigNoiseEngineer SigNoiseExpert
16:27:50 (cdslmd) SigNoiseStdDigLib Signal_Integrity SiliconQuest
16:27:50 (cdslmd) SiliconQuest_CTGen_Option Silicon_Ensemble Silicon_Ensemble_CTS
16:27:50 (cdslmd) Silicon_Ensemble_DSM_Crosstalk Silicon_Ensemble_OpenDev Silicon_Ensemble_OpenExe
16:27:50 (cdslmd) Silicon_Ensemble_WARP Silicon_Synthesis_QPBS SimControl
16:27:50 (cdslmd) SimVision    SpectreBasic    SpectreRF
16:27:50 (cdslmd) Spectre_BTAHVMOS_Models Spectre_BTASOI_Models Spectre_NorTel_Models
16:27:50 (cdslmd) Spectre_ST_Models Substrate_Coupling_Analysis Synlink_Interface
16:27:50 (cdslmd) UET        ULMdelta    ULMecho
16:27:50 (cdslmd) ULMhotel    ULMindia    ULMjuliette
16:27:50 (cdslmd) ULMmike        Universal_Smartpath VERILOG-SLAVE
16:27:50 (cdslmd) VERILOG-XL    VERITIME    VHDLLink
16:27:50 (cdslmd) VHDL_desktop    VXL-ALPHA    VXL-LMC-HW-IF
16:27:50 (cdslmd) VXL-SWITCH-RC    VXL-TURBO    VXL-VCW
16:27:50 (cdslmd) VXL-VET        VXL-VLS        VXL-VRA
16:27:50 (cdslmd) Vampire_HDRC    Vampire_HLVS    Vampire_MP
16:27:50 (cdslmd) Vampire_RCX    Vampire_UI    Verif_Ckpit_Analysis_Env
16:27:50 (cdslmd) Verilog_XL_Turbo_NT Verilog_XL_Desktop Verilog_desktop
16:27:50 (cdslmd) Virtuoso_Schem_Option Virtuoso_XL    Xilinx_FPGA
16:27:50 (cdslmd) a2dxf        aae-signalscan    aae-signalscan-transaction
16:27:50 (cdslmd) aae-transaction-explorer actomd        affirma-signalscan
16:27:50 (cdslmd) affirma-signalscan-control affirma-signalscan-pro affirma-signalscan-schmatic
16:27:50 (cdslmd) affirma-signalscan-source affirma-signalscan-transaction affirma-transaction-explorer
16:27:50 (cdslmd) allegro_dfa    allegro_dfa_att allegro_non_partner
16:27:50 (cdslmd) allegro_symbol    allegroprance    archiver
16:27:50 (cdslmd) arouter        caeviews    cals_out
16:27:50 (cdslmd) catia        cbds_in        cdxe_in
16:27:50 (cdslmd) comp        compose        compose_autoplan
16:27:50 (cdslmd) compose_gcr    compose_scells    compose_tlmr
16:27:50 (cdslmd) compose_util    concept        conceptXPC
16:27:50 (cdslmd) cpe        cpte        crefer
16:27:50 (cdslmd) cvtomd        debug        dfsverifault
16:27:50 (cdslmd) dracula_in    dxf2a        e2v
16:27:50 (cdslmd) edif2ged    expgen        fethman
16:27:50 (cdslmd) fetsetup    fluke        fsim
16:27:50 (cdslmd) gbom        ged2edif    glib
16:27:50 (cdslmd) gloss        gphysdly    gscald
16:27:50 (cdslmd) gspares        hp3070        iges_electrical
16:27:50 (cdslmd) intrgloss    intrroute    intrsignoise
16:27:50 (cdslmd) ipc_in        ipc_out        lwb
16:27:50 (cdslmd) mdin        mdout        mdtoac
16:27:50 (cdslmd) mdtocv        multiwire    packager
16:27:50 (cdslmd) pcb_editor    pcb_engineer    pcb_interactive
16:27:50 (cdslmd) pcb_prep    pcb_review    pcomp
16:27:50 (cdslmd) placement    plotVersa    ptc_in
16:27:50 (cdslmd) ptc_out        quanticout    redifnet
16:27:50 (cdslmd) rt        sdrc_in        sdrc_out
16:27:50 (cdslmd) signoise    skillDev    stream_in
16:27:50 (cdslmd) stream_out    swap        sx
16:27:50 (cdslmd) synSmartIF    synSmartLib    synTiOpt
16:27:50 (cdslmd) tsTSynVHDL    tsTSynVLOG    tsTestGen
16:27:50 (cdslmd) tsTestIntf    tune        tw01
16:27:50 (cdslmd) tw02        v2e        vc-signalscan
16:27:50 (cdslmd) vc-signalscan-transaction vc-transaction-explorer verifault
16:27:50 (cdslmd) vgen        viable        visula_in
16:27:50 (cdslmd) vloglink    wedifsch    xilCds
16:27:50 (cdslmd) xilComposerFE    xilConceptFE    xilEdif
16:27:50 (cdslmd) TimingAnalysis    RCExtraction    DelayCal
16:27:50 (cdslmd) TrialRoute    AmoebaPlace    DesignViewer
16:27:50 (cdslmd) Route        CeltIC        SignalIntegrity
16:27:50 (cdslmd) ClockSyn    PowerAnalysis    SpecialRoute
16:27:50 (cdslmd) TimingBudget    PartitionOptimizer Multithread_Route_Option
16:27:50 (cdslmd) Cierto_SPW_comm_library_fxp_pt Cierto_HW_design_sys_2000 Cierto_SPW_multimedia_kit
16:27:50 (cdslmd) Cierto_SPW_GSM_VE Cierto_SPW_IS136_VE Cierto_SPW_pcscdma_VE
16:27:50 (cdslmd) Cierto_signal_proc_wrksys_2000 Cierto_SPW_comm_lib_flt_pt SPW_Smart_Antenna_Library
16:27:50 (cdslmd) Cierto_Wireless_LAN_Library Cierto_SPW_CDMA_Library Cierto_SPW_model_manager
16:27:50 (cdslmd) Virtuoso_NeoCircuit DFM_Core_Technology Assura_DRC
16:27:50 (cdslmd) Assura_LVS    Assura_MP    Assura_OPC
16:27:50 (cdslmd) Assura_RCX    Assura_SI-TL    Assura_SI
16:27:50 (cdslmd) Assura_SiMC    Assura_SiVL    Assura_UI
16:27:50 (cdslmd) VoltageStorm_Cell VoltageStorm_Cell_Transistor SI_Timing_Convergence_VS
16:27:50 (cdslmd) VoltageStorm_Transistor VoltageStorm_PE STV90
16:27:50 (cdslmd) ElectronStorm_Transistor
16:27:50 (cdslmd)
16:27:50 (cdslmd) All FEATURE lines for cdslmd behave like INCREMENT lines
16:27:50 (cdslmd)
16:27:50 (cdslmd) EXTERNAL FILTERS are OFF
16:27:50 (lmgrd) cdslmd using TCP-port 32791
22:27:50 (lmgrd) TIMESTAMP 4/1/2012
发表于 2012-4-2 15:28:01 | 显示全部楼层
过期了
发表于 2014-1-4 21:32:14 | 显示全部楼层
need latest license
发表于 2014-12-4 01:48:33 | 显示全部楼层
发表于 2018-3-9 10:35:59 | 显示全部楼层
楼主,这个问题最后怎么解决的啊?请指导下
发表于 2018-3-16 14:50:20 | 显示全部楼层
謝謝分享  大推  感恩  thx
发表于 2018-6-1 18:34:40 | 显示全部楼层
回复 5# 牵挂
add license
发表于 2018-6-7 06:35:35 | 显示全部楼层
thanks
发表于 2018-11-16 18:07:55 | 显示全部楼层
GMT+8, 2025-12-28 21:53 , Processed in 0.022312 second(s), 7 queries , Gzip On, Redis On.
