查看: 11445|回复: 49
Flicker Noise in CMOS Transistors ......(by Abidi)
发表于 2006-11-28 08:36:05 | 显示全部楼层 |阅读模式
Flicker Noise in CMOS Transistors from Subthreshold to Strong Inversion at Various Temperatures
Jimmin Chang, Member, IEEE, A. A. Abidi, Member, IEEE, and C. R. Viswanathan, Fellow, IEEE
Abstract
    Flicker noise is the dominant noise source in silicon
MOSFET’S. Even though considerable amount of work has been
done in investigating the noise mechanism, controversy still exists
as to the noise origin. In this paper, a systematic study of flicker
noise in CMOS transistors from twelve different fabricators is
reported under various bias conditions corresponding to the gate
voltage changing from subthreshold to strong inversion, and
the drain voltage changing from linear to saturation regions
of operation. The measurement temperature was varied from
room temperature down to 5 K. Experimental results consistently
suggest that 1/f noise in n-channel devices is dominated by
carrier-density fluctuation while in p-channel devices the noise
is mainly due to mobility fluctuation.
jimmin.pdf
703.98 KB, 下载次数: 324 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-11-28 08:57:59 | 显示全部楼层
Thanks
发表于 2006-12-10 03:39:21 | 显示全部楼层
谢谢楼主,顶
发表于 2006-12-18 23:04:42 | 显示全部楼层
多谢楼主了
发表于 2007-1-15 01:40:16 | 显示全部楼层
谢谢提供解答.
发表于 2007-1-17 18:02:57 | 显示全部楼层
好东西啊,正好需要啊
发表于 2007-4-9 20:41:32 | 显示全部楼层
good good good stuff
发表于 2007-6-9 15:18:05 | 显示全部楼层
太好了啊
发表于 2007-6-12 08:39:53 | 显示全部楼层
thanks
发表于 2007-6-12 09:33:40 | 显示全部楼层
Thanks for sharing
GMT+8, 2025-12-25 18:54 , Processed in 0.033814 second(s), 7 queries , Gzip On, Redis On.
