查看: 5240|回复: 4
[求助] questasim10.0a+UVM
发表于 2012-3-23 23:44:56 | 显示全部楼层 |阅读模式
昨天在用questasim10.0a编译dpi库的时候,报了下面的错误:
# In file included from D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:29:
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:29:22: error: vpi_user.h: No such file or directory
# In file included from D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:30:
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:23:22: error: veriuser.h: No such file or directory
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:24:19: error: svdpi.h: No such file or directory
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc: In member function 'int uvm_re_cache::re_match(const char*, const char*)':
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: 'PLI_BYTE8' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: expected primary-expression before ')' token
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_regex.cc:124: error: 'vpi_printf' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c: In function 'int uvm_hdl_max_width()':
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:49: error: 'vpiHandle' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:49: error: expected `;' before 'ms'
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:50: error: 's_vpi_value' was not declared in this scope
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_hdl.c:50: error: expected `;' before 'value_s'
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc:34: error: expected `}' at end of input
# D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc: At global scope:
我使用的命令是D:/questa_sim_10.0a/gcc-4.2.1-mingw32vc9/bin/g++.exe \
        -g \
        -DQUESTA \
        -W \
        -shared \
        -Bsymbolic \
        -ID:/questa_sim_10.0a/gcc-4.2.1-mingw32vc9/include \
        D:/questa_sim_10.0a/verilog_src/uvm-1.0/src/dpi/uvm_dpi.cc \
        -o D:/questa_sim_10.0a/verilog_src/uvm-1.0/lib/uvm_dpi.dll \
  D:/questa_sim_10.0a/win32/mtipli.dll -lregex
因为我没有uvm_dpi.dll文件,所以就用上面的命令先生成,不知道怎么会报出这种错误,我用的库是从官网上下啊,怎么会没有需要的文件?
求大神指点!
发表于 2014-7-10 23:25:32 | 显示全部楼层
请问楼主这个问题解决没有啊,我也遇到同样的问题了,不知道怎么解决啊
发表于 2014-7-12 23:33:45 | 显示全部楼层
谢谢楼主...
发表于 2014-7-13 14:22:52 | 显示全部楼层
vpi_user.h不在你包含的路径下,应该加 -ID:/questa_sim_10.0a/include 也就是-I$(QUESTASIM_PATH)/include
发表于 2016-1-9 23:14:17 | 显示全部楼层
good job~~~
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 18:45 , Processed in 1.904918 second(s), 4 queries , Gzip On, Redis On.
