查看: 2587|回复: 1
[原创] Basic Knowledge of the Dental Curing Light
发表于 2012-3-19 15:32:50 | 显示全部楼层 |阅读模式
LED lightcuring machine is mainly used in clinic or dentistry,for dental repair withteeth curing in resin curing light. The superior curing effect of the LED lightcuring machine is being recognized by more and more physicians.
Somebasic knowledge of the dental curing light is now recommended for you.
TheDental Curing Light operating instructions
1.
Before the first use of the the DentalCuring Light we should charge it at least 14 hours. After that therecharging should be no more than 10 hours.
2.
To prevent eye light stimulation, we’d betterput on a good brown goggles before we use the dental curing light.
3.
we should fix well the locationbetween the dental curing light and the lamp holder shields.
4.
Install the lamp cap at the partsto be curing of the patients,then press the power switch.
5.
Turn the poweron a single working hours up to 60 seconds,then beep every ten secondsto prompt the operatorto select the appropriate curing time.
6.
After the operation is completedturn the lamp cap down on the free dental handpiece or any other dentalinstrument so as to facilitate the next using time. When the light of thedental during light get significantly weakened we should recharge itimmediately. Pull down the transformer on the plug if we need to use it after along time.
Pointsfor Attention of operating curing light
1.
Before charging to the curinglight make sure that the region voltage is 220V.
2.
The plastic shell of the dentalcuring light should avoid tough object impact.
3.
Curing light can only be scrubbedwith disinfectant or disinfection item, can not be immersed in water ordisinfectant.
4.
Do not look at the light directly.
5.
Children non-operating curinglight. Please keep it out of reach of children.
Ourmission is to provide a lifetime of oral health and wellness for you, yourfamily and friends. For more information,please feel free to visit www.izidental.com, a senior-friendly website fromthe professional and incredibly selective dental equipment and supplies.
发表于 2012-3-19 21:27:40 | 显示全部楼层
very good
GMT+8, 2025-9-13 07:03 , Processed in 0.023353 second(s), 7 queries , Gzip On, Redis On.
